Onyx350 InfinitePerformance Dual-Head:
Code:
# hinv -vm
IP53_4CPU Board: barcode MZH509 part 030-1868-001 rev -C
ASTODY Board: barcode MLV203 part 030-1726-003 rev -E
2U_INT_53 Board: barcode MYE900 part 030-1809-003 rev -B
IO9 Board: barcode MYM430 part 030-1771-005 rev -A
IP53_4CPU Board: barcode MXL750 part 030-1812-002 rev -C
ASTODY Board: barcode MYA424 part 030-1726-005 rev -A
2U_INT_53 Board: barcode NNX272 part 030-1809-006 rev -B
Location: /hw/module/001c02/IXbrick/xtalk/15/pci-x/0/1/ioc4
IO9 Board: barcode NLC357 part 030-1771-005 rev -A
8 700 MHZ IP35 Processors
Processor revision: 2.1. Scache: Size 4 MB Speed 350 Mhz Tap 0xc
CPU 1 at Module 001c01/Slot 0/Slice B: 700 Mhz MIPS R16000 Processor Chip (enabled)
CPU 2 at Module 001c01/Slot 0/Slice C: 700 Mhz MIPS R16000 Processor Chip (enabled)
CPU 3 at Module 001c01/Slot 0/Slice D: 700 Mhz MIPS R16000 Processor Chip (enabled)
CPU 4 at Module 001c02/Slot 0/Slice A: 700 Mhz MIPS R16000 Processor Chip (enabled)
Processor revision: 2.1. Scache: Size 8 MB Speed 350 Mhz Tap 0xa
CPU 5 at Module 001c02/Slot 0/Slice B: 700 Mhz MIPS R16000 Processor Chip (enabled)
CPU 6 at Module 001c02/Slot 0/Slice C: 700 Mhz MIPS R16000 Processor Chip (enabled)
CPU 7 at Module 001c02/Slot 0/Slice D: 700 Mhz MIPS R16000 Processor Chip (enabled)
Main memory size: 16384 Mbytes
Memory at Module 001c02/Slot 0: 8192 MB (enabled)
Integral SCSI controller 4: Version IDE (ATA/ATAPI) IOC4
CDROM: unit 0 on SCSI controller 4
Integral SCSI controller 3: Version SAS/SATA LS1068
Integral SCSI controller 5: Version QL12160, low voltage differential
Integral SCSI controller 6: Version QL12160, low voltage differential
Integral SCSI controller 7: Version QL12160, low voltage differential
Disk drive: unit 1 on SCSI controller 7 (unit 1)
Disk drive: unit 2 on SCSI controller 7 (unit 2)
Integral SCSI controller 8: Version QL12160, low voltage differential
IOC3/IOC4 serial port: tty3
IOC3/IOC4 serial port: tty4
IOC3/IOC4 serial port: tty5
IOC3/IOC4 serial port: tty6
IOC3/IOC4 serial port: tty7
IOC3/IOC4 serial port: tty8
IOC3/IOC4 serial port: tty9
IOC3/IOC4 serial port: tty10
Graphics board: V12
Graphics board: V12
Gigabit Ethernet: tg1, module 001c02, PCI bus 1 slot 4
Gigabit Ethernet: eg0, module 001c02, slot -1, firmware version 12.4.10
Iris Audio Processor: version RAD revision 13.0, number 1
PCI Adapter ID (vendor 0x1000, device 0x0054) PCI slot 2
PCI Adapter ID (vendor 0x1077, device 0x1216) PCI slot 2
PCI Adapter ID (vendor 0x1412, device 0x1724) PCI slot 1
PCI Adapter ID (vendor 0x1033, device 0x0035) PCI slot 2
PCI Adapter ID (vendor 0x1033, device 0x00e0) PCI slot 2
PCI Adapter ID (vendor 0x10a9, device 0x0005) PCI slot 2
IOC4 firmware revision 83
Dual Channel Display
IP35prom in Module 001c01/Slot n0: Revision 6.211
IP35prom in Module 001c02/Slot n0: Revision 6.211
USB controller: type OHCI
Code:
# /usr/gfx/gfxinfo -vv
Managed (":0.0") 3200x1200
BUZZ version B.1
PB&J version 1
128MB memory
Banks: 4, CAS latency: 3
Monitor 0 type: Unknown
Dual Channel Display option
Monitor 1 type: VSC 4892 Monitor 2 type: VSC 4892
Video Output: 1600 pixels, 1200 lines, 60.00Hz (2@1600x1200_60_ds)
Video Format Flags: (none)
Sync Disabled
Using Gamma Map 0
Monitor Type: VSC-4892
Gain (all color components) - 0.000000 ; range [1,10]
Channel 1:
Origin = (1600,0)
Sync Disabled
Using Gamma Map 0
Graphics board 1 is "ODYSSEY" graphics.
