Onyx 350 IP: V12 2x600 R16k 6GB DM8 SAS/SATA USB
Unread postby recondas » Wed Jun 10, 2009 12:24 pm
A step-by-step photo log of the process to add VPro graphics to an Origin 350 follow the hinv related posts.
hinv -vm
       IP53_2CPU Board: barcode NKW201     part 030-1863-001 rev -D
          ASTODY Board: barcode MLV203     part 030-1726-003 rev -E
       2U_INT_53 Board: barcode NME262     part 030-1809-006 rev -B
             IO9 Board: barcode NLC357     part 030-1771-005 rev -A
2 600 MHZ IP35 Processors
CPU 0 at Module 001c01/Slot 0/Slice A: 600 Mhz MIPS R16000 Processor Chip (enabled)
  Processor revision: 2.1. Scache: Size 4 MB Speed 300 Mhz  Tap 0xc
CPU 1 at Module 001c01/Slot 0/Slice C: 600 Mhz MIPS R16000 Processor Chip (enabled)
Main memory size: 6144 Mbytes
Memory at Module 001c01/Slot 0: 6144 MB (enabled)
  Bank 4 contains 512 MB (Premium) DIMMS (enabled)
  Bank 5 contains 512 MB (Premium) DIMMS (enabled)
  Bank 6 contains 512 MB (Premium) DIMMS (enabled)
  Bank 7 contains 512 MB (Premium) DIMMS (enabled)
Integral SCSI controller 3: Version SAS/SATA LS1068
IOC3/IOC4 serial port: tty3
IOC3/IOC4 serial port: tty4
IOC3/IOC4 serial port: tty5
IOC3/IOC4 serial port: tty6
Graphics board: V12
  PCI Adapter ID (vendor 0x1000, device 0x0054) PCI slot 2
  PCI Adapter ID (vendor 0x1412, device 0x1724) PCI slot 1
  PCI Adapter ID (vendor 0x1033, device 0x0035) PCI slot 2
  PCI Adapter ID (vendor 0x1033, device 0x00e0) PCI slot 2
IOC4 firmware revision 83
USB controller: type OHCI
Graphics via a Fuel V12 inserted in the O350's XIO slot.
/usr/gfx/gfxinfo -v
        BUZZ version B.1
        PB&J version 1
        128MB memory
                Banks: 4, CAS latency: 3
         Monitor 0 type: NEC 26089
         Video Format Flags:  (none)
         Sync Disabled
         Using Gamma Map 0
 scsicontrol -i /dev/scsi/sc*
/dev/scsi/sc0d1l0:  Disk          SEAGATE ST336753LC      0005
Device is  ready
/dev/scsi/sc0d2l0:  Disk          SEAGATE ST336753LC      0005
Device is  ready
/dev/scsi/sc2d0l0:  CD-ROM        MATSHITADVD-ROM SR-8178 PZ21
ANSI vers 0, ISO ver: 0, ECMA ver: 0; supports:
Device is  not ready
As bri3d noticed, the insertion of graphics changed the L1 brick identity from Chimera Server to Chimera Blade:
ack: 001, slot: 01, partition: none, type: Chimera Blade [2MB flash], serial:NME262, source: EEPROM
L1 Controller Environmental monitoring with V12 installed and several hours run time.
