ipfilter and passive ftp
cybercow
Unread postby cybercow » Mon Jan 14, 2008 4:04 am
I`m using standard ftpd from IRIX dist, altrough the active ftp seems working fine, the passive one blocs the traffic all the time.
here the piece of ipf.conf for ftp, the passive block is wrong:
# active FTP
pass in quick proto tcp from any port > 1023 to 'my_server_ip_addr' port = 21 flags S  keep state
pass out quick proto tcp from any port = 20 to any port > 1023 flags S keep state
# passive FTP
pass in quick proto tcp from any to 'my_server_ip_addr' port 15000 >< 20000 flags S keep state
pass out proto tcp all keep state
mmendez
Re: ipfilter and passive ftp
Unread postby mmendez » Tue Jan 15, 2008 12:18 pm
Which machine is running ipfilter? Have you tried setting up ipf to use the ftp proxy feature?
SGI: :Indigo2IMP: :Fuel: :O2: :Octane2:
Sun: Ultra2, Ultra60, Sun Fire 4800
Apple: G3, Powermac G4 MDD, PowerMac G5, Mac Mini, iBook G4 12", MBP
Dec 3000
IBM RS/6000
AMD64 FreeBSD box
Return to “SGI: Security”
