Home Origin 2000 :)
cosmos
Home Origin 2000 :)
Unread postby cosmos » Wed Jan 07, 2004 7:12 pm
4 250 MHZ IP27 Processors
FPU: MIPS R10010 Floating Point Chip Revision: 3.4
CPU 0 at Module 1/Slot 1/Slice A: 250 Mhz MIPS R10000 Processor Chip (enabled)
Processor revision: 3.4. Scache: Size 4 MB Speed 250 Mhz Tap 0x9
CPU 1 at Module 1/Slot 1/Slice B: 250 Mhz MIPS R10000 Processor Chip (enabled)
CPU 2 at Module 1/Slot 2/Slice A: 250 Mhz MIPS R10000 Processor Chip (enabled)
CPU 3 at Module 1/Slot 2/Slice B: 250 Mhz MIPS R10000 Processor Chip (enabled)
Main memory size: 1472 Mbytes
Memory at Module 1/Slot 1: 704 MB (enabled)
Bank 1 contains 256 MB (Standard) DIMMS (enabled)
Bank 2 contains 128 MB (Standard) DIMMS (enabled)
Bank 3 contains 64 MB (Standard) DIMMS (enabled)
Bank 4 contains 64 MB (Standard) DIMMS (enabled)
Bank 5 contains 64 MB (Standard) DIMMS (enabled)
Bank 6 contains 64 MB (Standard) DIMMS (enabled)
Bank 7 contains 64 MB (Standard) DIMMS (enabled)
Memory at Module 1/Slot 2: 768 MB (enabled)
Bank 3 contains 128 MB (Standard) DIMMS (enabled)
Integral SCSI controller 2: Version Fibre Channel QL2200, 33 MHz PCI
Integral SCSI controller 5: Version QL1040B (rev. 2), differential
Integral SCSI controller 6: Version QL1040B (rev. 2), differential
Integral SCSI controller 4: Version QL1040B (rev. 2), differential
Integral SCSI controller 7: Version QL1040B (rev. 2), differential
Integral SCSI controller 3: Version Fibre Channel QL2200, 33 MHz PCI
PCI Adapter ID (vendor 4215, device 8704) pci slot 1
Origin MSCSI board, module 1 slot 7: Revision 3
PCI Adapter ID (vendor 4215, device 4128) pci slot 2
PCI Adapter ID (vendor 4215, device 4128) pci slot 3
PCI Adapter ID (vendor 4391, device 1024) pci slot 1
Origin PCI XIO board, module 1 slot 2: Revision 4
PCI Adapter ID (vendor 4215, device 8704) pci slot 0
IP27prom in Module 1/Slot n1: Revision 6.129
IP27prom in Module 1/Slot n2: Revision 6.129
IO6prom on Global Master Baseio in Module 1/Slot io1: Revision 6.129
