It is currently Fri Sep 03, 2010 2:17 am
Post new topic Reply to topic  [ 53 posts ]  Go to page 1, 2, 3, 4  Next
 Post subject: Onyx 300 IR3: 16x600MHz 10GB 4xRM10 DG5-2/TVO
PostPosted: Mon May 19, 2008 9:57 am
EDIT: An updated hinv is on page 4.
Code:
fyrestorm 1% hinv -vm
       IP45_4CPU Board: barcode MMB342     part 030-1797-001 rev -B
          KTOWN2 Board: barcode LZP881     part 030-1593-001 rev  G
          GE16-4 Board: barcode GMX327     part 030-1398-001 rev  A
             IO8 Board: barcode MLZ524     part 030-1673-003 rev -G
4 600 MHZ IP35 Processors
CPU 1 at Module 001c01/Slot 0/Slice B: 600 Mhz MIPS R14000 Processor Chip (enabled)
CPU 2 at Module 001c01/Slot 0/Slice C: 600 Mhz MIPS R14000 Processor Chip (enabled)
CPU 3 at Module 001c01/Slot 0/Slice D: 600 Mhz MIPS R14000 Processor Chip (enabled)
Main memory size: 2048 Mbytes
Integral SCSI controller 3: Version SAS/SATA LS1068
  Tape drive: unit 6 on SCSI controller 1: DAT
IOC3/IOC4 serial port: tty3
IOC3/IOC4 serial port: tty4
Graphics board: InfiniteReality2E
Gigabit Ethernet: tg1, module 001c01, PCI bus 2 slot 2
Iris Audio Processor: USB audio revision 1.0, number 0
  PCI Adapter ID (vendor 0x1000, device 0x0054) PCI slot 1
  PCI Adapter ID (vendor 0x14e4, device 0x1645) PCI slot 2
IP35prom in Module 001c01/Slot n0: Revision 6.211
USB controller: type OHCI
Code:
2% /usr/gfx/gfxinfo -v
Graphics board 0 is "KONAD" graphics.
        Display has 2 channels
        4 GEs (of 4), occmask = 0x0f
        4 RM9 boards (of 4) 1/1/1/1
        Texture Memory: 64MB/64MB/64MB/64MB
        Extra-Large pixel depth
        32K cmap
        DPLEX option detected
        brd: 80f61806 3020c06/3020c06/3020c06/3020c06 f9211002
        rm0: 15032057 15431057
              4631057 2/2/2/2
              4d31057 2/2/2/2/2/2/2/2
              4938057 5/5/5/5/5/5/5/5/5/5/5/5/5/5/5/5/5/5/5/5
        rm1: 15032057 15431057
              4631057 2/2/2/2
        rm2: 15032057 15431057
              4631057 2/2/2/2
        rm3: 15032057 15431057
              4631057 2/2/2/2
         dg: 05532057
              5838057 1/1/1/1
              5631057 1/1
        GE:   NIC #:      0000.002a.e59b (family: 0b)
              Serial #:   GMX327
              Part #:     030-1398-001
        KT:   NIC #:      0000.003f.d1c6 (family: 0b)
              Serial #:   LZP881
              Part #:     030-1593-001
        RM0:  NIC #:      0000.002e.7841 (family: 0b)
              Serial #:   GCA321
              Part #:     030-1402-001
        TM0:  NIC #:      0000.001e.af8b (family: 0b)
              Serial #:   DEM892
              Part #:     030-1053-001
        RM1:  NIC #:      0000.002e.794d (family: 0b)
              Serial #:   GCA323
        TM1:  NIC #:      0000.002e.687f (family: 0b)
              Serial #:   GCA060
        RM2:  NIC #:      0000.002e.4c37 (family: 0b)
              Serial #:   GCA342
        TM2:  NIC #:      0000.002e.7730 (family: 0b)
              Serial #:   GBZ682
        RM3:  NIC #:      0000.002e.48e8 (family: 0b)
              Serial #:   GCC332
        TM3:  NIC #:      0000.0024.0094 (family: 0b)
              Serial #:   DGN848
        BP:   No NIC serial number available.
