graphics tablets and GIMP
lisp
Unread postby lisp » Tue Feb 11, 2003 4:49 am
I purchased myself a nifty little ArtPad II. I've got it all configured and stuff, but it's behaving very strangely in the gimp. It appears something is reporting the occasional 0 value on the axis. Nothing that suggests this appears with the normal pointer, but it makes it useless for drawing in the gimp with. Is this a bug in the gimp?
lisa
Shtoink
Unread postby Shtoink » Tue Feb 11, 2003 9:31 am
If you have other software to test it out on, I would suggest testing it out on other stuff as well. You could try FilmGimp and eclipse out, as for anything else, they all cost alot or are very hard to find abandonware.
Man... I want one of these pads, too...
I can't afford my hobbies.
Unread postby nekonoko » Sun Apr 06, 2003 12:02 am
I have an old ArtZ II 12x12 I've been meaning to try and get working under IRIX. It needs a new power supply though, the cable is a bit worn near the power brick and looks unsafe.
lisp
Unread postby lisp » Mon Apr 07, 2003 12:18 am
The pad's as sweet as a sweet sweet thing on Photoshop and Illustrator.
So, it *is* the GIMP's fault.
lisa