Managed (":0.1") 3200x1200
BUZZ version B.2
PB&J version 1
128MB memory
Monitor 1 type: DEL -24543 Monitor 2 type: SAM 430
Sync Disabled
Using Gamma Map 0
Monitor Type: DEL-40993
Channel 1:
Origin = (1600,0)
Sync Disabled
Using Gamma Map 0
Monitor Type: SAM-430
Code:
# l2cmd serial all
001c01:
Data Location Value
Local System Serial Number NVRAM M2008888
Reference System Serial Number Attached L2 M2008888
Local Brick Serial Number EEPROM MYE999
Reference Brick Serial Number NVRAM MYE999
EEPROM Product Name Serial Part Number Rev T/W
INTERFACE 2U_INT_53 MYE900 030_1809_003 B 00
IO9 IO9 MYM430 030_1771_005 A 00
ODYSSEY ASTODY MLV203 030_1726_003 E 00
RISER 2U_RISER MXC235 030_1808_005 A 00
NODE IP53_4CPU MZH509 030_1868_001 C 00
SNOWBALL no hardware detected
PS 1 no hardware detected
PS 2 DPS-500EBE XPD0323002193 060-0178-003 S1
EEPROM JEDEC-SPD Info Part Number Rev Speed SGI
DIMM 0 7F7FFE000000000012001671 CM2201B 2 8.0 NO DATA
DIMM 2 7F7FFE000000000012001690 CM2201B 2 8.0 NO DATA
DIMM 4 CE000000000000000CF04200 M3 46L2820BT2-CA0 2B 10.0 NO DATA
DIMM 6 CE000000000000000CA94200 M3 46L2820BT2-CA0 2B 10.0 NO DATA
DIMM 1 7F7FFE000000000012001691 CM2201B 2 8.0 NO DATA
DIMM 3 7F7FFE00000000001200168E CM2201B 2 8.0 NO DATA
DIMM 5 CE000000000000000CE64800 M3 46L2820BT2-CA0 2B 10.0 NO DATA
DIMM 7 CE000000000000000C5A4D00 M3 46L2820BT2-CA0 2B 10.0 NO DATA
001c02:
Data Location Value
Local Brick Serial Number EEPROM NNX222
Reference Brick Serial Number NVRAM NNX222
INTERFACE 2U_INT_53 NNX272 030_1809_006 B 00
IO9 IO9 NLC357 030_1771_005 A 00
ODYSSEY ASTODY MYA424 030_1726_005 A 00
RISER 2U_RISER NND054 030_1808_006 B 00
NODE IP53_4CPU MXL750 030_1812_002 C 00
PS 2 DPS-500EBE XPD0451009596 060-0178-003 S4
DIMM 0 CE000000000000000C6F6F00 M3 46L2820BT2-CA0 2B 10.0 N/A
DIMM 2 CE000000000000000C576F00 M3 46L2820BT2-CA0 2B 10.0 N/A
DIMM 4 CE000000000000000C5B0200 M3 46L2820DT2-CA0 2D 10.0 N/A
DIMM 6 CE000000000000000C620200 M3 46L2820DT2-CA0 2D 10.0 N/A
DIMM 1 CE000000000000000CBD6F00 M3 46L2820BT2-CA0 2B 10.0 N/A
DIMM 3 CE000000000000000C786F00 M3 46L2820BT2-CA0 2B 10.0 N/A
DIMM 5 CE000000000000000C5A0100 M3 46L2820DT2-CA0 2D 10.0 N/A
DIMM 7 CE000000000000000CEB0100 M3 46L2820DT2-CA0 2D 10.0 N/A
Code:
#l2cmd env
001c01:
Description State Warning Limits Fault Limits Current
1.8V Enabled 10% 1.62/ 1.98 20% 1.44/ 2.16 1.78
12V Disabled 10% 10.80/ 13.20 20% 9.60/ 14.40 12.12
12V Enabled 10% 10.80/ 13.20 20% 9.60/ 14.40 12.06
3.3V Enabled 10% 2.97/ 3.63 20% 2.64/ 3.96 3.32
12V IO Enabled 10% 10.80/ 13.20 20% 9.60/ 14.40 12.06