        DG:   NIC #:      0000.0037.6cf2 (family: 0b)
              Serial #:   HKA950
              Part #:     030-1242-001
        DGOPT:NIC #:      0000.0037.69b1 (family: 0b)
              Serial #:   HKA905
              Part #:     030-1409-001
         Video Output: 1280 pixels, 1024 lines, 60.00Hz (1280x1024_60.vfo)
         Video Format Flags:  (none)
         Sync Output(s):
          Composite sync on Green
          Composite TTL sync on Aux 0
         Using Gamma Map 0
        Channel 1:
         Sync Output(s):
         Using Gamma Map 0
        Channel 2 (physical port 222):
         Sync Disabled
         Using Gamma Map 0
Code:
fyrestorm 1# configmon -h
  SEQ            NAME      LOCATION          SERIAL_NUM   PART_NUMBER  REVISION
    0              NA            NA                  NA            NA        NA
    1   MODULE_001c01            NA                  NA            NA        NA
    2              L1        001c01                  NA            NA        NA
    3       IP45_4CPU        001c01              MMB342  030-1797-001        -B
    4       MEMBANK_0        001c01                  NA            NA        NA
    5       MEMBANK_1        001c01                  NA            NA        NA
    6       MEMBANK_2        001c01                  NA            NA        NA
    7       MEMBANK_3        001c01                  NA            NA        NA
    8          R14000        001c01                  NA            NA        NA
    9          R14000        001c01                  NA            NA        NA
   10          R14000        001c01                  NA            NA        NA
   11          R14000        001c01                  NA            NA        NA
   12              NA        001c01                  NA            NA        NA
   13             IO8        001c01              MLZ524  030-1673-003        -G
   14          GE16-4      XTALK_11              GMX327  030-1398-001         A
   15          KTOWN2      XTALK_11              LZP881  030-1593-001         G
   16             RM9      XTALK_11              GCC332  030-1402-001         A
   17          TM7-64      XTALK_11              DGN848  030-1053-001         F
   18             RM9      XTALK_11              GCA342  030-1402-001         A
   19          TM7-64      XTALK_11              GBZ682  030-1053-001         F
   20             RM9      XTALK_11              GCA323  030-1402-001         A
   21          TM7-64      XTALK_11              GCA060  030-1053-001         F
   22           DG5-2      XTALK_11              HKA927  030-1242-001         F
   23           DPLEX      XTALK_11              HKA901  030-1409-001         D
   24             IO8      XTALK_14              MLZ524  030-1673-003        -G
   25     SCSI_CTLR_3            NA                  NA            NA        NA
   26     SCSI_CTLR_0            NA                  NA            NA        NA
   27         DRIVE_1            NA            3HX08B49    ST336753LC      0005
   28         DRIVE_2            NA            3HX06XY9    ST336753LC      0005
   29     SCSI_CTLR_1            NA                  NA            NA        NA
   30         CDROM_4            NA                  NA            NA        NA
   31          TAPE_6            NA                  NA            NA        NA
   32    ETHERNET_EF0            NA                  NA            NA        NA
Code:
4% diskpatch -v
sc0d1l0:  Disk         SEAGATE ST336753LC      0005  Serial: 3HX08xxx
sc0d2l0:  Disk         SEAGATE ST336753LC      0005  Serial: 3HX08xxx
Code:
l2cmd env
001c01:
        12V IO    Enabled  10%  10.80/ 13.20  20%   9.60/ 14.40   12.06
       12V DIG    Enabled  10%  10.80/ 13.20  20%   9.60/ 14.40   12.06
            5V    Enabled  10%   4.50/  5.50  20%   4.00/  6.00    4.97
          3.3V    Enabled  10%   2.97/  3.63  20%   2.64/  3.96    3.32
        5V aux    Enabled  10%   4.50/  5.50  20%   4.00/  6.00    4.97
      3.3V aux    Enabled  10%   2.97/  3.63  20%   2.64/  3.96    3.41
          2.5V    Enabled  10%   2.25/  2.75  20%   2.00/  3.00    2.50
   Speedo2 CPU    Enabled  10%   1.44/  1.76  20%   1.28/  1.92    1.58
          1.5V    Enabled  10%   1.35/  1.65  20%   1.20/  1.80    1.48
FAN 0     LEFT    Enabled         2160         3924
FAN 1   CENTER    Enabled         2160         4017
FAN 2    RIGHT    Enabled         2160         4066
FAN 3       PS    Enabled         2160         3276
FAN 4      PS'    Enabled         2160         4383
Description    State       Temp       Temp       Temp       Temp
NODE 0            Enabled   40C/104F   46C/114F   49C/120F   25C/ 77F
NODE 1            Enabled   40C/104F   46C/114F   49C/120F   24C/ 75F
001g02:
        5V aux    Enabled  10%   4.50/  5.50  20%   4.00/  6.00    5.07
      3.3V aux    Enabled  10%   2.97/  3.63  20%   2.64/  3.96    3.34
FAN 0   BLOWER    Enabled         1080         1476
L1                Enabled   30C/ 86F   35C/ 95F   40C/104F   23C/ 73F
File comment: Onyx 300 with an L2 controller/display, SGI klingon-grey external DDS4 and DVD drives; a fibre channel array <top>, and the intel-based Dell PE2600 server I use as a PC. All crammed into a leftover O2k rack.
 Post subject: Re: Onyx 300
PostPosted: Mon May 19, 2008 10:46 am
The beast lives! Great to see Wadatsumi in action again :)
私のホバークラフト は鰻が一杯です。
PostPosted: Mon May 19, 2008 11:12 am
Can't wait to see its other half alive again ;)
Code:
KONAD gfx ? What kind of setup is that ? a G brick ?
