Origin 350: 16xR16K 700MHz, 4GB RAM
ramq
Unread postby ramq » Sat Dec 12, 2009 4:06 pm
May I present 'Venom', my newly downsized Origin 350 multi-brick config!
This is what's left at the moment from my rescent aquire and is trimmed down to a more manageable size (=less powerdraw).
hinv -vm
       IP53_4CPU Board: barcode MXD727     part 030-1868-001 rev -C
       2U_INT_53 Board: barcode MTZ152     part 030-1809-003 rev -B
             IO9 Board: barcode MTS407     part 030-1771-005 rev -A
       IP53_4CPU Board: barcode MXM753     part 030-1868-001 rev -C
       2U_INT_53 Board: barcode MTC260     part 030-1809-003 rev -A
Location: /hw/module/001c02/IXbrick/xtalk/15/pci-x/0/1/ioc4
             IO9 Board: barcode MTS540     part 030-1771-005 rev -A
       IP53_4CPU Board: barcode MTA290     part 030-1868-001 rev -C
       2U_INT_53 Board: barcode MTC253     part 030-1809-003 rev -A
       IP53_4CPU Board: barcode MTA291     part 030-1868-001 rev -C
       2U_INT_53 Board: barcode MTV599     part 030-1809-003 rev -A
          ROUTER Board: barcode MVA352     part 030-1634-003 rev -A
16 700 MHZ IP35 Processors
  Processor revision: 2.1. Scache: Size 4 MB Speed 350 Mhz  Tap 0xc
CPU 1 at Module 001c01/Slot 0/Slice B: 700 Mhz MIPS R16000 Processor Chip (enabled)
CPU 2 at Module 001c01/Slot 0/Slice C: 700 Mhz MIPS R16000 Processor Chip (enabled)
CPU 3 at Module 001c01/Slot 0/Slice D: 700 Mhz MIPS R16000 Processor Chip (enabled)
CPU 4 at Module 001c02/Slot 0/Slice A: 700 Mhz MIPS R16000 Processor Chip (enabled)
CPU 5 at Module 001c02/Slot 0/Slice B: 700 Mhz MIPS R16000 Processor Chip (enabled)
CPU 6 at Module 001c02/Slot 0/Slice C: 700 Mhz MIPS R16000 Processor Chip (enabled)
CPU 7 at Module 001c02/Slot 0/Slice D: 700 Mhz MIPS R16000 Processor Chip (enabled)
CPU 8 at Module 001c03/Slot 0/Slice A: 700 Mhz MIPS R16000 Processor Chip (enabled)
CPU 9 at Module 001c03/Slot 0/Slice B: 700 Mhz MIPS R16000 Processor Chip (enabled)
CPU 10 at Module 001c03/Slot 0/Slice C: 700 Mhz MIPS R16000 Processor Chip (enabled)
CPU 11 at Module 001c03/Slot 0/Slice D: 700 Mhz MIPS R16000 Processor Chip (enabled)
CPU 12 at Module 001c04/Slot 0/Slice A: 700 Mhz MIPS R16000 Processor Chip (enabled)
CPU 13 at Module 001c04/Slot 0/Slice B: 700 Mhz MIPS R16000 Processor Chip (enabled)
CPU 14 at Module 001c04/Slot 0/Slice C: 700 Mhz MIPS R16000 Processor Chip (enabled)
CPU 15 at Module 001c04/Slot 0/Slice D: 700 Mhz MIPS R16000 Processor Chip (enabled)
Main memory size: 4096 Mbytes
Memory at Module 001c01/Slot 0: 1024 MB (enabled)
  Bank 0 contains 512 MB (Premium) DIMMS (enabled)
  Bank 1 contains 512 MB (Premium) DIMMS (enabled)
Memory at Module 001c02/Slot 0: 1024 MB (enabled)
Memory at Module 001c03/Slot 0: 1024 MB (enabled)
Memory at Module 001c04/Slot 0: 1024 MB (enabled)
ROUTER in Module 001c01/Slot 0: Revision 1: Active Ports [2,3,4,5,] (enabled)
Integral SCSI controller 19: Version IDE (ATA/ATAPI) IOC4
Integral SCSI controller 20: Version QL12160, low voltage differential
Integral SCSI controller 21: Version QL12160, low voltage differential
IOC3/IOC4 serial port: tty27
IOC3/IOC4 serial port: tty28
