It is currently Tue May 21, 2013 1:27 pm
Post new topic Reply to topic  [ 6 posts ]
 Post subject: Rackmount Onyx2 [1 of 8]
Unread postPosted: Tue Jul 28, 2009 12:32 am
Code:
# hinv -mv
     IP31PIMM8MB Board: barcode JRX698     part 030-1401-002 rev  B
            IP31 Board: barcode JRP075     part 030-1255-004 rev  A
        MODULEID Board: barcode K0021861   part              rev
            IP31 Board: barcode JRP763     part 030-1255-004 rev  A
      4P1G5_MPLN Board: barcode JHF872     part 030-1066-002 rev  L
     IP31PIMM8MB Board: barcode JRX807     part 030-1401-002 rev  B
          GE16-4 Board: barcode KFZ433     part 030-1398-001 rev  E
             MIO Board: barcode GTR385     part 030-0880-003 rev  G
          BASEIO Board: barcode GSM513     part 030-0734-002 rev  N
4 300 MHZ IP27 Processors
CPU 0 at Module 1/Slot 2/Slice A: 300 Mhz MIPS R12000 Processor Chip (enabled)
  Processor revision: 2.3. Scache: Size 8 MB Speed 200 Mhz  Tap 0xa
CPU 1 at Module 1/Slot 2/Slice B: 300 Mhz MIPS R12000 Processor Chip (enabled)
CPU 2 at Module 1/Slot 1/Slice A: 300 Mhz MIPS R12000 Processor Chip (enabled)
CPU 3 at Module 1/Slot 1/Slice B: 300 Mhz MIPS R12000 Processor Chip (enabled)
Main memory size: 4096 Mbytes
Memory at Module 1/Slot 82: 2048 MB (enabled)
Memory at Module 1/Slot 81: 2048 MB (enabled)
IOC3/IOC4 serial port: tty3
IOC3/IOC4 serial port: tty4
Graphics board: InfiniteReality2E
Iris Audio Processor: version RAD revision 7.0, number 1
  PCI Adapter ID (vendor 0x10a9, device 0x0003) PCI slot 6
  PCI Adapter ID (vendor 0x10a9, device 0x0005) PCI slot 7
IO6prom on Global Master Baseio in Module 1/Slot io2: Revision 6.156
Code:
# /usr/gfx/gfxinfo -v
        Display has 2 channels
        4 GEs (of 4), occmask = 0x0f
        2 RM9 boards (of 2) 1/1/0/0
        Texture Memory: 64MB/64MB/-/-
        Medium pixel depth
        32K cmap
        GVO option detected
        brd: 80f61806 3020c06/3020c06/-/- f9311002
        rm0: 15032057 15431057
              4631057 2/2/2/2
              4d31057 2/2/2/2/2/2/2/2
              4938057 5/5/5/5/5/5/5/5/5/5/5/5/5/5/5/5/5/5/5/5
        rm1: 15032057 15431057
              4631057 2/2/2/2
         dg: 05532057
              5838057 1/1/1/1
              5631057 1/1
        GE:   NIC #:      0000.0047.172e (family: 0b)
              Serial #:   KFZ433
              Part #:     030-1398-001
        KT:   No NIC serial number available.
        RM0:  NIC #:      0000.0034.a8bc (family: 0b)
              Serial #:   JGN030
              Part #:     030-1402-001
        TM0:  NIC #:      0000.0034.4782 (family: 0b)
              Serial #:   JGN148
              Part #:     030-1053-001
        RM1:  NIC #:      0000.0030.7e8f (family: 0b)
              Serial #:   JGE829
        TM1:  NIC #:      0000.002f.f4fa (family: 0b)
              Serial #:   JDN990
        RM2:  No NIC serial number available.
        TM2:  No NIC serial number available.
        RM3:  No NIC serial number available.
        TM3:  No NIC serial number available.
        BP:   No NIC serial number available.
        DG:   NIC #:      0000.0047.230b (family: 0b)
              Serial #:   KCT697
              Part #:     030-1242-001
        DGOPT:NIC #:      0000.0047.2c7d (family: 0b)
              Serial #:   KCT812
              Part #:     030-1184-002
Unread postPosted: Tue Jul 28, 2009 3:06 am
Very nice system! You set up that Onyx2 very fast.
:Octane2: 2xR12000 400MHz, 4GB RAM, V12 GFX
Unread postPosted: Tue Jul 28, 2009 3:21 am
Using the harddrive from my own Onyx2 and Foetz's disk clone script it's rather trivial :D
Unread postPosted: Sun Aug 09, 2009 11:50 pm
That is a VERY sexy piece of hardware! :) Any shots of the back?
-J
No SGI box currently...Snif!
Unread postPosted: Mon Aug 10, 2009 6:14 am
Want to buy one?
There's an exhaust plenum under the Onyx2, but in this photo it's partially obscured by the power strip.
I fitted an intake plenum to this system as well, you can see it here from the front: viewtopic.php?f=3&t=16721463&start=16
Above it you can see the exhaust plenum of the second Onyx2
Unread postPosted: Mon Aug 10, 2009 10:15 am
jan-jaap wrote:
Want to buy one?
:lol: :lol: :lol:
Sorry, I'd have to sell my house...Oh wait! I don't own my house...I rent! Haha!
Seriously, no thank you. I have to buy a MIG welder in the coming months...So many things to do, so little time (and money)
Thanks for the photo. It's a lovely clean machine.
-J