:Onyx2: :Fuel: :1600SW: :O2: :0300: :0300:
PostPosted: Mon May 19, 2008 11:36 pm
If you look at the configmon you can see it is a GE16, RM9, DG5 => IR2E so would be in a graphics brick.
Nice setup!
:ChallengeL: :O2000: :Onyx2: :Onyx2: :Onyx: :O2000R: :O2000R: :O2000E: :O2000E: :Onyx2R: :O3000: :O3000: :O3000: :O3000: :O3000: :O3000: :0300: :0300: :0300: :Indy: :Indigo2: :Indigo2: :Indigo2IMP: :Octane: :Octane: :Octane2: :Octane2: :Fuel: :Fuel:
 Profile E-mail
PostPosted: Sun Jul 20, 2008 3:44 pm
Added sound:
Code:
a.k.a. the Griffin iMic - it was plug and play <no need to edit ioconfig>. Since there was no sound during the original IRIX install, I did have to set the chkconfig "soundscheme" flag "on" to enable the typical IRIX desktop sounds.
PostPosted: Thu Aug 07, 2008 8:35 pm
recondas wrote:
Added sound:
Code:
Jeeze, wreck .... graphics from Cinerama Holiday but sound from the Jazz Singer. Bleugh ! Let's put some real sound in it !
 Post subject: Re: Onyx 300: 4x600-2GB-USB Sound-IR2E Graphics-L2 Controller
PostPosted: Fri Aug 08, 2008 10:17 am
I think his PCI slots are full ;)
私のホバークラフト は鰻が一杯です。
PostPosted: Mon Aug 11, 2008 3:41 pm
Even the Jazz Singer don't sound too bad when he's singing in an 8x10 room accompanied by the fan in a G-brick :)
I actually have one of the compatible PCI sound boards, but neko hit the nail on the head - there only *two* PCI slots in an O300. Right now that's a GigE and an FC board <tho I'm watching for one of the SATA boards>.
PostPosted: Mon Aug 11, 2008 7:50 pm
recondas wrote:
[... - there only *two* PCI slots in an O300.
I thought there was an option to put 16 (or was it 64 ?) pci slots in an origin 3-series ? Maybe you need that :)
PostPosted: Mon Aug 11, 2008 8:37 pm
::drool::
:Onyx2: :Octane2: :Indigo2: :0300:
Onyx2, 4x400 MHz, IR3 // Origin 300, 4x600MHz
Octane2, 2x400 MHz, V12 // Indigo2, 250 MHz, Extreme
 Profile E-mail
PostPosted: Tue Aug 12, 2008 4:06 am
I've seen O3xxx P-Bricks make the occasional appearance on eBay, but unfortunately the the P-Brick isn't compatible with the Origin 3xx. The Origin 3xx requires a PCI expansion module. If there have been any PCI Expansion Modules available recently <at less than corporate level pricing>, I've missed them. Then there's the whole L1 serial security issue to deal with.
O300 PCI Expansion modules probably rare enough that it'd be easier to pick up a few more PCI slots via the purchase of a second O300.
PostPosted: Tue Aug 12, 2008 9:13 am
Absolutely - that's essentially my reasoning when I went with a second dual CPU O300. Gave me a couple extra slots plus additional RAM for comparatively little cash. The extra CPUs weren't bad either ;)
The O350 is a pretty nice step up in that you get three open PCI slots per brick, plus you have on-board gigabit ethernet which saves a slot. If you have two O350s and are starved for slots, you can optionally remove the second IO9 - this gives you a total of seven free PCI slots in just two bricks.
私のホバークラフト は鰻が一杯です。
 Post subject: Re: Onyx 300: 4x600-2GB-USB Sound-IR2E Graphics-L2 Cont. SATA
PostPosted: Thu Mar 12, 2009 11:44 am
Updated the hinv to include an SAS adapter. Installed it, fired up the system and saw the following scroll by in the start-up console:
Code:
NOTICE: /hw/module/001c01/Ibrick/xtalk/14/pci/1/scsi_ctlr/0:  1064 SAS/SATA firmware version 1.26.0.0
I've got an SATA DVD-RW, as soon as I pick up some SATA hard drive(s) and a suitable external enclosure I'll post an update.
 Post subject: Re: Onyx 300: 4x600-2GB-IR2E Graphics-SAS/SATA-L2 Controller
PostPosted: Mon Mar 16, 2009 11:51 pm
Cool! Went for the 4-port model then?
私のホバークラフト は鰻が一杯です。
PostPosted: Tue Mar 17, 2009 9:47 am
One bidder bought up the remaining supply of those $45 8-ports you found. If more show up in the future, I'll get one and move the 4-port into an Intel server <where there's lots of room for internal devices>.
EDIT: Installed an 8-port SAS3442X. Where the syslog once read
Code:
it now reads
Code:
NOTICE: /hw/module/001c01/Ibrick/xtalk/14/pci/1/scsi_ctlr/0:  1068 SAS/SATA firmware version 0.6.9.0
