Octane2, 600MHz, V12-DCD, DIVO, CardCage, 3584MB, Avid Array
Unread postby recondas » Sat Apr 21, 2007 10:27 pm
1% hinv -vm
      PM10600MHZ Board: barcode NJX202     part 030-1774-002 rev  B
            IP30 Board: barcode MVV984     part 030-1467-001 rev  L
             FP1 Board: barcode KJX274     part 030-0891-003 rev  G
    PWR.SPPLY.ER Board: barcode AAE4390043 part 060-0035-003 rev  C
        XTALKPCI Board: barcode GRN860     part 030-0952-005 rev  C
      ODY128B1_2 Board: barcode NEH880     part 030-1945-002 rev  A
            DIVO Board: barcode FXP262     part 030-1305-001 rev  A
1 600 MHZ IP30 Processor
Heart ASIC: Revision F
Main memory size: 3584 Mbytes
Xbow ASIC: Revision 1.4
  CDROM: unit 3 on SCSI controller 1
  CDROM: unit 5 on SCSI controller 1
  Tape drive: unit 6 on SCSI controller 1: DLT
Integral SCSI controller 2: Version QL12160, low voltage differential
  Disk drive: unit 2 on SCSI controller 2 (unit 2)
  Disk drive: unit 3 on SCSI controller 2 (unit 3)
Integral SCSI controller 3: Version QL12160, low voltage differential
  Disk drive: unit 4 on SCSI controller 3 (unit 4)
  Disk drive: unit 5 on SCSI controller 3 (unit 5)
Graphics board: V12
Gigabit Ethernet: tg1, PCI slot 3
  PCI Adapter ID (vendor 0x14e4, device 0x1645) PCI slot 3
  PCI Adapter ID (vendor 0x10a9, device 0x0002) PCI slot 0
  PCI Adapter ID (vendor 0x10a9, device 0x0002) PCI slot 2
DIVO Video: controller 0 unit 0: Input, Output
Dual Channel Display
2% /usr/gfx/gfxinfo -vv
        Managed (":0.0") 2560x1024
        BUZZ version B.2
        PB&J version 1
        128MB memory
                Banks: 4, CAS latency: 3
         Monitor 0 type: Unknown
        Dual Channel Display option
         Monitor 1 type: DEL -8189       Monitor 2 type: NEC 26089
         Video Output: 1280 pixels, 1024 lines, 60.00Hz (2@1280x1024_60)
         Video Format Flags:  (none)
         Sync Disabled
         Using Gamma Map 0
         Monitor Type:  DEL-57347
         Gain (all color components) - 0.000000 ; range [1,10]
        Channel 1:
         Origin = (1280,0)
         Sync Disabled
         Using Gamma Map 0
         Monitor Type:  NEC-26089
3% /usr/dmedia/bin/DIVO/divohinv
/hw/node/xtalk/9
        DIVO (part number 030-1305-001 A), serial number FXP262
        VL device 0 (name DIVO_0), AL subsystem DIVO_0
        IRIX number 0
4% configmon -h
  SEQ            NAME      LOCATION          SERIAL_NUM   PART_NUMBER  REVISION
    0              NA            NA                  NA            NA        NA
    1             FP1            NA              KJX274  030-0891-003         G
    2            IP30            NA              MVV984  030-1467-001         L
    3      PM10600MHZ            NA              NJX202  030-1774-002         B
    4      ODY128B1_2            NA              NEH880  030-1945-002         A
    5            DIVO            NA              FXP262  030-1305-001         A
    6    PWR.SPPLY.ER            NA          AAE4390043  060-0035-003         C
    7        XTALKPCI            NA              GRN860  030-0952-005         C
    8     SCSI_CTLR_0            NA                  NA            NA        NA
    9         DRIVE_1            NA  3CEXXXX    Copyrigh    SX173404LC      BD13
   10         DRIVE_2            NA        UFLXXXX     MAN3184MC      5507
   11     SCSI_CTLR_1            NA                  NA            NA        NA
   12         CDROM_3            NA                  NA            NA        NA
   13         CDROM_5            NA                  NA            NA        NA
   14          TAPE_6            NA                  NA            NA        NA
   15     SCSI_CTLR_2            NA                  NA            NA        NA
   16         DRIVE_2            NA            3CD0XXXX    ST336704LC      3305
   17         DRIVE_3            NA            3CD0XXXX    ST336704LC      3305
   18     SCSI_CTLR_3            NA                  NA            NA        NA
   19         DRIVE_4            NA            3CD0XXXX    ST336704LC      3305
   20         DRIVE_5            NA            3CD1XXXX    ST336704LC      3305
Four Avid rS36/160 10k MediaDrives striped across both channels of a qla12160s mounted in a cardcage:
5% diskpatch -v
sc0d1l0:  Disk         SEAGATE ST173404LC      0004  Serial: 3CEXXXX
sc0d2l0:  Disk         FUJITSU MAN3184MC       5507  Serial: UFLXXXX
sc3d2l0:  Disk         AVID    ST336704LC      3305  Serial: 3CD0XXXX
sc3d3l0:  Disk         AVID    ST336704LC      3305  Serial: 3CD0XXXX
sc4d4l0:  Disk         AVID    ST336704LC      3305  Serial: 3CD0XXXX
sc4d5l0:  Disk         AVID    ST336704LC      3305  Serial: 3CD0XXXX
Re: Octane2, 600MHz, V12, DCD, CardCage, 1792 MB RAM, Avid Array
Unread postby recondas » Wed Jun 20, 2007 6:19 pm
Updated with RAM, gigabit ethernet, Cardcage, array and DCD <time to buy a second 2407FWP>
Unread postby nekonoko » Fri Jun 22, 2007 6:43 am
recondas wrote:
4% diskpatch -v
Aha - using 'diskpatch' as a quick means to query the drives is pretty slick! Thanks for the tip :)
Richtom1
Unread postby Richtom1 » Fri Jun 22, 2007 3:11 pm
Nice one Dave.
