My big box, Origin 200
wolflord
Unread postby wolflord » Wed Jan 07, 2004 5:39 pm
Processor 0: 180 MHZ IP27
FPU: MIPS R10010 Floating Point Chip Revision: 2.7
Processor 1: 180 MHZ IP27
Processor 2: 180 MHZ IP27
FPU: MIPS R10010 Floating Point Chip Revision: 2.6
Processor 3: 180 MHZ IP27
CPU 0 at Module 1/Slot 1/Slice A: 180 Mhz MIPS R10000 Processor Chip (enabled)
Processor revision: 2.7. Scache: Size 1 MB Speed 120 Mhz Tap 0x9
CPU 1 at Module 1/Slot 1/Slice B: 180 Mhz MIPS R10000 Processor Chip (enabled)
CPU 2 at Module 2/Slot 2/Slice A: 180 Mhz MIPS R10000 Processor Chip (enabled)
Processor revision: 2.6. Scache: Size 1 MB Speed 120 Mhz Tap 0x9
CPU 3 at Module 2/Slot 2/Slice B: 180 Mhz MIPS R10000 Processor Chip (enabled)
Main memory size: 4096 Mbytes
Memory at Module 1/Slot 1: 2048 MB (enabled)
Memory at Module 2/Slot 2: 2048 MB (enabled)
Integral SCSI controller 3: Version QL1040B (rev. 2), single ended
Tape drive: unit 4 on SCSI controller 1: DAT
Integral SCSI controller 4: Version QL1040B (rev. 2), single ended
Integral SCSI controller 5: Version Fibre Channel QL2200A, 33 MHz PCI
Integral SCSI controller 2: Version QL1040B (rev. 2), differential
Integral SCSI controller 6: Version QL1080, low voltage differential
IOC3/IOC4 serial port: tty3
IOC3/IOC4 serial port: tty4
IOC3 parallel port: plp2
Fast Ethernet: ef1, version 1, module 2, slot MotherBoard, pci 2
Integral Fast Ethernet: ef0, version 1, module 1, slot MotherBoard, pci 2
Origin 200 base I/O, module 1 slot 1
Origin 200 base I/O, module 2 slot 2
PCI Adapter ID (vendor 4215, device 4128) pci slot 6
PCI Adapter ID (vendor 4215, device 8704) pci slot 5
PCI Adapter ID (vendor 4215, device 4224) pci slot 7
HUB in Module 1/Slot 1: Revision 3 Speed 90.00 Mhz (enabled)
HUB in Module 2/Slot 2: Revision 3 Speed 90.00 Mhz (enabled)
IP27prom in Module 1/Slot n1: Revision 6.129
IP27prom in Module 2/Slot n2: Revision 6.129
WolfLord - :4D70G: :Octane2:
