It is currently Wed May 22, 2013 5:22 pm
Post new topic Reply to topic  [ 2 posts ]
Unread postPosted: Thu Jun 03, 2010 1:40 am
Recently acquired, still exploring. Pretty serviceable little box, but there's more RAM on the way already. And there's this PCI card cage that came in the "spare" chassis... Will have to add pictures another time.
Code:
octane2# hinv -vm
      PM20360MHZ Board: barcode KGL983     part 030-1591-001 rev  A
            IP30 Board: barcode KKJ530     part 030-1467-001 rev  D
             FP1 Board: barcode MGH323     part 030-0891-003 rev  J
    PWR.SPPLY.ER Board: barcode AAE9070645 part 060-0035-001 rev  C
           MOT20 Board: barcode HAT084     part 030-1240-003 rev  D
             EVO Board: barcode GPY486     part 030-1156-999 rev  A
2 360 MHZ IP30 Processors
Heart ASIC: Revision F
CPU: MIPS R12000 Processor Chip Revision: 3.3
Main memory size: 1024 Mbytes
Xbow ASIC: Revision 1.4
  Tape drive: unit 2 on SCSI controller 0: DAT
Graphics board: EMXI
Personal Video: unit 1, revision 2.0
octane2#
Code:
octane2# ./gfxinfo
        VC3 rev A, CMAP rev E, Heart rev F
        21" monitor (id 0xb)
        Video board present
octane2#
Code:
octane2# uname -R
6.5 6.5.22m
octane2# cc -version
MIPSpro Compilers: Version 7.4.4m
octane2#
Then? :IRIS3130: ... Now? :O3x02L: :1600SW:+MLA :Fuel: :Octane2: :Octane: :Indigo2IMP: ... Other: DEC :BA213: :BA123: Sun, DG AViiON, NeXT :Cube:
Unread postPosted: Tue Jun 08, 2010 3:00 pm
A good one! (better then mine):) Mine is only 1x300 Mhz and ESI. (Still hasn't got a camera to take some shots and post a hinv.-)
:O2: [urubamba][R5K, 180MHz, 512 Mb] :Octane2: [tezcatlipoca][R12K, 1x300MHz, 1024 Mb, V8]
