Origin 200 2xR12k 270MHz
shrek
Unread postby shrek » Thu Jan 08, 2004 1:05 am
2 270 MHZ IP27 Processors
CPU 0 at Module 1/Slot 1/Slice A: 270 Mhz MIPS R12000 Processor Chip (enabled)
Processor revision: 2.3. Scache: Size 4 MB Speed 180 Mhz Tap 0x9
CPU 1 at Module 1/Slot 1/Slice B: 270 Mhz MIPS R12000 Processor Chip (enabled)
Main memory size: 768 Mbytes
Memory at Module 1/Slot 1: 768 MB (enabled)
Bank 0 contains 128 MB (Standard) DIMMS (enabled)
Bank 1 contains 64 MB (Standard) DIMMS (enabled)
Bank 2 contains 64 MB (Standard) DIMMS (enabled)
Disk drive: unit 5 on SCSI controller 0 (unit 5)
Disk drive: unit 6 on SCSI controller 0 (unit 6)
Integral Fast Ethernet: ef0, version 1, module 1, slot MotherBoard, pci 2
Origin 200 base I/O, module 1 slot 1
HUB in Module 1/Slot 1: Revision 3 Speed 90.00 Mhz (enabled)
IP27prom in Module 1/Slot n1: Revision 6.150
Paid 400 Euro for the thing in May 2003. Upgrade parts (to get it R12k) costed around 40 US dollar (in September 2003)
Users browsing this forum: Yandex [Bot] and 2 guests