5V aux Enabled 10% 4.50/ 5.50 20% 4.00/ 6.00 5.04
3.3V aux Enabled 10% 2.97/ 3.63 20% 2.64/ 3.96 3.27
2.5V Enabled 10% 2.25/ 2.75 20% 2.00/ 3.00 2.51
5V Enabled 10% 4.50/ 5.50 20% 4.00/ 6.00 4.94
3.3V aux Disabled 10% 2.97/ 3.63 20% 2.64/ 3.96 3.27
XIO 12V bias Enabled 10% 10.80/ 13.20 20% 9.60/ 14.40 12.00
XIO 5V Enabled 10% 4.50/ 5.50 20% 4.00/ 6.00 4.94
XIO 2.5V Enabled 10% 2.25/ 2.75 20% 2.00/ 3.00 2.47
XIO 3.3V aux Enabled 10% 2.97/ 3.63 20% 2.64/ 3.96 3.32
NODE0 3.3V aux Enabled 10% 2.97/ 3.63 20% 2.64/ 3.96 3.27
NODE0 5V aux Enabled 10% 4.50/ 5.50 20% 4.00/ 6.00 5.04
NODE0 12V Enabled 10% 10.80/ 13.20 20% 9.60/ 14.40 12.00
NODE0 SRAM Enabled 10% 2.25/ 2.75 20% 2.00/ 3.00 2.48
NODE0 1.5V Enabled 10% 1.35/ 1.65 20% 1.20/ 1.80 1.49
NODE0 CPU Enabled 10% 1.13/ 1.38 20% 1.00/ 1.50 1.25
Description State Warning RPM Current RPM
FAN 0 EXHST 1 Enabled 2160 2370
FAN 1 PS Enabled 1800 2103
FAN 2 PCI 1 Enabled 2160 2337
FAN 3 PCI 2 Enabled 2160 2569
FAN 4 ODY Enabled 1679 4371
Advisory Critical Fault Current
Description State Temp Temp Temp Temp
INTERFACE 0 Enabled Disabled Disabled 75C/167F 46C/114F
INTERFACE 1 Enabled Disabled Disabled 75C/167F 45C/113F
INTERFACE 2 Enabled Disabled Disabled 75C/167F 33C/ 91F
PCI RISER Enabled Disabled Disabled 75C/167F 32C/ 89F
ODYSSEY Enabled Disabled Disabled 75C/167F 38C/100F
NODE Enabled Disabled Disabled 75C/167F 29C/ 84F
BEDROCK Enabled Disabled Disabled 75C/167F 46C/114F
001c02:
1.8V Enabled 10% 1.62/ 1.98 20% 1.44/ 2.16 1.777
12V <not present>
12V #2 Enabled 10% 10.80/ 13.20 20% 9.60/ 14.40 12.000
3.3V Enabled 10% 2.97/ 3.63 20% 2.64/ 3.96 3.320
12V IO Enabled 10% 10.80/ 13.20 20% 9.60/ 14.40 12.063
5V AUX Enabled 10% 4.50/ 5.50 20% 4.00/ 6.00 5.044
3.3V AUX Enabled 10% 2.97/ 3.63 20% 2.64/ 3.96 3.268
PCI 5V AUX Enabled 10% 4.50/ 5.50 20% 4.00/ 6.00 5.044
PCI 3.3V Enabled 10% 2.97/ 3.63 20% 2.64/ 3.96 3.320
PCI 2.5V Enabled 10% 2.25/ 2.75 20% 2.00/ 3.00 2.496
PCI 5V Enabled 10% 4.50/ 5.50 20% 4.00/ 6.00 4.940
IP53 3.3V AUX Enabled 10% 2.97/ 3.63 20% 2.64/ 3.96 3.268
IP53 5V AUX Enabled 10% 4.50/ 5.50 20% 4.00/ 6.00 5.044
IP53 12V Enabled 10% 10.80/ 13.20 20% 9.60/ 14.40 12.000
IP53 VCPU Enabled 10% 1.13/ 1.38 20% 1.00/ 1.50 1.241
IP53 SRAM Enabled 10% 2.25/ 2.75 20% 2.00/ 3.00 2.470
IP53 1.5V Enabled 10% 1.35/ 1.65 20% 1.20/ 1.80 1.495
FAN 0 EXHST 1 Enabled 1980 2177
FAN 1 EXHST 2 Enabled 1980 2177
FAN 2 PS Enabled 3200 4066
FAN 3 PCI 1 Enabled 1980 2616
0 INTERFACE 0 Enabled 31C/ 87F 48C/118F 55C/131F 15C/ 59F