l1cmd env
          1.8V    Enabled  10%   1.62/  1.98  20%   1.44/  2.16    1.777
           12V <not present>
        12V #2    Enabled  10%  10.80/ 13.20  20%   9.60/ 14.40   12.000
          3.3V    Enabled  10%   2.97/  3.63  20%   2.64/  3.96    3.320
        12V IO    Enabled  10%  10.80/ 13.20  20%   9.60/ 14.40   12.000
        5V AUX    Enabled  10%   4.50/  5.50  20%   4.00/  6.00    5.044
      3.3V AUX    Enabled  10%   2.97/  3.63  20%   2.64/  3.96    3.268
    PCI 5V AUX    Enabled  10%   4.50/  5.50  20%   4.00/  6.00    5.044
      PCI 3.3V    Enabled  10%   2.97/  3.63  20%   2.64/  3.96    3.302
      PCI 2.5V    Enabled  10%   2.25/  2.75  20%   2.00/  3.00    2.496
        PCI 5V    Enabled  10%   4.50/  5.50  20%   4.00/  6.00    4.940
  XIO 12V BIAS    Enabled  10%  10.80/ 13.20  20%   9.60/ 14.40   12.000
        XIO 5V    Enabled  10%   4.50/  5.50  20%   4.00/  6.00    4.940
      XIO 2.5V    Enabled  10%   2.25/  2.75  20%   2.00/  3.00    2.457
  XIO 3.3V AUX    Enabled  10%   2.97/  3.63  20%   2.64/  3.96    3.285
 IP53 3.3V AUX    Enabled  10%   2.97/  3.63  20%   2.64/  3.96    3.251
   IP53 5V AUX    Enabled  10%   4.50/  5.50  20%   4.00/  6.00    5.044
      IP53 12V    Enabled  10%  10.80/ 13.20  20%   9.60/ 14.40   12.000
     IP53 VCPU    Enabled  10%   1.13/  1.38  20%   1.00/  1.50    1.269
     IP53 SRAM    Enabled  10%   2.25/  2.75  20%   2.00/  3.00    2.483
     IP53 1.5V    Enabled  10%   1.35/  1.65  20%   1.20/  1.80    1.480
FAN  0  EXHST 1    Enabled         1980         2177
FAN  1       PS    Enabled         3200         4066
FAN  2    PCI 1    Enabled         1980         2343
FAN  3    PCI 2    Enabled         1980         2576
FAN  4      ODY    Enabled         1679         4272
 0 INTERFACE 0       Enabled    [Autofan Control]    75C/167F   44C/111F
 1 INTERFACE 1       Enabled    [Autofan Control]    75C/167F   43C/109F
 2 INTERFACE 2       Enabled    [Autofan Control]    75C/167F   35C/ 95F
 3 PCI RISER         Enabled    [Autofan Control]    75C/167F   34C/ 93F
 4 ODYSSEY           Enabled    [Autofan Control]    75C/167F   35C/ 95F
 5 NODE              Enabled    [Autofan Control]    75C/167F   33C/ 91F
 6 BEDROCK           Enabled    [Autofan Control]    75C/167F   48C/118F
                     Zone Temp     Target    Current   Zone Fan   Curr/Min
Zone Name  State     Sensors       Average   Average   Index      Fan %
NODE        Enabled     0,1,2,5,6  47C/116F  40C/104F          0   18%/ 18%
PS          Enabled     0,1,2,5,6  47C/116F  40C/104F          1   55%/ 55%
PCI         Enabled             3  45C/113F  34C/ 93F        2,3   55%/ 55%
ODY         Enabled             4  48C/118F  35C/ 95F          4   55%/ 55%
L1 "serial all" command:
l1cmd serial all
Local System Serial Number      NVRAM         M2008383
Reference System Serial Number  NVRAM         M2008383
Local Brick Serial Number       EEPROM        NME262
Reference Brick Serial Number   NVRAM         NME262
INTERFACE   2U_INT_53       NNX272         030_1809_006          B    00
IO9         IO9             NLC357         030_1771_005          A    00
ODYSSEY     ASTODY          MLV203         030_1726_003          E    00
RISER       2U_RISER        NND054         030_1808_006          B    00
NODE        IP53_2CPU       NKW201         030_1863_001          D    00
PS 1        no hardware detected
PS 2        DPS-500EBE      XPD0451009596  060-0178-003          S4
DIMM 0     CE000000000000000C6F6F00 M3 46L2820BT2-CA0   2B   10.0  N/A
DIMM 2     CE000000000000000C576F00 M3 46L2820BT2-CA0   2B   10.0  N/A
DIMM 4     CE000000000000000CEF8300 M3 46L6423DT3-CA0   3D   10.0  N/A
DIMM 6     CE000000000000000CC18400 M3 46L6423DT3-CA0   3D   10.0  N/A
DIMM 1     CE000000000000000CBD6F00 M3 46L2820BT2-CA0   2B   10.0  N/A
DIMM 3     CE000000000000000C786F00 M3 46L2820BT2-CA0   2B   10.0  N/A
DIMM 5     CE000000000000000C0E8400 M3 46L6423DT3-CA0   3D   10.0  N/A
DIMM 7     CE000000000000000CF48300 M3 46L6423DT3-CA0   3D   10.0  N/A
The conversion from Origin 350 to Onyx 350 took less than two hours, including trimming the V12 bulkhead and heatsink.
Unmodified Origin 350 - a Fuel VPro graphics board will replace the lower exhaust fan.
Both exhaust fans and support bracket removed. Required removal of only 8 screws, 3 in each fan and 2 for the support bracket (one of the support bracket screws is accessed from the exterior).
Fuel VPro Graphics board - the bulkhead and heatsink have been trimmed to fit the Origin 350.
