Dev system/video editing, O2
Unread postby wolflord » Wed Jan 07, 2004 5:45 pm
sgio2 1# hinv -v
CPU: MIPS R5000 Processor Chip Revision: 2.1
FPU: MIPS R5000 Floating Point Coprocessor Revision: 1.0
1 200 MHZ IP32 Processor
Main memory size: 832 Mbytes
FLASH PROM version 4.18
Integral SCSI controller 2: Version Fibre Channel QL2200A, 33 MHz PCI
On-board serial ports: tty1
On-board serial ports: tty2
CRM graphics installed
PCI Adapter ID (vendor 36868, device 32888) pci slot 1
PCI Adapter ID (vendor 36868, device 32888) pci slot 2
PCI Adapter ID (vendor 4215, device 8704) pci slot 3
Video: MVP unit 0 version 1.4
Vice: TRE
sgio2 2# /usr/gfx/gfxinfo
32 bitplanes
Monitor 0 type: Unknown
WolfLord - :4D70G: :Octane2:
