O2 200mhz/1GB - Saiph
Unread postby mgtremaine » Mon Sep 01, 2008 3:54 pm
This showed up last Easter for my Son [it's blue and almost Egg shaped]. :P Sure he's 7 years old but they have to start young right. I was surprised how much more snappy the O2 200/1GB is compared to my Indy 180/256MB.
CPU: MIPS R5000 Processor Chip Revision: 2.1
FPU: MIPS R5000 Floating Point Coprocessor Revision: 1.0
1 200 MHZ IP32 Processor
Main memory size: 1024 Mbytes
FLASH PROM version 4.18
On-board serial ports: tty1
On-board serial ports: tty2
CRM graphics installed
Video: MVP unit 0 version 1.4
Vice: TRE
        32 bitplanes
         Monitor 0 type: Unknown
         Video Output: 1280 pixels, 1024 lines, 59.94Hz (1280x1024_60)
Re: O2 200mhz/1GB - Saiph
Unread postby un_ » Mon Sep 01, 2008 9:21 pm
I wish my dad had been that cool :) I remember him proudly telling us about it when we picked up the nextstation from you!
