O2 - R10k 195 MHz, 128MB, 1600SW
japes
Unread postby japes » Thu Feb 19, 2009 12:29 am
Posting from my little O2. Got my 1600SW card installed and connected up. Wow! Just wow!
Best money I've spent on any SGI graphics thing so far. I'm impressed with the scrolling and general behavior with this. I think I might need some software to control the monitor (no CD included, my board was a used pull).
# hinv -vm
1 195 MHZ IP32 Processor
Main memory size: 128 Mbytes
FLASH PROM version 4.18
On-board serial ports: tty1
On-board serial ports: tty2
CRM graphics installed
Video: MVP unit 0 version 1.4
 with no AV Card or Camera.
Vice: TRE
1600SW Flat Panel adapter board and display.
# /usr/gfx/gfxinfo
        Managed (":0.0") 1600x1024
        32 bitplanes
        Timing table flags:
         Monitor 0 type: Unknown
         Video Output: 1600 pixels, 1024 lines, 60.00Hz (1600x1024_60p)
japes
Re: O2 - R10k 195 MHz, 128MB, 1600SW
Unread postby japes » Thu Feb 19, 2009 1:10 am
Photo, also shows my new workspace for the hobby computers. Nine feet of countertop, and it's already a disaster zone. Do not give me any flat surface if don't want it covered in stuffs. A few projects on either side too.
indyman007
Unread postby indyman007 » Fri Feb 20, 2009 2:53 am
I like the make shift indigo 2 door!
Also looks like a wide screen monitor.
:Indy: R4600PC 133 MHz
Mac Mini 2.5GHz 8GB RAM
Raspberry Pi
japes
Unread postby japes » Fri Feb 20, 2009 9:30 am
The Indigo2s came along with an Indigo from craigslist. I'm probably going to clean up the one with the purple door and then find it a new home. The other is in quite nice shape, I have some upgrades for it and then it will be my green i2 example.
Yes, the 1600SW has a resolution of 1600x1024 in about 17-18 inches. While it's slow and has a narrow viewing angle these days, it still has one of the highest DPIs on LCDs.
indyman007
Unread postby indyman007 » Fri Feb 20, 2009 9:33 am
Damn cats always getting in the way!
On the far right!
Raspberry Pi
Arabski
Unread postby Arabski » Fri Feb 20, 2009 10:19 am
indyman007 wrote:Damn cats always getting in the way!
On the far right!
He hunts the mouse! Can't you see? :D
Image * Image
japes
Unread postby japes » Fri Feb 20, 2009 11:24 am
Arabski wrote:He hunts the mouse! Can't you see? :D
It does appear that way doesn't it. He jumped on the counter and I thought it'd be nice if he made an appearance in the photo. This is the best I could get from him. There were so many more interesting things to sniff.
Dr. Dave
Unread postby Dr. Dave » Fri Feb 20, 2009 8:45 pm
LOLcats: "Kompooter Kat is watchin ur micez"
indyman007
Unread postby indyman007 » Sat Feb 21, 2009 1:19 am
Just out of interest what is to the right? (Apart from the cat)
Raspberry Pi
japes
Unread postby japes » Sat Feb 21, 2009 1:52 pm
indyman007 wrote:Just out of interest what is to the right? (Apart from the cat)
Nothing too special. IBM PS/2 Model 56slc. An IBM made 386/sx that isn't quite as bad as a regular Intel 386/sx. I'd actually like it gone...including the clicky Model M keyboard and old monitor.
indyman007
Unread postby indyman007 » Sat Feb 21, 2009 2:05 pm
Any news about the origin 3400? Are you going to post pictures?
Raspberry Pi
karbonKid
Unread postby karbonKid » Sun Feb 22, 2009 4:07 pm
Wha?!! You want to get rid of a Model M???
japes
Unread postby japes » Sun Feb 22, 2009 5:37 pm
karbonKid wrote:Wha?!! You want to get rid of a Model M???
Yes, because I'm not a huge Model M fan, it doesn't have the "Windows" key which makes it useless for my Mac, and nearly useless for a Windows computer. The market for them seems to have taken a dip on ebay. If bundling the setup gets someone to come and take the whole set from me on craigslist, well then I don't have to load it up and take it to the recyclers.
Meanwhile I'll continue to load up NIBBLES.BAS and play on it.