There is an opening on the rear of the case just below the position of the installed graphics board. The opening has a cover plate on headless Origin 350s. The cover can be removed and a radial fan installed internally to provide extra cooling.
The openings seen in the graphics board bulkhead should be sealed so the fans will draw cool air through the nodeboard shroud and across the graphics board heatsink, rather than through the opens in the graphics board bulkhead and right back out via the fans.
70mm radial fan (this one is rated at 14.7CFM). The 70mm fan is a tight fit between the PCI riser and the IO9 daughter card. The fan is positioned to exhaust air through an exhaust grill (the grill has a removable cover plate). This photo was taken during a 'test' fit; before final installation a gasket was added to seal the gap between the fan and the case.
This particular fan was used because it was what the local computer parts place had in stock that was the right size. It's a Dynatron 70mm Radial fan, most commonly used on low-profile CPU coolers (for 1U servers). It might be possible to fit larger radial fan if the exhaust ducting is arranged to place the body of the fan behind the IO9 daughter board (seen in the right foreground of the photo).
Three-pin header for graphics fan. To avoid L1 "Fan Error" messages, a 3-pin fan that proves fan speed information must be used. The header uses a non-standard pinout: Pin 1 - 12VDC; Pin 2 - Tach; Pin 3 - Ground. NOTE: A 4-pin PWM fan may also be used; the O350 fan header and the PWM fan socket are keyed to allow connection of only the 3 necessary fan wires (although the 12VDC, tach and ground wires should be configured to match the SGI pinout).
Upper exhaust fan replaced (without bracket) and a VPro graphics board installed in place of lower fan (the heatsink and bulkhead on the graphics board must be trimmed to allow installation). The large square metal object visible in the graphics board is the backing plate/attachment mechanism for the VPro heatsink. There is a threaded hole in the center of this assembly that will align with an opening in the lid of the O350 - inserting a screw through the O350 lid into the threaded hole will provide support to the graphics board.
The 'rail' (marked in the photo by the lower arrow), retained from the original Fuel mounting hardware, is a nearly perfect fit above the node board cooling shroud and provides additional support to the VPro graphics board (about an inch was trimmed from the left end of the rail). The VPro board is also supported by a screw that goes through a pre-existing opening in the lid of the O350 case into a threaded boss on the VPro (marked in the photo by the upper arrow).
PROM boot screen after installation of a VPro graphics board from a Fuel (the monitor is a 1600SW).
Unused Origin 350 exhaust fan and bracket; and sections trimmed from the graphics board bulkhead / heatsink.
bplaa.yai
Re: Onyx350: 2x600-6GB-V10-USB
Unread postby bplaa.yai » Wed Jun 10, 2009 1:02 pm
Haha, welcome to the club ;)
I like the way you cut the V10 heatsink to let the cover over the CPUs/bedrock but then where do you intend to install the extra cooling ?
Anyway, nice to see you got yours :)
:Onyx2: :O2: :O3x0: :O3x0:
Unread postby recondas » Wed Jun 10, 2009 1:18 pm
bplaa.yai wrote:Haha, welcome to the club ;)
Thanks - you guys made it easy.
bplaa.yai wrote:I like the way you cut the V10 heatsink to let the cover over the CPUs/bedrock
I had taken the heatsink off while working on the INV_ODSY_MEMCFG_512 thread and got noticed that it probably wouldn't take much to cut it. Once I had the O350 to measure from it was a 10 minute job with a carbide-tipped power saw.
bplaa.yai wrote:where do you intend to install the extra cooling ?
It's installed - check the fan listing in the L1 'env'. I installed a 70mm PWM fan into what I thought might have been intended as the graphics fan exhaust slot. I plugged the new fan's 4-pin connector into the 3-pin "fan 4" header. Also covered up all of the vents through the V10 bulkhead and gasketed the fan where it attaches to the O350 case <so the fan wasn't sucking air in through the path of least resistance and right back out again>. With a couple hours of run time the Bedrock has held steady at 48c <tho I plan to do a little stress testing this afternoon>.
bplaa.yai wrote:Anyway, nice to see you got yours :)
Thanks!
Unread postby foetz » Wed Jun 10, 2009 5:17 pm
good job :D
i need to get an origin350, too :mrgreen:
bri3d
Re: Onyx350: 2x600 R16k 6GB V10 USB
Unread postby bri3d » Wed Jun 10, 2009 8:30 pm
Welcome to the club! - I might be trying some of your cooling ideas later on :)
Unread postby nekonoko » Wed Jun 10, 2009 8:36 pm
Very nice! I may wind up doing this in my second O350 node (the one without the IO9). Does anyone know the difference between a Tezro rack and a "modded" Onyx 350 InfinitePerformance? They smell the same to me :)
Geoman
Unread postby Geoman » Thu Jun 11, 2009 1:35 am
Nice work! and because your machine has this temperature monitoring, you can alway check if everything is ok.
