It is currently Tue May 21, 2013 11:35 am
Post new topic Reply to topic  [ 5 posts ]
Unread postPosted: Sat Mar 24, 2007 4:33 pm
I couldn't resist in upgrading my lovely toy:
Code:
Octane2 1% hinv -mv
      PM20400MHZ Board: barcode KYA069     part 030-1476-001 rev  D
            IP30 Board: barcode MMP229     part 030-1467-001 rev  H
    PWR.SPPLY.ER Board: barcode AAE9200234 part 060-0035-002 rev  A
             FP1 Board: barcode MCD790     part 030-0891-003 rev  H
          ODY128 Board: barcode KTW991     part 030-1404-003 rev  A
2 400 MHZ IP30 Processors
Heart ASIC: Revision F
Main memory size: 5120 Mbytes
Xbow ASIC: Revision 1.4
Graphics board: V8
Code:
Octane2 2% /usr/gfx/gfxinfo
        BUZZ version A.1
        PB&J version 1
        128MB memory
                Banks: 4, CAS latency: 3
         Monitor 0 type: Unknown
         Video Output: 1280 pixels, 1024 lines, 50.00Hz (1280x1024_50)
Running the V8 only at 50Hz on a F180 tft results in a clear image without the typical V6/V8 'OpenGL-artefacts' and problems.
:Octane2: 2xR12000 400MHz, 4GB RAM, V12 GFX
Unread postPosted: Thu May 28, 2009 12:59 am
Code:
Octane2 4% hinv -mv
    PWR.SPPLY.ER Board: barcode AAE1050838 part 060-0035-002 rev  A
  ODY128VERSIONB Board: barcode MDF774     part 030-1611-001 rev  C
Main memory size: 8192 Mbytes
Graphics board: V12
Code:
Octane2 5% /usr/gfx/gfxinfo
        Managed (":0.0") 1696x1056
        BUZZ version B.1
        PB&J version 1
        128MB memory
         Video Output: 1680 pixels, 1050 lines, 60.00Hz (1680x1050_60)
Unread postPosted: Thu Aug 20, 2009 2:56 am
2 Memory modules died :-(
Unread postPosted: Thu Aug 20, 2009 1:55 pm
Sorry to hear about your RAM, Geoman. I had some Dataram memory that served me pretty well for about a year, and one module apparently died right as I sold four sticks of it. It could have been damaged in shipping though - but it does seem like people have been having issues with it. :(
:Onyx2: :Fuel: :Indigo2: :Indigo2IMP: :O3x0:
Unread postPosted: Fri Aug 21, 2009 2:26 am
Yes, the modules from Kingston and SGI are the double stacked ones, which are comparatively robust.
The ICs on the DATARAM modules look like those for notebooks, they are soldered side by side via ball grid array.
Seems like they're indeed very delicate.
