It is currently Sat May 18, 2013 3:24 pm
Post new topic Reply to topic  [ 3 posts ]
Unread postPosted: Wed Dec 22, 2010 8:40 pm
Thanks to Mike for a great packing job on this one.
Nice Indigo2 with IMPACT badge and matching feet. I've got a 100aseT 3COM EISA card around here that I'll install once I find it again... And at some point it'll get a fresh install.
Edit: Halfway to a GigaRAM Indigo2 with one kit of HP D4893A 128MB SIMMs installed and another set on order. Why? Why not?? Also added the "10000" badge. I'll have to see what happened to the pictures I took...
Code:
# hinv -vm
1 195 MHZ IP28 Processor
Main memory size: 768 Mbytes
On-board serial ports: 2
Graphics board: Solid Impact
EISA bus: adapter 0
Code:
# /usr/gfx/gfxinfo -vv
        Product ID 0x1, 1 GE, 1 RE, 0 TRAMs
        VC3 rev A, CMAP rev EMC rev D
         Video Format Flags:  (none)
         Sync Disabled
         Using Gamma Map 0
         Monitor Type:  unknown
Code:
# uname -aR
IRIX64 PURPSY 6.5 6.5.21f 07141608 IP28
Code:
# scsicontrol -i /dev/scsi/*
/dev/scsi/sc0d1l0:  Disk          IBM     DGHS09Z         03E0
ANSI vers 3, ISO ver: 0, ECMA ver: 0; supports:  synch linkedcmds cmdqueing
Device is  ready
/dev/scsi/sc0d2l0:  Disk          SEAGATE ST15230N        0638
ANSI vers 2, ISO ver: 0, ECMA ver: 0; supports:  synch cmdqueing
Device is  ready
/dev/scsi/sc0d3l0:  CD-ROM        TOSHIBA CD-ROM XM-5401TA0436
ANSI vers 2, ISO ver: 0, ECMA ver: 0; supports:  reladdr linkedcmds
Device is  not ready
Code:
# /sbin/diskpatch -v
sc0d1l0:  Disk         IBM     DGHS09Z         03E0  Serial: 6827A323
sc0d2l0:  Disk         SEAGATE ST15230N        0638  Serial: 00536493
Then? :IRIS3130: ... Now? :O3x02L: :1600SW:+MLA :Fuel: :Octane2: :Octane: :Indigo2IMP: ... Other: DEC :BA213: :BA123: Sun, DG AViiON, NeXT :Cube:
Unread postPosted: Wed Dec 22, 2010 8:53 pm
Very Nice! Pics?
:Octane2: :Octane2: :Octane: :Indigo2IMP: :Indigo2: :O2: :O2+:
Octane2 2x600 V12 8GB
- Octane2 600 V12 2GB - Octane 2x400 V10 2GB
Indigo² 195 Max Impact 386MB - Indigo² 250 Extreme 386MB
O2 350 CRM 256MB - O2+ 400 CRM 512MB
"I'm totally unappreciated in my time. You can run this whole park from this room, with minimal staff, for up to three days. You think that kind of automation is easy? Or cheap? You know anybody who can network eight Connection Machines and de-bug two million lines of code for what I bid this job? Because if you can, I'd love to see him try."
Unread postPosted: Wed Dec 22, 2010 10:21 pm
Pics tomorrow, I'll edit this placeholder and add them.