1 INTERFACE 1 Enabled 31C/ 87F 48C/118F 55C/131F 17C/ 62F
2 INTERFACE 2 Enabled 31C/ 87F 48C/118F 55C/131F 18C/ 64F
3 PCI RISER Enabled 31C/ 87F 48C/118F 55C/131F 18C/ 64F
4 ODYSSEY Enabled 31C/ 87F 48C/118F 75C/167F 38C/100F
5 NODE Enabled 31C/ 87F 48C/118F 55C/131F 15C/ 59F
6 BEDROCK Enabled 31C/ 87F 48C/118F 55C/131F 16C/ 60F
Code:
l2cmd pci
001c01:
Bus Slot Slot Stat Bus Stat Power Mode/Speed
1 1 0x80 0x01 0x44 15W PCI 66MHz
1 2 0xad 0x0c 0x44 7.5W PCI 66MHz
2 1 0x40 0x00 0x40 7.5W PCI 33MHz
2 2 0x44 0x01 0x40 15W PCI 33MHz
001c02:
Bus Slot Slot Stat Power Mode/Speed
1 1 0x80 0x01 15W PCI 66MHz
1 2 0x80 0x01 15W PCI 66MHz
2 1 0x00 0x0f none PCI 33MHz
2 2 0x00 0x00 7.5W PCI 33MHz
Code:
# l2cmd l1 ver
001c01:
L1 1.48.1 (Image A), Built 01/22/2007 11:34:34 [MIPS 2MB image]
001c02:
# l2cmd ver
L2 version: 1.48.0
...and the PROM Power-On Diagnostics info:
Code:
Starting PROM Boot process
IP35 PROM SGI Version 6.210 built 02:33:51 PM Aug 26, 2004
Testing/Initializing memory ............... DONE
Copying PROM code to memory ............... DONE
Discovering local IO ...................... DONE
Discovering NUMAlink connectivity ......... DONE
Found 2 objects (2 hubs, 0 routers) in 7125 usec
Waiting for peers to complete discovery.... DONE
Global master is /hw/rack/001/bay/01....... DONE
Intializing any CPUless nodes.............. DONE
Checking partitioning information ......... DONE
Local slave entering slave loop
Loading BASEIO prom ....................... DONE
BASEIO PROM Monitor SGI Version 6.210 built 02:30:38 PM Aug 26, 2004 (BE64)
8 CPUs on 2 nodes found.
Graphics diagnostics
Board version 1 - Buzz revision 2B
On board sdram size: 128 Mb
Cas latency: CAS 3
4 banks by sdram module
Device passed diagnostics
Odyssey board #1 found on nasid 1
Board version 1 - Buzz revision 3B
Cas latency: CAS 3
On-board (IO9) tigon3 1000BaseT interface
Base I/O Ethernet set to /dev/ethernet/tg0
Probing IOC4 ATA adapter 2
IOC4 RevId = 83
Detected Vendor id/Product MATSHITA DVD-ROM SR-8177
Walking SCSI Adapter 0, (pci id 3)
1+ Device Vendor Product: SEAGATE ST336753LC
2+ Device Vendor Product: SEAGATE ST336753LC
3- 4- 5- 6- 7- 8- 9- 10- 11- 12- 13- 14- 15- = 2 device(s)
Walking SCSI Adapter 1, (pci id 3)
Initializing PROM Device drivers ..........
Initializing Base I/O Ethernet Interface...Done.
---------------Interface Configuration Summary----------------
ASIC|Revision|MAC Address : 5701|B5|08:00:69:13:e7:48
Link Negotiation|Advertisement : On|<H10 F10 H100 F100 H1000 F1000>
Link|Speed|Duplex|Rx/Tx FlowCtrl: Up|1000|Full|Off/Off
