Indigo2, R4400 200Mhz, 384Mb RAM, Extreme
Unread postby Voralyan » Tue Dec 14, 2010 7:35 am
And another one, "proxima", the Indigo2:
thoweh@proxima $>hinv -v
CPU: MIPS R4400 Processor Chip Revision: 6.0
1 200 MHZ IP22 Processor
Main memory size: 384 Mbytes
Data cache size: 16 Kbytes
On-board serial ports: 2
Graphics board: GU1-Extreme
EISA bus: adapter 0
thoweh@proxima $>/usr/gfx/gfxinfo
        8 GEs, 2 REs, 24 bitplanes, 4 auxplanes, 4 cidplanes, Z-buffer
        GR2 revision 6, VB2.0
        HQ2.1 rev A, GE7 rev B,  RE3.1 rev A, VC1 rev B, MC rev C
        unknown, assuming 19" monitor
Other hardware:
- SGI granite keyboard & mouse
- Eizo FlexScan L567 (I'm an Eizo fan...) via the self made cable
- 3com fast ethernet card in EISA slot (Phobos E100 drives)
Planned upgrades:
:A3502L: :O2000: :O200: = :O200: - :O200: :O200: :Octane: :Octane: :320: :O2: :Indigo2IMP: :Indy:
+ | d | i | g | i | t | a | l | +apple +[...] ;)
Re: Indigo2, R4400 200Mhz, 384Mb RAM, Extreme
Unread postby jan-jaap » Tue Dec 14, 2010 7:48 am
Voralyan wrote:- Eizo FlexScan L567 (I'm an Eizo fan...)
Me too. It's very sad that most of the current EIZO displays do not support sync-on-green anymore :(
