Origin 3400, 20 x R12k @ 400 MHz, 21 GB
japes
Unread postby japes » Mon Apr 06, 2009 2:26 pm
Five C-bricks, one D-brick with 10 x 72gb drives (need to determine which one is bad still).
# hinv -vm
            IP35 Board: barcode LPV717     part 030-1604-006 rev -B
        IP35PIMM Board: barcode LBV414     part 030-1616-002 rev -G
        IP35PIMM Board: barcode LPP596     part 030-1616-002 rev -G
          IBRICK Board: barcode MAK285     part 030-1557-007 rev -D
            IP35 Board: barcode LPJ333     part 030-1604-006 rev -B
        IP35PIMM Board: barcode LPJ666     part 030-1616-002 rev -G
        IP35PIMM Board: barcode LPP708     part 030-1616-002 rev -G
            IP35 Board: barcode LPV513     part 030-1604-006 rev -B
        IP35PIMM Board: barcode LPP511     part 030-1616-002 rev -G
        IP35PIMM Board: barcode LZA529     part 030-1616-002 rev -H
            IP35 Board: barcode LPJ508     part 030-1604-006 rev -B
        IP35PIMM Board: barcode LPP547     part 030-1616-002 rev -G
        IP35PIMM Board: barcode LYZ192     part 030-1616-002 rev -H
            IP35 Board: barcode MGY537     part 030-1604-006 rev -B
        IP35PIMM Board: barcode KSB937     part 030-1616-002 rev -G
        IP35PIMM Board: barcode LBP054     part 030-1616-002 rev -G
          ROUTER Board: barcode LGT876     part 030-1634-002 rev -B
          ROUTER Board: barcode MAT906     part 030-1634-002 rev -B
20 400 MHZ IP35 Processors
FPU: MIPS R12010 Floating Point Chip Revision: 3.5
CPU 0 at Module 001c07/Slot 0/Slice A: 400 Mhz MIPS R12000 Processor Chip (enabled)
  Processor revision: 3.5. Scache: Size 8 MB Speed 266 Mhz  Tap 0xa
CPU 1 at Module 001c07/Slot 0/Slice B: 400 Mhz MIPS R12000 Processor Chip (enabled)
CPU 2 at Module 001c07/Slot 0/Slice C: 400 Mhz MIPS R12000 Processor Chip (enabled)
CPU 3 at Module 001c07/Slot 0/Slice D: 400 Mhz MIPS R12000 Processor Chip (enabled)
CPU 4 at Module 001c10/Slot 0/Slice A: 400 Mhz MIPS R12000 Processor Chip (enabled)
CPU 5 at Module 001c10/Slot 0/Slice B: 400 Mhz MIPS R12000 Processor Chip (enabled)
CPU 6 at Module 001c10/Slot 0/Slice C: 400 Mhz MIPS R12000 Processor Chip (enabled)
CPU 7 at Module 001c10/Slot 0/Slice D: 400 Mhz MIPS R12000 Processor Chip (enabled)
CPU 8 at Module 001c13/Slot 0/Slice A: 400 Mhz MIPS R12000 Processor Chip (enabled)
CPU 9 at Module 001c13/Slot 0/Slice B: 400 Mhz MIPS R12000 Processor Chip (enabled)
CPU 10 at Module 001c13/Slot 0/Slice C: 400 Mhz MIPS R12000 Processor Chip (enabled)
CPU 11 at Module 001c13/Slot 0/Slice D: 400 Mhz MIPS R12000 Processor Chip (enabled)
CPU 12 at Module 001c16/Slot 0/Slice A: 400 Mhz MIPS R12000 Processor Chip (enabled)
CPU 13 at Module 001c16/Slot 0/Slice B: 400 Mhz MIPS R12000 Processor Chip (enabled)
CPU 14 at Module 001c16/Slot 0/Slice C: 400 Mhz MIPS R12000 Processor Chip (enabled)
CPU 15 at Module 001c16/Slot 0/Slice D: 400 Mhz MIPS R12000 Processor Chip (enabled)
CPU 16 at Module 001c27/Slot 0/Slice A: 400 Mhz MIPS R12000 Processor Chip (enabled)
CPU 17 at Module 001c27/Slot 0/Slice B: 400 Mhz MIPS R12000 Processor Chip (enabled)
CPU 18 at Module 001c27/Slot 0/Slice C: 400 Mhz MIPS R12000 Processor Chip (enabled)
CPU 19 at Module 001c27/Slot 0/Slice D: 400 Mhz MIPS R12000 Processor Chip (enabled)
Main memory size: 21504 Mbytes
Memory at Module 001c07/Slot 0: 5120 MB (enabled)
  Bank 2 contains 512 MB (Premium) DIMMS (enabled)
  Bank 3 contains 512 MB (Premium) DIMMS (enabled)
  Bank 4 contains 512 MB (Premium) DIMMS (enabled)
