Almost forgot video editor: 300MHz O2
The Keeper
Unread postby The Keeper » Wed Jan 07, 2004 7:02 pm
O2 1% hinv -v
1 300 MHZ IP32 Processor
Main memory size: 512 Mbytes
FLASH PROM version 4.16
Integral SCSI controller 2: Version Fibre Channel QL2200
Disk drive: unit 0 on SCSI controller 2 (unit 0)
Disk drive: unit 1 on SCSI controller 2 (unit 1)
Disk drive: unit 2 on SCSI controller 2 (unit 2)
Disk drive: unit 3 on SCSI controller 2 (unit 3)
Disk drive: unit 4 on SCSI controller 2 (unit 4)
Disk drive: unit 5 on SCSI controller 2 (unit 5)
On-board serial ports: tty1
On-board serial ports: tty2
CRM graphics installed
PCI Adapter ID (vendor 36868, device 32888) pci slot 1
PCI Adapter ID (vendor 36868, device 32888) pci slot 2
PCI Adapter ID (vendor 4215, device 8704) pci slot 3
Video: MVP unit 0 version 1.4
Vice: TRE
O2 2% /usr/gfx/gfxinfo -v
32 bitplanes
Monitor 0 type: SGX 256
Video Output: 1280 pixels, 1024 lines, 75.03Hz (1280x1024_75)
Video Format Flags: (none)
Sync Disabled
Using Gamma Map 0
O2 3%
