Purple Indigo2:195 MHz R10K
regan_russell
Unread postby regan_russell » Sat May 17, 2008 2:05 am
1 195 MHZ IP28 Processor
Main memory size: 384 Mbytes
On-board serial ports: 2
Graphics board: High Impact
EISA bus: adapter 0
        Product ID 0x0, 1 GE, 1 RE, 1 TRAM
        VC3 rev A, CMAP rev EMC rev D
        unknown, assuming 19" monitor (id 0xa)
:Onyx2R: :Onyx2R: :0300: :0300: :0300: :O200: :Octane: :Octane: :O2: :O2: :Indigo2IMP: :Indy: :Indy: :Indy: :Indy: :Indy: :Indy: :Indy: :Indy:
:hpserv: J5600, 2 x SUN, 2 x Mac, 3 x Alpha, 2 x RS/6000
SupremeCmdr
Re: Purple Indigo2:195 MHz R10K
Unread postby SupremeCmdr » Sat May 17, 2008 3:03 pm
Very cool.
I haven't seen many of these around locally.
Apple Unibody MBP 2.66Ghz, 8Gb OSX 10.6
Apple MacMini 1.83Ghz, 1Gb OSX 10.5
Apple Power Mac Cube 450Mhz, 256Mb, OSX 10.3 Sweet!
Sun Ultra10 440Mhz 1Gb, SunOS 5.10
http://gothmog.homeunix.net/blog
