just upgraded Octane
acronym
Unread postby acronym » Wed Jan 07, 2004 6:45 pm
IRIS 24% hinv -v
2 300 MHZ IP30 Processors
Heart ASIC: Revision E
CPU: MIPS R12000 Processor Chip Revision: 2.4
Main memory size: 1024 Mbytes
Xbow ASIC: Revision 1.2
Graphics board: SSI
PCI Adapter ID (vendor 4265, device 5) pci slot 3
IRIS 25% /usr/gfx/gfxinfo
Product ID 0x3, 2 GEs, 2 REs, 0 TRAMs
MGRAS revision 2, RA revision 0
VC3 rev A, CMAP rev E, Heart rev E
21" monitor (id 0xb)
Video Output: 1280 pixels, 1024 lines, 72.24Hz (1280x1024_72)