IOC3/IOC4 serial port: tty29
IOC3/IOC4 serial port: tty30
IOC3/IOC4 serial port: tty23
IOC3/IOC4 serial port: tty24
IOC3/IOC4 serial port: tty25
IOC3/IOC4 serial port: tty26
Gigabit Ethernet: tg6, module 001c02, PCI bus 1 slot 4
IOC4 firmware revision 79
IOC3/IOC4 external interrupts: 6
HUB in Module 001c03/Slot 0: Revision 2 Speed 200.00 Mhz (enabled)
HUB in Module 001c04/Slot 0: Revision 2 Speed 200.00 Mhz (enabled)
IP35prom in Module 001c03/Slot n0: Revision 6.210
IP35prom in Module 001c04/Slot n0: Revision 6.210
l1cmd serial all
Local System Serial Number      NVRAM         M2100629
Reference System Serial Number  NVRAM         M2100629
Local Brick Serial Number       EEPROM        MTZ152
Reference Brick Serial Number   NVRAM         MTZ152
EEPROM      Product Name    Serial      Part Number           Rev  T/W
INTERFACE   2U_INT_53       MTZ152      030_1809_003          B    00
IO9         IO9             MTS407      030_1771_005          A    00
ODYSSEY     no hardware detected
RISER       2U_RISER        MXN357      030_1808_005          A    00
NODE        IP53_4CPU       MXD727      030_1868_001          C    00
EEPROM     JEDEC-SPD Info           Part Number        Rev Speed  SGI
DIMM 0     CE000000000000005FF40800 M3 46L6510BT1-CA0  0B   10.0  NO DATA
DIMM 2     no hardware detected
DIMM 4     no hardware detected
DIMM 6     no hardware detected
DIMM 1     CE000000000000005FC80C00 M3 46L6510BT1-CA0  0B   10.0  NO DATA
DIMM 3     no hardware detected
DIMM 5     no hardware detected
DIMM 7     no hardware detected
l1cmd env
           12V   Disabled  10%  10.80/ 13.20  20%   9.60/ 14.40   12.06
           12V    Enabled  10%  10.80/ 13.20  20%   9.60/ 14.40   12.06
            5V    Enabled  10%   4.50/  5.50  20%   4.00/  6.00    4.97
          3.3V    Enabled  10%   2.97/  3.63  20%   2.64/  3.96    3.32
        12V IO    Enabled  10%  10.80/ 13.20  20%   9.60/ 14.40   12.06
        5V aux    Enabled  10%   4.50/  5.50  20%   4.00/  6.00    5.04
      3.3V aux    Enabled  10%   2.97/  3.63  20%   2.64/  3.96    3.27
          2.5V    Enabled  10%   2.25/  2.75  20%   2.00/  3.00    2.51
          1.8V    Enabled  10%   1.62/  1.98  20%   1.44/  2.16    1.78
      3.3V aux   Disabled  10%   2.97/  3.63  20%   2.64/  3.96    3.27
  XIO 12V bias   Disabled  10%  10.80/ 13.20  20%   9.60/ 14.40    0.00
        XIO 5V   Disabled  10%   4.50/  5.50  20%   4.00/  6.00    0.00
      XIO 2.5V   Disabled  10%   2.25/  2.75  20%   2.00/  3.00    0.00
  XIO 3.3V aux   Disabled  10%   2.97/  3.63  20%   2.64/  3.96    0.00
NODE0 3.3V aux    Enabled  10%   2.97/  3.63  20%   2.64/  3.96    3.27
  NODE0 5V aux    Enabled  10%   4.50/  5.50  20%   4.00/  6.00    5.04
     NODE0 12V    Enabled  10%  10.80/ 13.20  20%   9.60/ 14.40   12.00
    NODE0 SRAM    Enabled  10%   2.25/  2.75  20%   2.00/  3.00    2.50
    NODE0 1.5V    Enabled  10%   1.35/  1.65  20%   1.20/  1.80    1.49
     NODE0 CPU    Enabled  10%   1.13/  1.38  20%   1.00/  1.50    1.25
FAN 0  EXHST 1    Enabled         2160         2305
FAN 1  EXHST 2    Enabled         2160         2305
FAN 2       PS    Enabled         1575         1980
FAN 3    PCI 1    Enabled         2160         2589
FAN 4    PCI 2    Enabled         2160         2877
Description    State       Temp       Temp       Temp       Temp
INTERFACE 0       Enabled   31C/ 87F   48C/118F   55C/131F    5C/ 41F -23-
INTERFACE 1       Enabled   31C/ 87F   48C/118F   55C/131F    6C/ 42F -23-
INTERFACE 2       Enabled   31C/ 87F   48C/118F   55C/131F   11C/ 51F -13-
PCI RISER         Enabled   31C/ 87F   48C/118F   55C/131F   10C/ 50F -11-
ODYSSEY          Disabled
NODE              Enabled   31C/ 87F   48C/118F   55C/131F    8C/ 46F -14-
BEDROCK           Enabled   31C/ 87F   48C/118F   55C/131F    3C/ 37F -31-
scsicontrol -i /dev/scsi/sc*
/dev/scsi/sc0d1l0:  Disk          COMPAQ  BD1468A4B5      HPB8
Device is  ready
/dev/scsi/sc2d0l0:  CD-ROM        MATSHITADVD-ROM SR-8178 PZ21
ANSI vers 0, ISO ver: 0, ECMA ver: 0; supports:
Device is  not ready
/sbin/diskpatch -v
sc0d1l0:  Disk         COMPAQ  BD1468A4B5      HPB8  Serial: J405XJ1K
Re: Origin 350: 16xR16K 700MHz, 4GB RAM
Unread postby recondas » Sat Dec 12, 2009 6:00 pm
Very nice! Any plans to add graphics?
BTW, were you able to use the pin-out information to set up a power supply for your L2 controller? Like you, I have two systems with L2 controllers, and have I've found the L3 software to be very handy as an overall controller/remote monitoring tool for both systems. I run it on the same lightweight system used as a Synergy host <run so I can share a single keyboard and mouse between the Onyx 300, Onyx 350, a PC and a Mac>.
Unread postby hamei » Sun Dec 13, 2009 12:02 am
recondas wrote: < so I can share a single keyboard and mouse between the Onyx 300, Onyx 350, a PC and a Mac>.
I hate to say this, but have you guys considered the possibility that maybe you're getting a little carried away ? :shock:
Unread postby guardian452 » Sun Dec 13, 2009 11:41 am
well, good keyboards and mice ARE hard to find ;)
Unread postby foetz » Sun Dec 13, 2009 10:35 pm
sybrfreq wrote:well, good keyboards and mice ARE hard to find ;)
indeed. i'm always stocking up granite kb and mice as good as i can :D
ramq
Unread postby ramq » Mon Dec 14, 2009 2:19 am
recondas wrote:Very nice! Any plans to add graphics?
Well, yes and no. I'm planning on incorporating the famous "V10 hack", but it's on very low priority cause I currently don't need graphics on it, other than for fun. A little FW-card and USB will probably pimp this machine a little further, but nothing planned further than that.
Well, apart from memory that is. (Currently I have some 2GB kits in hopefully a couple of weeks.)
Well, actually I haven't had time for it yet. Had some spare time this weekend to fire up this thing, plus diagnosing other bricks, etc. I'll probably measure the pinout next time I'll dedicate time for the O3800 system + power measuring.
So far this hasn't been a problem though, since the L3 software takes care of all my needs so far. Only drawback is that L1-reconfigs (changing rack/slot numbers + associated reboot) crap things up on the little Linux-bugger, so I have to reboot it every time I make such changes.
