02000 4CPU R12K
LoWeN
02000 4CPU R12K
Unread postby LoWeN » Thu Jan 08, 2004 12:08 am
4 300 MHZ IP27 Processors
CPU 0 at Module 1/Slot 1/Slice A: 300 Mhz MIPS R12000 Processor Chip (enabled)
Processor revision: 2.3. Secondary cache: Size 8 MB Speed 200 Mhz
CPU 1 at Module 1/Slot 1/Slice B: 300 Mhz MIPS R12000 Processor Chip (enabled)
CPU 2 at Module 1/Slot 2/Slice A: 300 Mhz MIPS R12000 Processor Chip (enabled)
CPU 3 at Module 1/Slot 2/Slice B: 300 Mhz MIPS R12000 Processor Chip (enabled)
Main memory size: 3072 Mbytes
Memory at Module 1/Slot 1: 2048 MB (enabled)
Memory at Module 1/Slot 2: 1024 MB (enabled)
Integral SCSI controller 2: Version Fibre Channel AIC-1160, revision 2
Disk drive: unit 0 on SCSI controller 2
Disk drive: unit 1 on SCSI controller 2
Disk drive: unit 2 on SCSI controller 2
Disk drive: unit 3 on SCSI controller 2
Disk drive: unit 4 on SCSI controller 2
Disk drive: unit 5 on SCSI controller 2
Disk drive: unit 6 on SCSI controller 2
Disk drive: unit 7 on SCSI controller 2
Disk drive: unit 8 on SCSI controller 2
Disk drive: unit 9 on SCSI controller 2
Integral SCSI controller 3: Version Fibre Channel AIC-1160, revision 2
Integral SCSI controller 4: Version QL1040B (rev. 2), differential
Jukebox: unit 1 on SCSI controller 4
Tape drive: unit 2 on SCSI controller 4: DLT
Integral SCSI controller 5: Version QL1040B (rev. 2), differential
Integral SCSI controller 6: Version QL1040B (rev. 2), differential
Integral SCSI controller 7: Version QL1040B (rev. 2), differential
IOC3 serial port: tty1
IOC3 serial port: tty2
Origin BASEIO board, module 1 slot 1: Revision 4
Origin FIBRE CHANNEL board, module 1 slot 4: Revision 4
PCI Adapter ID (vendor 36868, device 4448) pci slot 0
PCI Adapter ID (vendor 36868, device 4448) pci slot 1
Origin MSCSI board, module 1 slot 5: Revision 4
PCI Adapter ID (vendor 4215, device 4128) pci slot 2
PCI Adapter ID (vendor 4215, device 4128) pci slot 3
IOC3 external interrupts: 1
IP27prom in Module 1/Slot n1: Revision 6.31
IP27prom in Module 1/Slot n2: Revision 6.57
IO6prom on Global Master Baseio in Module 1/Slot io1: Revision 6.31
UX powered
Users browsing this forum: Bing [Bot], marshallh and 3 guests
