It is currently Sat May 25, 2013 1:53 pm
Post new topic Reply to topic  [ 3 posts ]
Unread postPosted: Tue Oct 20, 2009 3:14 pm
Code:
Speedracer# hinv -vm
      PM20600MHZ Board: barcode MXF583     part 030-1778-001 rev  C
            IP30 Board: barcode MWY770     part 030-1467-001 rev  J
    PWR.SPPLY.ER Board: barcode AAE0030096 part 060-0035-003 rev  A
             FP1 Board: barcode MVJ424     part 030-0891-003 rev  J
  ODY128VERSIONB Board: barcode MSG686     part 030-1611-001 rev  C
2 600 MHZ IP30 Processors
Heart ASIC: Revision F
Main memory size: 8192 Mbytes
Xbow ASIC: Revision 1.4
Graphics board: V12
Code:
Speedracer# usr/gfx/gfxinfo
        Managed (":0.0") 1600x1200
        BUZZ version B.1
        PB&J version 1
        128MB memory
                Banks: 4, CAS latency: 3
         Monitor 0 type: Unknown
         Video Output: 1600 pixels, 1200 lines, 59.83Hz (1600x1200_60)
:Octane2: :Octane2: :Octane: :Indigo2IMP: :Indigo2: :O2: :O2+:
Octane2 2x600 V12 8GB
- Octane2 600 V12 2GB - Octane 2x400 V10 2GB
Indigo² 195 Max Impact 386MB - Indigo² 250 Extreme 386MB
O2 350 CRM 256MB - O2+ 400 CRM 512MB
"I'm totally unappreciated in my time. You can run this whole park from this room, with minimal staff, for up to three days. You think that kind of automation is easy? Or cheap? You know anybody who can network eight Connection Machines and de-bug two million lines of code for what I bid this job? Because if you can, I'd love to see him try."
Unread postPosted: Wed Oct 21, 2009 7:13 am
eMGee wrote:
With a PCI card cage and three internal SCSI disks in the bays installed by the looks of it, you could run that in [software] RAID5 if you wanted to. :o
IRIX doesn't do software RAID5, and I wouldn't recommend installing Linux on such a nice system :lol:
Unread postPosted: Wed Oct 21, 2009 7:44 am
As embarrassing it is to admit, the movie Jurassic Park lead me down the IRIX path. I am a bit obsessive. I also was really wanting to learn a UNIX system and a bit of graphic editing. I also longed for the command driven days, like back in the 90s.
Everyone on here pointed me toward an Octane. Naturally, I started leaning toward the higher spec ones. Then, SGISTEVE wanted to get rid of all his SGI stuff at a really good price. So, I went for it!
On top of that, I have a local expert who has every part and bit of knowledge I could ever want. Plus, he is only a few blocks away too.
I have since become fascinated with everything Silicon Graphics, and I see many more machines in my future...
