O2000 6CPU R12K
LoWeN
O2000 6CPU R12K
Unread postby LoWeN » Thu Jan 08, 2004 12:06 am
6 300 MHZ IP27 Processors
CPU 0 at Module 1/Slot 1/Slice A: 300 Mhz MIPS R12000 Processor Chip (enabled)
Processor revision: 2.3. Scache: Size 8 MB Speed 200 Mhz Tap 0xa
CPU 1 at Module 1/Slot 1/Slice B: 300 Mhz MIPS R12000 Processor Chip (enabled)
CPU 2 at Module 1/Slot 2/Slice A: 300 Mhz MIPS R12000 Processor Chip (enabled)
CPU 3 at Module 1/Slot 2/Slice B: 300 Mhz MIPS R12000 Processor Chip (enabled)
CPU 4 at Module 1/Slot 3/Slice A: 300 Mhz MIPS R12000 Processor Chip (enabled)
CPU 5 at Module 1/Slot 3/Slice B: 300 Mhz MIPS R12000 Processor Chip (enabled)
Main memory size: 4480 Mbytes
Memory at Module 1/Slot 1: 2048 MB (enabled)
Memory at Module 1/Slot 2: 1152 MB (enabled)
Bank 2 contains 128 MB (Standard) DIMMS (enabled)
Bank 3 contains 128 MB (Standard) DIMMS (disabled)
Memory at Module 1/Slot 3: 1280 MB (enabled)
Bank 3 contains 128 MB (Standard) DIMMS (enabled)
ROUTER in Module 1/Slot 2: Revision 2: Active Ports [4,5,6] (enabled)
ROUTER in Module 1/Slot 3: Revision 2: Active Ports [5,6] (enabled)
IOC3 serial port: tty1
IOC3 serial port: tty2
IOC3 external interrupts: 1
HUB in Module 1/Slot 3: Revision 5 Speed 100.00 Mhz (enabled)
IP27prom in Module 1/Slot n1: Revision 6.64
IP27prom in Module 1/Slot n2: Revision 6.64
IP27prom in Module 1/Slot n3: Revision 6.64
IO6prom on Global Master Baseio in Module 1/Slot io1: Revision 6.65
UX powered
Users browsing this forum: linkdex [Bot] and 2 guests
