Octane2, 600MHz, 512MB, V12, 36GB Remanufactured Special
ipaddict
Unread postby ipaddict » Wed May 02, 2007 7:08 pm
This is one of the Octane2 units from this special.
hinv:
      PM10600MHZ Board: barcode NJX172     part 030-1774-002 rev  B
            IP30 Board: barcode NCN449     part 030-1467-001 rev  L
             FP1 Board: barcode MVD028     part 030-0891-003 rev  J
    PWR.SPPLY.ER Board: barcode AAE4390052 part 060-0035-003 rev  C
      ODY128B1_2 Board: barcode NEF668     part 030-1945-002 rev  A
1 600 MHZ IP30 Processor
Heart ASIC: Revision F
Main memory size: 512 Mbytes
Xbow ASIC: Revision 1.4
Graphics board: V12
gfxinfo:
        BUZZ version B.2
        PB&J version 1
        128MB memory
                Banks: 4, CAS latency: 3
         Monitor 0 type: Unknown
uname:
IRIX64 Octane2 6.5 6.5.30m 07202013 IP30
