Compiling YafRay V0.0.7 On MIPSPRO
GeneratriX
Unread postby GeneratriX » Wed Jun 15, 2005 3:37 am
...mmmhhh
Anyone has completed succesfully the build of YafRay V0.0.7 on IRIX? ...I got the package already compiled, but on the 'make install' phase I get:
make install
Making install in src
Making install in yafraycore
/bin/sh ../../mkinstalldirs /usr/local/lib
 /bin/sh ../../libtool --mode=install /usr/freeware/bin/install -c  libyafraycore.la /usr/local/lib/libyafraycore.la
/usr/freeware/bin/install -c .libs/libyafraycore /usr/local/lib/libyafraycore
/usr/freeware/bin/install -c .libs/libyafraycore.lai /usr/local/lib/libyafraycore.la
Libraries have been installed in:
   /usr/local/lib
If you ever happen to want to link against installed libraries
in a given directory, LIBDIR, you must either use libtool, and
specify the full pathname of the library, or use the `-LLIBDIR'
flag during linking and do at least one of the following:
   - add LIBDIR to the `LD_LIBRARYN32_PATH' environment variable
     during execution
   - use the `-Wl,-rpath -Wl,LIBDIR' linker flag
See any operating system documentation about shared libraries for
more information, such as the ld(1) and ld.so(8) manual pages.
Making install in lights
/bin/sh ../../mkinstalldirs /usr/local/lib/yafray
 /bin/sh ../../libtool --mode=install /usr/freeware/bin/install -c  libpathlight.la /usr/local/lib/yafray/libpathlight.la
libtool: install: warning: relinking `libpathlight.la'
(cd /WareRoot/YafRay-0.07/YafRay/yafray-0.0.7/src/lights; /bin/sh ../../libtool --mode=relink g++ -O3 -fomit-frame-pointer -ffast-math -Wall -D_PTHREADS -I../yafraycore -g -O2 -o libpathlight.la -rpath /usr/local/lib/yafray -no-undefined -module -export-dynamic -avoid-version pathlight.lo pathtools.lo ../yafraycore/libyafraycore.la )
g++ -shared -nostdlib /usr/freeware/lib/gcc-lib/mips-sgi-irix6.5/3.3/crtbegin.o  .libs/pathlight.o .libs/pathtools.o  -Wl,-rpath -Wl,/usr/local/lib -L/usr/local/lib -lyafraycore -L/usr/freeware/lib/gcc-lib/mips-sgi-irix6.5/3.3 -L/usr/bin -L/usr/freeware/lib/gcc-lib/mips-sgi-irix6.5/3.3/../../.. -lstdc++ -lm -L/usr/lib32/mips3 -L/usr/lib32 -lgcc /usr/freeware/lib/gcc-lib/mips-sgi-irix6.5/3.3/crtend.o  -Wl,-soname -Wl,libpathlight `test -n "" && echo -Wl,-set_version -Wl,` -Wl,-update_registry -Wl,.libs/so_locations -o .libs/libpathlight
ld32: FATAL   9  : I/O error (-lyafraycore): No such file or directory
collect2: ld returned 32 exit status
libtool: install: error: relink `libpathlight.la' with the above command before installing it
*** Error code 1 (bu21)
skywriter
Unread postby skywriter » Wed Jun 15, 2005 10:28 am
last time i compiled yafray was with 0.0.6 and gcc 3.3 on MIPS. yes the performance was pretty poor. yes the binay was huge. yes the experience was digusting. but it did work. sometimes that's all the counts anymore. too bad. I would have too say that this source (at the time) relied on too many GNU-ism's like libtool to make it worth using a different compiler.
GeneratriX
Some Symbols...
Unread postby GeneratriX » Wed Jun 15, 2005 12:55 pm
skywriter wrote:last time i compiled yafray was with 0.0.6 and gcc 3.3 on MIPS. yes the performance was pretty poor. yes the binay was huge. yes the experience was digusting. but it did work. sometimes that's all the counts anymore. too bad. I would have too say that this source (at the time) relied on too many GNU-ism's like libtool to make it worth using a different compiler.