  Bank 5 contains 512 MB (Premium) DIMMS (enabled)
  Bank 6 contains 512 MB (Premium) DIMMS (enabled)
  Bank 7 contains 512 MB (Premium) DIMMS (enabled)
Memory at Module 001c10/Slot 0: 4096 MB (enabled)
  Bank 7 contains 512 MB (Standard) DIMMS (enabled)
Memory at Module 001c13/Slot 0: 4096 MB (enabled)
Memory at Module 001c16/Slot 0: 4096 MB (enabled)
Memory at Module 001c27/Slot 0: 4096 MB (enabled)
ROUTER in Module 001c07/Slot 0: Revision 1: Active Ports [1,2,3,4,5,6,] (enabled)
ROUTER in Module 001c27/Slot 0: Revision 1: Active Ports [1,4,6,] (enabled)
Integral SCSI controller 0: Version Fibre Channel QL2200A, 33 MHz PCI
  Disk drive: unit 5 on SCSI controller 0 (unit 5)
  Disk drive: unit 6 on SCSI controller 0 (unit 6)
  Disk drive: unit 7 on SCSI controller 0 (unit 7)
  Disk drive: unit 8 on SCSI controller 0 (unit 8)
  Disk drive: unit 9 on SCSI controller 0 (unit 9)
  Disk drive: unit 10 on SCSI controller 0 (unit 10)
  Disk drive: unit 13 on SCSI controller 0 (unit 13)
Integral SCSI controller 5: Version IEEE1394 SBP2
  IEEE1394 CDROM: node 1010031001b79a port 0 on SCSI controller 5
IOC3/IOC4 serial port: tty3
Integral Fast Ethernet: ef0, version 1, module 001c07, pci 4
  PCI Adapter ID (vendor 0x1077, device 0x2200) PCI slot 1
  PCI Adapter ID (vendor 0x104c, device 0x8009) PCI slot 6
HUB in Module 001c07/Slot 0: Revision 2 Speed 200.00 Mhz (enabled)
HUB in Module 001c10/Slot 0: Revision 2 Speed 200.00 Mhz (enabled)
HUB in Module 001c13/Slot 0: Revision 2 Speed 200.00 Mhz (enabled)
HUB in Module 001c16/Slot 0: Revision 2 Speed 200.00 Mhz (enabled)
HUB in Module 001c27/Slot 0: Revision 2 Speed 200.00 Mhz (enabled)
IP35prom in Module 001c07/Slot n0: Revision 6.210
IP35prom in Module 001c10/Slot n0: Revision 6.210
IP35prom in Module 001c13/Slot n0: Revision 6.210
IP35prom in Module 001c16/Slot n0: Revision 6.210
IP35prom in Module 001c27/Slot n0: Revision 6.210
IEEE 1394 High performance serial bus controller 0: Type: OHCI, Version 0 0
USB controller: type OHCI
13-may-2009 Edit: Updated, now running 20 cpus, was 18.
:O3000: :Fuel: :Tezro: :Tezro: :Octane2: :Octane2: :Octane2: :Octane: :Octane: :Octane: :Indigo: :Indigo: :Indigo: :Indigo: :O2: :1600SW: :O2: :1600SW: :1600SW: :Indigo2: :Indigo2: :Indigo2: :Indigo2: :Indigo2IMP: :Indy: :Indy: :Indy: :Indy: :O3x0: :O3x02L: :O3x02L:
Re: Origin 3400, 18 x R12k @ 400 MHz, 21 GB
Unread postby hamei » Tue Apr 07, 2009 12:09 am
japes wrote:Still waiting on getting a replacement PIMM, but it's all loaded up with memory.
Pretty nice ! What's the deal with the standard and premium memory tho ? In the past it looked like all the 1 gig sticks were premium while the smaller dimms were standard, but you have 512 meg dimms that show up both ways ... ??
japes
Unread postby japes » Tue Apr 07, 2009 12:38 am
hamei wrote:What's the deal with the standard and premium memory tho ? In the past it looked like all the 1 gig sticks were premium while the smaller dimms were standard, but you have 512 meg dimms that show up both ways ... ??
512 MB dimms are available as either premium or standard. They have one more chip on the dimm. So if you were going to have a large (cpu count) system, but didn't need the memory you could opt for the premium 512 modules. The 256 MB dimms were only standard.
Here's a link to the Origin 3k manual, specifically the section on memory in the C-brick chapter: http://techpubs.sgi.com/library/tpl/cgi-bin/getdoc.cgi/hdwr/bks/SGI_EndUser/books/Origin_3K_OG/sgi_html/ch04.html#LE78208-PARENT