I hope to get a DCD for one of my Octanes soon. Was the DCD automatically recognized with your OS?
Richard
Unread postby recondas » Fri Jun 22, 2007 5:24 pm
Richtom1 wrote:Nice one Dave.
Thank you.
Richtom1 wrote:I hope to get a DCD for one of my Octanes soon. Was the DCD automatically recognized with your OS?
It was, though the first boot after installation it loaded 2@1280x1024_60 <apparently the default setting if it didn't like what you had selected>, rather than the single display 1920x1200_60 I had it set at. Not a big problem , but with a single display I could only see half of my desktop until I re-ran setmon to get back to 1920x1200 <aimed at my single display>. I'm using a 24" lcd, which I thought it looked acceptable at 1920x1200 connected to the vga port. Don't think I could go back now that I've seen the results when connected to the dvi port. Looks like I need to budget for a matching second lcd.
There's a copy of the manual 'Dual Channel Display Guide for Silicon Graphics Octane2 and Silicon Graphics Fuel Workstations' on TechPubs.
ipaddict
Unread postby ipaddict » Sat Jun 23, 2007 9:41 pm
recondas wrote:I'm using a 24" lcd, which I thought it looked acceptable at 1920x1200 connected to the vga port. Don't think I could go back now that I've seen the results when connected tothe dvi port. Looks like I need to budget for a matching second lcd.
Light years better, isn't it? :D
Re: Octane2, 600MHz, V12-DCD, DIVO, CardCage, 1792MB, Avid Array
Unread postby recondas » Thu Mar 12, 2009 4:32 pm
Added an Onyx2 style Digital Video Option <DIVO>, updated the hinv.
/hw/node/xtalk/9
        IRIX number 0
Unread postby recondas » Mon Mar 16, 2009 8:32 am
eMGee wrote:Very nice system there!
Thanks
eMGee wrote:Do you use (or are you planning on using) it for compositing/editing?
Not professionally
eMGee wrote:The ‘Avid array’ is SCSI, I see. How's the performance?
Haven't tested it lately - but here's a diskperf test I did when I had the same array and controller attached to an Octane with a single R12-360Mhz <oc'd to 425MHz>. Might see some improvement if the same test was run with the current 600MHz setup.
eMGee wrote:By the way, any pictures of the setup? (Perhaps also of the array and DIVO?)
The Octane2 is <just> visible in this shot from my environment gallery <which hasn't been updated in quite a while>:
While not the the same array <this one is a spare>, they look the same <look between the G4 PowerMac and the Octane with it's back to you>:
I didn't take any photos of the DIVO before I installed it, but I've got another DIVO that I'll photograph and post later.
Re: Octane2, 600MHz, V12-DCD, DIVO, CardCage, 3584MB, Avid Array
Unread postby recondas » Sat Aug 22, 2009 3:44 am
Added two 1GB DIMMs.......
Unread postby recondas » Wed Oct 28, 2009 12:37 pm
Switched from one 1920x1200 display to two 18" 1280x1024 LCD displays <connected via the DCD>. The DCD dual display mode spans both monitors, giving an effective resolution of 2560x1024.
Here's a photo of the setup running ElectroPaint <with a fairly long shutter time - excuse the motion blur in the EP elements>.
indyman007
Unread postby indyman007 » Wed Oct 28, 2009 2:43 pm
What is this, 'avid array'?
:Indy: R4600PC 133 MHz
Mac Mini 2.5GHz 8GB RAM
Raspberry Pi
shadowless
Unread postby shadowless » Wed Oct 28, 2009 2:46 pm
those 4 boxes sitting next to the mac g4
indyman007
Unread postby indyman007 » Wed Oct 28, 2009 2:49 pm
Oh, are they used for storage?
Raspberry Pi
Unread postby recondas » Wed Oct 28, 2009 2:57 pm
indyman007 wrote:Oh, are they used for storage?
Yes - you can see them listed in the "diskpatch" portion of my original post. They're the ones where the drive firmware returned "Avid". <diskpatch is an older IRIX utility intended to "prevent stiction problems with some disk drives", but using it with the -v switch is a quick way to get a list of hard drives attached to the system>
indyman007
Unread postby indyman007 » Wed Oct 28, 2009 2:59 pm
Well, thank-you for the information, hmmm, I think I'll just stick in another HDD instead of such an array.
I was wondering what all those disks were doing in one octane :D.
Is that array SGI branded, it doesn't look it.
Raspberry Pi