Octane doesnt :-((
Unread postby jan-jaap » Thu Jun 11, 2009 4:24 am
Nice box :)
recondas wrote:
I wonder what's the difference between a 600MHz R14k and a 600MHz R16k?
Unread postby hamei » Thu Jun 11, 2009 4:37 am
jan-jaap wrote:Nice box :)
Last time I said that I got slapped :(
recondas wrote:
Maybe it needs to be flashed ?
Unread postby recondas » Thu Jun 11, 2009 5:22 am
Thanks to all for the kind words!
nekonoko wrote:Does anyone know the difference between a Tezro rack and a "modded" Onyx 350 InfinitePerformance? They smell the same to me :)
The illustrations and text in the respective owner's guides make the them appear more similar than not. Interestingly, SGI avoids *any* mention in the Tezro rack user's guide of the external XIO port <and by proxy, the Router brick and other XIO connected expansion bricks> - perhaps to give some "marketing distance" between the rack Tezro and what was probably the relatively more expensive Onyx Infinite Performance?
There are probably some differences in the PROM <I say probably, but I'm sure *someone* here has the skills required to look> to produce the differing PROM splash screens and the machine type info seen by inst:
CPUARCH=R10000
IP35
CPUBOARD=IP35
MODE=64bit
SUBGR=IP35
GFXBOARD=ODYSSEY
MACHINE=Onyx3 InfinitePerformance, Fuel
Geoman wrote:your machine has this temperature monitoring, you can alway check if everything is ok.
The monitoring system is pretty nice. The L1 environmental monitoring lists "Target Average" and "Current Average" temperatures for a number of key components <and even which "Zones" are monitored>. The system can automatically adjust the fan speeds for temperature increases/decreases; will increase fan speeds if one fan fails, and shut the system down if two fail or any of the monitored zones exceeds the listed 'fault temp'. If there are any problems with system fans or temperatures, the "Service Required" LED on the front panel will activate and the L1 display will scroll the appropriate error or fault message.
bri3d
Unread postby bri3d » Thu Jun 11, 2009 10:56 am
Someone needs to get a V12 in one of these - I think that might be part of how the PROM and software recognizes the difference - I know, for one, that Discreet licensing recognizes my system as a "fuelv10"
Gerhard Lenerz's SGIStuff table lists Onyx350, Onyx4 (this was the UltimateVision configuration), Tezro, and Origin350 as having the exact same IP numbers - I'm guessing the recognition is just based on the graphics option, since it seems to be the only solid difference between them.
Re: Onyx 350: 2x600 R16k 6GB V10 DM8 SAS/SATA USB
Unread postby recondas » Thu Jun 11, 2009 2:34 pm
Added an mAudio Revolution 7.1 <the OEM for the SGI DMediaPro DM8 PCI Audio Option> and an LSI SAS3442X PCI-X SAS/SATA HBA. There's currently a SATA DVD-RW hanging off the SAS3442X; wanted to re-try the SATA DVD-RW with a clean install.
Unread postby nekonoko » Thu Jun 11, 2009 4:34 pm
bri3d wrote:Someone needs to get a V12 in one of these - I think that might be part of how the PROM and software recognizes the difference - I know, for one, that Discreet licensing recognizes my system as a "fuelv10"
That's probably the key - Tezro never shipped with a V10 so it makes sense in that respect.
recondas wrote: There's currently a SATA DVD-RW hanging off the SAS3442X; wanted to re-try the SATA DVD-RW with a clean install.
I'm sure you're well aware, but you do have native IDE should a SATA DVD-RW not work out :)
Unread postby recondas » Thu Jun 11, 2009 4:59 pm
nekonoko wrote:I'm sure you're well aware, but you do have native IDE should a SATA DVD-RW not work out :)
Yeah - I was throwin' a Hail Mary for hamei..... <but it looks like Staubach stayed on the bench for this one>.
bri3d
Unread postby bri3d » Thu Jun 11, 2009 5:00 pm
The Tezro was codenamed Chimera, and so is the O350 (according to PROM settings).
In addition, there's a PROM flag to switch between a "ChiBlade" and a "Rackmounted Workstation" (which seems to have no effect on my system - I've tried both settings and they stick but don't seem to do anything) - so I think we've got it.
Now someone just needs to grab a V12 and try it!
