Clear (prototype) O2 RM7000/600MHz 1GB AV/FPA (Asa/亜左)
Unread postby nekonoko » Tue Jun 26, 2007 9:49 pm
Not overly special hardware wise, though it's a very cool looking machine; the front LED throws a nice glow throughout the crystal face.
neko@Asa ~ % hinv -vm
CPU: QED RM7000 Processor Chip Revision: 5.3
FPU: QED RM7000 Floating Point Coprocessor Revision: 5.0
1 602 MHZ IP32 Processor
Main memory size: 1024 Mbytes
Secondary unified instruction/data cache size: 256 Kbytes on Processor 0
Ternary unified instruction/data cache size: 1 Mbyte on Processor 0
Data cache size: 16 Kbytes
FLASH PROM version 4.18
On-board serial ports: tty1
On-board serial ports: tty2
CRM graphics installed
Video: MVP unit 0 version 1.4
Vice: TRE
1600SW Flat Panel adapter board and display.
neko@Asa ~ % /usr/gfx/gfxinfo -vv
        Managed (":0.0") 1600x1024
        32 bitplanes
        Timing table flags:
         Monitor 0 type: Unknown
         Video Output: 1600 pixels, 1024 lines, 50.00Hz (1600x1024_50p)
         Video Format Flags:  (none)
         Sync Disabled
         Using Gamma Map 0
         Monitor Type:  SGI Flat Panel 1600SW
root@Asa ~ # diskpatch -v
sc0d1l0:  Disk         SGI     ST373405LC      2744  Serial: 3EK10GHA
yuckymucky
Re: Clear (prototype) O2 R5K/180MHz 512MB AV
Unread postby yuckymucky » Wed Jun 27, 2007 7:42 am
Looks really cool. How do you like that keyboard? I was thinking about picking one up but have never heard any pros or cons about one.
Unread postby nekonoko » Wed Jun 27, 2007 8:41 am
It uses a laptop style half stroke keyboard and that can be a negative for some. They do work perfectly with SGI machines and the backlighting can be helpful sometimes.
Unread postby foetz » Wed Jun 27, 2007 3:35 pm
nice one. a real collector's item. congrats :D
Re: Clear (prototype) O2 RM5200/300MHz 512MB AV
Unread postby nekonoko » Mon Oct 22, 2007 11:06 pm
Updated with new RM5200/300MHz CPU module. Interestingly, the VICE revision changed from DX to TRE just from the CPU module swap, suggesting that it's actually not tied to the motherboard revision at all.
zahal
Unread postby zahal » Tue Oct 23, 2007 1:47 pm
Have you done the PS fan with blue led swap on this one?
Sitting in a room.....thinkin' shit up. :evil:
:O2: 400MHz R12k - :320: Dual 600MHz PIII - HP Alphaserver DS15 - Digital DECstation5000/133 - Dell T3500 - Apple G4 Cube dual 500MHz/GF6200 - Newton Messagepad 2100 - Apple PowerBook 2400c/G3@240 - Apple PowerMacintosh 6100/66 - Apple PowerMacintosh 6500/G3@500MHz - Apple Workgroup Server 9150/120 G3@280 - Apple Macintosh IIfx - Apple Macintosh LC475 (OC Full 040 33MHz) - Apple Macintosh Color Classic (Full 040 40Mhz Mystic upgrade) - Sun Cobalt Cube 3 - EBOX 3300A-JSK - Tadpole RDI UltraBook IIi - Compaq Armada 4120 - Digital HiNote Ultra II - HP OmniBook 425 - HP 200LX - Crossbeam C12
Unread postby nekonoko » Tue Oct 23, 2007 2:00 pm
Nope - it's all stock. The only thing I've added is a faster CPU.
Unread postby josehill » Tue Oct 23, 2007 4:41 pm
It's odd how natural the Microsoft mouse looks next to a clear O2. :lol:
TaoTeCheese
Unread postby TaoTeCheese » Tue Oct 23, 2007 6:35 pm
josehill wrote:It's odd how natural the Microsoft mouse looks next to a clear O2. :lol:
You mean SGI only looks good next to Microsoft when all the color has been sucked out of it?
Who knew? :P
tillin9
Location: New York, NY / Westport, CT / #mupen64plus on freenode
Unread postby tillin9 » Tue Oct 23, 2007 7:15 pm
Is this the clear O2 with the crack in the back or another one?
Either way, it looks awesome, despite the M$ mouse.
Unread postby josehill » Tue Oct 23, 2007 9:12 pm
Full disclosure: I have the same MS mouse on my O2. Say what you will about Microsoft, but they do know how to make a good mouse. (Sorry to hijack the thread, Neko...)
Unread postby nekonoko » Tue Oct 23, 2007 10:15 pm
The keyboard/mouse are just "peripherals of opportunity" as I don't keep this system set up all the time (it lives on a shelf) :) In fact, I couldn't find the little green USB to PS/2 converter for the mouse last night so I used a standard SGI mouse while testing the 300MHz CPU.
Re: Clear (prototype) O2 RM7000/600MHz 512MB AV/FPA
Unread postby nekonoko » Tue Mar 18, 2008 6:21 pm
Updated: RM7000/600MHz CPU, FPA and matching clear 1600SW.
Only thing I need for it now is another 512MB and an O2 cam.
deBug
Unread postby deBug » Tue Mar 18, 2008 6:57 pm
nekonoko wrote:Updated: RM7000/600MHz CPU, FPA and matching clear 1600SW.
Nice!
Does your 600 have external cache on the CPU board?
Mein Führer, I can walk!
Unread postby nekonoko » Tue Mar 18, 2008 7:10 pm
I think so - it lists tertiary cache on hinv:
