Octane2, single R12K 400MHz, 2GB, V8, 146GB FC
silicium
Unread postby silicium » Sat Sep 19, 2009 10:28 am
hinv -vm
            PM10 Board: barcode KXG819     part 030-1475-002 rev  B
            IP30 Board: barcode LMF714     part 030-1467-001 rev  D
    PWR.SPPLY.ER Board: barcode AAE1480138 part 060-0035-003 rev  A
             FP1 Board: barcode KSV972     part 030-0891-003 rev  G
        XTALKPCI Board: barcode MLF064     part 030-0952-009 rev  A
           ODY32 Board: barcode MES860     part 030-1403-003 rev  B
   FIBRE_CHANNEL Board: barcode EAA538     part 030-0927-003 rev  C
1 400 MHZ IP30 Processor
Heart ASIC: Revision F
Main memory size: 2048 Mbytes
Xbow ASIC: Revision 1.4
Integral SCSI controller 3: Version Fibre Channel AIC-1160, revision 1
  Disk drive: unit 31 on SCSI controller 3 (unit 31)
Integral SCSI controller 4: Version Fibre Channel AIC-1160, revision 1
Graphics board: V6
Gigabit Ethernet: eg0, PCI slot 3, firmware version 12.4.10
  PCI Adapter ID (vendor 0x10a9, device 0x0009) PCI slot 3
  PCI Adapter ID (vendor 0x9004, device 0x1160) PCI slot 0
  PCI Adapter ID (vendor 0x9004, device 0x1160) PCI slot 1
/usr/gfx/gfxinfo
        BUZZ version A.1
        PB&J version 1
        32MB memory
                Banks: 2, CAS latency: 3
         Monitor 0 type: Unknown
System disk:
# Disk Performance Test Results Generated By Diskperf V1.2
# Test name     : SEAGATE ST73307LC
# Test date     : Sat Sep 19 17:15:31 2009
# Test machine  : IRIX64 IRIS 6.5 07202013 IP30
# Test type     : XFS data subvolume
# Test path     : /tmp/test
# Request sizes : min=16384 max=4194304
# Parameters    : direct=1 time=10 scale=1.000 delay=0.000
# XFS file size : 158466048 bytes
      16384   11.12   13.33   20.45   15.74    7.75    3.33
      32768   14.30   14.68   19.81   13.90    9.71    5.31
      65536   14.65   15.79   21.53   15.76    9.42    8.20
     131072   13.80   15.71   19.98   15.11    9.69   11.94
     262144   13.81   14.30   13.83   16.05   10.16   13.46
     524288   15.96   15.31   15.57   14.32   11.43   14.95
    1048576   15.47   15.08   15.32   15.54   13.39   15.37
    2097152   15.48   15.87   14.89   14.89   14.75   14.99
    4194304   16.28   15.83   14.95   15.28   14.84   15.63
Option disk:
# Test name     : IBM-SSG HUS103014FLF21
# Test date     : Sat Sep 19 16:57:54 2009
# Test path     : /mnt/fc0/test
# XFS file size : 44859392 bytes
      16384    2.58   29.43    2.83    2.82    3.53    3.82
      32768    5.11   43.37    5.72    5.84    6.95    6.96
      65536    9.37   59.20   12.52   12.44   12.67   12.14
     131072   16.99   72.59   29.20   29.32   22.20   20.57
     262144   28.41   79.39   29.48   29.35   35.08   30.72
     524288   42.89   85.72   43.72   44.30   48.63   41.51
    1048576   57.00   85.85   58.59   44.42   61.21   53.19
    2097152   68.53   85.47   71.53   52.54   70.35   54.64
    4194304   76.21   83.08   78.58   64.65   77.47   67.46
CD:
scsicontrol -i /dev/scsi/sc1d6l0
/dev/scsi/sc1d6l0:  CD-ROM        PLEXTOR CD-R   PX-W124TS1.06
ANSI vers 2, ISO ver: 0, ECMA ver: 0; supports:  synch linkedcmds
EDIT1 - upgrades: gfx -> V8, SCSI -> QLA12160, input -> Wacom Intuos2 6x8
EDIT2 - power supply fan control stuck in fast mode, removed QLA12160, added/removed/re-added second FC XIO card, installed XFS stripe on two FC dual-channel 146GB disks in PC case recycled as enclosure.
:Indigo2IMP:extreme :Octane2:V8 :O200: :Onyx2:IR2e
indyman007
Re: Octane2, single R12K 400MHz, 2GB, V6, 146GB FC
Unread postby indyman007 » Sat Sep 19, 2009 11:05 am
Looks like a nice setup, I like the FC :).
:Indy: R4600PC 133 MHz
Mac Mini 2.5GHz 8GB RAM
Raspberry Pi
Re: Octane2, single R12K 400MHz, 2GB, V8, 146GB FC
Unread postby vishnu » Fri Dec 25, 2015 9:51 am
silicium wrote:EDIT2 - power supply fan control stuck in fast mode...
I'm sure you know but if you have a card in XIO slot D fastfan is always on regardless of whatever other slots are populated. Some members have conjectured that setting fastfan=0 in your environment prevents that, I have yet to try it but as soon as I get a fourth XIO card in my Octane2 I plan to... ;)
