It is currently Fri Sep 03, 2010 2:17 am
Post new topic Reply to topic  [ 4 posts ]
 Post subject: Fuel R14k 600mhz 2048MB V12
PostPosted: Sat Jan 10, 2009 5:26 pm
A special thanks to Zerolapse for giving me a great deal on this system. My highest powered SGI before this was an O2 R10k 195mhz and an Indigo 2 R10k w/ High Impact. This is a HUGE improvement in terms of performance. I love this machine :D
hinv -vm
Code:
            IP34 Board: barcode MNV385     part 030-1707-003 rev -H
        IP34PIMM Board: barcode NCN997     part 030-1730-002 rev -E
          ASTODY Board: barcode NAT871     part 030-1726-005 rev -A
1 600 MHZ IP35 Processor
Main memory size: 2048 Mbytes
Graphics board: V12
IP35prom in Module 001c01/Slot n0: Revision 6.211
USB controller: type OHCI
gfxinfo:
Code:
   Managed (":0.0") 1600x1024
   BUZZ version B.2
   PB&J version 1
   128MB memory
      Banks: 4, CAS latency: 3
    Monitor 0 type: Unknown
    Video Output: 1600 pixels, 1024 lines, 82.98Hz (1600x1024_83)
- Jim
 Post subject: Re: Fuel R14k 600mhz 2048MB V12
PostPosted: Wed Jan 14, 2009 9:10 am
Congratulations for the deal, very nice system there! :)
That's something rather Fuel-specific (with support for it out-of-the-box), but how is the USB under IRIX? Have you tried it out yet? How many USB ports are there? (Two, right?)
:Tezro: :Indigo2: :rx2600:
PostPosted: Wed Jan 14, 2009 9:23 am
directedition wrote:
Code:
Hmmm, 83Hz? On a 1600SW or something else?
Awful :lol:
Currently in commercial service: Image :Octane2: :Onyx2:(2x) :0300:
PostPosted: Wed Jan 14, 2009 9:51 am
My 1600SW is just THAT awesome :)
But really, it's driving my FW900 at 1920x1080@72hz right now. I was planning on putting my 1600SW adapter in, but decided against it.
- Jim
