Octane 2xr10k, 225mhz, 512mb, 8.3GB
jnolck
Unread postby jnolck » Wed Apr 18, 2007 5:13 pm
harriet 10# hinv -mv
      PM20225MHZ Board: barcode GTM684     part 030-1271-002 rev  F
            IP30 Board: barcode DTX247     part 030-0887-005 rev  A
             FP1 Board: barcode 07417C     part 030-0891-003 rev  E
    PWR.SPPLY.S2 Board: barcode AAC8150318 part 060-0038-001 rev  D
            GM10 Board: barcode GPG389     part 030-0938-003 rev  V
2 225 MHZ IP30 Processors
Heart ASIC: Revision D
Main memory size: 512 Mbytes
Xbow ASIC: Revision 1.3
Integral SCSI controller 0: Version QL1040B, single ended
Integral SCSI controller 1: Version QL1040B, single ended
Graphics board: SI with texture option
Got my adaptors from deep space today, so i'm finally able to test the octane. It's not a fancy one, but it's my octane and i love it. I actually drove all the way up to San Francisco to get this one. SGI fever is to blame for such act.
Octane 2xr10k, 225mhz, 512mb, 8.3gb harriet
02 r10k, 150mhz, 256MB, 4GB johannah
Ultra10 333MHz US-IIi, 512MB, 20GB alissa
SB2000 2x750Mhz US-III, 2GB, 36GB cheryl
jnolck
Re: Octane 2xr10k, 225mhz, 512mb, 8.3GB
Unread postby jnolck » Wed Apr 09, 2008 3:54 pm
Got an external cdrom and a new video board.
bash-3.1# hinv -mv
           MOT10 Board: barcode JHV912     part 030-1241-002 rev  H
  CDROM: unit 5 on SCSI controller 1
Graphics board: ESI
bash-3.1# /usr/gfx/gfxinfo
        Product ID 0x2, 1 GE, 1 RE, 4 TRAMs
        HQ rev B, GE11 rev B, RE4 rev C, PP1 rev E,
        VC3 rev A, CMAP rev E, Heart rev D
        Managed (":0.1") 1280x1024
        HQ rev B, GE12 rev A, RE4 rev C, PP1 rev E,
        VC3 rev A, CMAP rev F, Heart rev D
