Octane MXE R12000 360MHz
Unread postby nekonoko » Wed Jan 07, 2004 6:59 pm
[Koyori:~] neko 3% hinv -vm
      PM10360MHZ Board: barcode MLE099     part 030-1590-002 rev  B
            IP30 Board: barcode GRN429     part 030-0887-005 rev  A
    PWR.SPPLY.ER Board: barcode AAE1240501 part 060-0035-003 rev  A
             FP1 Board: barcode 24231C     part 030-0891-003 rev  E
        XTALKPCI Board: barcode HPT350     part 030-0952-005 rev  D
           MOT20 Board: barcode LMC135     part 030-1240-003 rev  H
1 360 MHZ IP30 Processor
Heart ASIC: Revision E
Main memory size: 1536 Mbytes
Xbow ASIC: Revision 1.3
Integral SCSI controller 2: Version QL1080, low voltage differential
Integral SCSI controller 3: Version QL1080, low voltage differential
Integral SCSI controller 4: Version QL1080, low voltage differential
Graphics board: EMXI
  PCI Adapter ID (vendor 0x1077, device 0x1080) PCI slot 1
  PCI Adapter ID (vendor 0x1077, device 0x1080) PCI slot 2
  PCI Adapter ID (vendor 0x1077, device 0x1080) PCI slot 3
[Koyori:~] neko 4% /usr/gfx/gfxinfo -v
        VC3 rev A, CMAP rev F, Heart rev E
        19" monitor (id 0x1)
         Video Output: 1280 pixels, 1024 lines, 75.92Hz (1280x1024_76)
         Video Format Flags:  (none)
         Sync Disabled
         Using Gamma Map 0
