My best SGI box: Octane 2x300MHz...
The Keeper
Unread postby The Keeper » Wed Jan 07, 2004 4:54 pm
octane 1% hinv -v
2 300 MHZ IP30 Processors
Heart ASIC: Revision E
CPU: MIPS R12000 Processor Chip Revision: 2.5
Main memory size: 1280 Mbytes
Xbow ASIC: Revision 1.3
Integral SCSI controller 2: Version Fibre Channel QL2200, 33 MHz PCI
Disk drive: unit 0 on SCSI controller 2 (unit 0)
Disk drive: unit 1 on SCSI controller 2 (unit 1)
Disk drive: unit 2 on SCSI controller 2 (unit 2)
Disk drive: unit 3 on SCSI controller 2 (unit 3)
Disk drive: unit 4 on SCSI controller 2 (unit 4)
Disk drive: unit 5 on SCSI controller 2 (unit 5)
Disk drive: unit 6 on SCSI controller 2 (unit 6)
Disk drive: unit 7 on SCSI controller 2 (unit 7)
IOC3 parallel port: plp-1
Graphics board: EMXI
Graphics board: ESI
Fast Ethernet: ef1, version 1, pci 2
PCI Adapter ID (vendor 0x1077, device 0x2200) PCI slot 1
octane 2%
octane 2% /usr/gfx/gfxinfo -v
VC3 rev A, CMAP rev E, Heart rev E
19" monitor (id 0x1)
Managed (":0.1") 1280x1024
HQ rev B, GE12 rev A, RE4 rev C, PP1 rev E,
VC3 rev A, CMAP rev F, Heart rev E
octane 3%