Hello Ben;
it compiles fine, even with MIPSPRO; is on the install process where it fails. Anyway I've rescued manually all the decisory files, to arrange those on the classic YafRay dir structure, as follows:
cd usr/local
ls
bin  etc  lib
cd bin
ls
lt-yafray  yafray
cd ..
cd etc
ls
gram.yafray
cd ..
cd lib
ls
libyafraycore       libyafrayplugin     yafray
libyafraycore.la    libyafrayplugin.la
cd yafray
ls
libarealight          libhemilight          libsoftlight
libbasicblocks        libmixblocks          libspherelight
libbasicshaders       libpathlight          libspotlight
libblendershader      libphotonlight        libsunlight
libglobalphotonlight  libpointlight         libsunsky
libhdri               libshaderback
And an 'ldd' shows that it is linked as follows:
ldd yafray
libyafraycore  => /usr/local/lib/libyafraycore
libz.so  => /usr/lib32/libz.so
libpthread.so  => /usr/lib32/libpthread.so
libdl.so  => /usr/lib32/libdl.so
libm.so  => /usr/lib32/libm.so
libc.so.1  => /usr/lib32/libc.so.1
...But on execution complains with:
./yafray
 2853:./yafray: rld: Error: unresolvable symbol in /usr/local/lib/libyafraycore: _ZN6yafray9context_tC1Ev
 2853:./yafray: rld: Error: unresolvable symbol in /usr/local/lib/libyafraycore: _ZN6yafray9context_tD1Ev
 2853:./yafray: rld: Fatal Error: this executable has unresolvable symbols
skywriter
Unread postby skywriter » Wed Jun 15, 2005 1:10 pm
weird.... but free!
GeneratriX
Unread postby GeneratriX » Wed Jun 15, 2005 1:31 pm
skywriter wrote:weird.... but free!
heheh! :lol:
...Seems that the only way to debug it is doing a trace for those unresolvable symbols ( _ZN6yafray9context_tC1Ev ... _ZN6yafray9context_tD1Ev ) but I have not too much time by now, and this build is only strictly fro my spare time! ;)
Re: Compiling YafRay V0.0.7 On MIPSPRO
Unread postby dexter1 » Thu Jun 16, 2005 5:51 pm
Diego wrote:...mmmhhh
Ok everybody please start laughing at Yafray makefile "specialists", 'cause this one is a real screamer:
g++ ??? what the hell does that do in a mipspro build? Looks like somebody made a sick joke upon us. I tried this myself and even with env settings like 'setenv CXX CC' it still came up with g++.
Sure enough, i found the bug in src/yafraycore/Makefile.in:
CPP = @CPP@
CPPFLAGS = @CPPFLAGS@
CXX = g++
CXXCPP = @CXXCPP@
CXXDEPMODE = @CXXDEPMODE@
Hardcoded g++ compiler in the makefile. It doesn't get any worse than this. Stupid crack kiddies...
So add this patch:
--- Makefile.in.save    Fri Jun 17 02:11:56 2005
+++ Makefile.in Fri Jun 17 02:12:16 2005
@@ -51,7 +51,7 @@
 CPP = @CPP@
-CXX = g++
+CXX = @CXX@
 CXXCPP = @CXXCPP@
 CXXFLAGS = @CXXFLAGS@
--- vector3d.h.save     Fri Jun 17 02:20:41 2005
+++ vector3d.h  Fri Jun 17 02:20:54 2005
@@ -26,7 +26,7 @@
 #include<config.h>
 #endif
-#include<cmath>
+#include<math.h>
 #include<iostream>
 #include<stdlib.h>
 #include<stdio.h>
--- color.h.save        Fri Jun 17 02:23:23 2005
+++ color.h     Fri Jun 17 02:23:36 2005
@@ -28,7 +28,7 @@
 #endif
 #include <iostream>
-#include <cmath>
+#include <math.h>
 #define COLOR_SIZE 3
And this environment:
setenv CC c99
setenv CXX CC
setenv CFLAGS '-O3 -mips4 -n32'
setenv CXXFLAGS '-O3 -mips4 -n32'
setenv CPPFLAGS '-I/usr/nekoware/include'
setenv LDFLAGS '-L/usr/nekoware/lib  -Wl,-rpath -Wl,/usr/nekoware/lib'
setenv GNUMAKE '/usr/nekoware/bin/make'
setenv PERL '/usr/nekoware/bin/perl'
There are more Makefile.in which also have this harcode. Please fix them accordingly...
The " _ZN6yafray9context_tC1Ev" i recognised as c++ name mangling errors, which would be perfectly logical if one would mix g++ libs with mipspro code.
It could be that the libraries need to be rearchived with CC -ar -WR,-suv -o
I'm rechecking this ATM...
GeneratriX
Unread postby GeneratriX » Thu Jun 16, 2005 6:16 pm
dexter1 wrote:Ok everybody please start laughing at Yafray makefile "specialists", 'cause this one is a real screamer:
Nice catch, Dexter! ;)
...but I've also tried using g++ (GCC Version 3.3), and I can't get a clean install here... Hence my words:
Diego wrote:it compiles fine, even with MIPSPRO
As far as I can see, it is not a very clean "multiplatform" sourcecode, but I could be wrong! ;)
Unread postby dexter1 » Sat Jun 18, 2005 8:11 am
Diego wrote: Nice catch, Dexter! ;)
No Diego, you're missing the entire point.
With the Makefile.in template you ALWAYS compile with g++ even when the ./configure script says it has found CC and you have set environment variables the right way.
The g++ is HARDCODED in all Makefile.in templates...
If you really managed to get it compiled with MIPSPro 7.4.x you should have had complaints with
#include <cmath>
in 2 files because that is an old, unsupported style header file. See my patch, it's in there...
That's why you need to change all g++ occurences with @CXX@ in all Makefile.in files. Then do a ./configure again and it should start compiling with MIPSPro CC.
The make install problem is an entirely different one. Looks like the supplied libtool severely screws up. The solution is to get the latest libtool from gnu.org ( 1.5.18 ), ./configure;make that one and copy libtool and ltmain.sh to the yafray top source dir. Then do
 ./configure --enable-static --disable-fast-install ; gmake ; gmake install
The next thing that you get is that every cout/cerr stream ending with '<<endl' will segfault and dump core. Looks like the coders got overzealous and decided to overload every << instance in their own ostream class. Handy...
Replacing all '<<endl' with '<<"\n"' seems to fix this. Better get a script to do that for you. :)
I have this almost done. Good testing still needs to be done before we can go to '-Ofast -IPA'
Unread postby foetz » Sat Jun 18, 2005 12:07 pm
hi,
tried it, too.
it's a real pain. seems like the guys over there are some sort of 'made with and for linux' :lol:
hardcoding g++ in some makefiles is crap anyway. no matter which os.
GeneratriX
Unread postby GeneratriX » Sat Jun 18, 2005 2:28 pm
dexter1 wrote:No Diego, you're missing the entire point.
Ouch! :oops: Now I really feel stupid! :lol:
That's it, seems that I'm too much hurried by this days, and I've not taked well care of your post...
Now all has a lot of sense.
dexter1 wrote:If you really managed to get it compiled with MIPSPro 7.4.x you should have had complaints with
#include <cmath>
Nah... then, I've never really compiled with MIPSPRO; now I can see the g++ sentences hardcoded in my Makefile.in! :shock:
Sorry, I'm felt in the fact too late. You can see it even in my previous post! Augh! :(
dexter1 wrote:The make install problem is an entirely different one. Looks like the supplied libtool severely screws up. The solution is to get the latest libtool from gnu.org ( 1.5.18 ), ./configure;make that one and copy libtool and ltmain.sh to the yafray top source dir. Then do
Well; seems a lot of work for a nice piece of software that I'll only use a few minutes by month in my spare time... But stills interesting...
I already have done a tardist install for Blender 2.37a, and I could like to add this one to the list of customizations modules for my SlimDesktop, since both makes a good douple! ;)
SlimDesktop has currently included a tardist for YafRay V0.0.6, but if the new version is "NekoWared" I'll be happy pulling out the 0.0.6 to replace it with another "IRIX-Orphan" software...
The prerequisites for a program, to be added to my SlimDesktop are:
1) Not other tardist versions visible on the net for such program.
2) An IRIX friendly roadmap of the program, without too many gcc/g++ 'isms or platform dependant vicious.
3) That the program by itself can be interesting from a graphic/visual work point of view for the end user.
4) That the program can enhance the already available features on IRIX/IMD/4Dwm.
5) The author agreement about the inclusion of his software on my big tardist install! :) ...Even when sometimes I'm too lazy to ask to the authors, and I only wait for a claim to pull-out the whole thing! ;)
But as a rule of my philosophy, I'll not double efforts already present on the IRIX community, beeing this SGI FreeWare, NekoWare, or whatever else. So, every tardist version already present on SlimDesktop for a given program, yet covered by the SGI/IRIX community, there'll be replaced for a new one acomplishing strictly the above five rules to keep my software rich from the point of view of their originality and usefulness.
This also works as a good way to manage better my time at front my SGI boxes! :)
Unread postby dexter1 » Thu Jun 23, 2005 7:20 am
After some bloody confrontation scenarious with yafray source, i think i have the magic patch file pinned down. Problem only is that i cannot find a mundane test.xml file so i can test the yafray binary. I already tried the test007.zip package and i can't get a sensible xml out of blender. Or the xml code will come out fine, but i get things like this:
neo:~>yafray YBtest.xml
Starting YafRay ...
Loading grammar ...
Starting parser ...
[Warning]: Unknown camera attr aspect_ratio
[Warning]: Unknown camera attr bokeh_type
[Warning]: Unknown camera attr bokeh_bias
[Warning]: Unknown camera attr bokeh_rotation
Parsing OK
Loading plugins ...
[Warning]: Unknown shader type blendershader
[Error]: undefined shader MAcristal object ignored
[Error]: undefined shader MArojo object ignored
[Error]: undefined shader MAMaterial object ignored
[WARNING]:Unused param angle in light
[WARNING]:Unused param cluster in light
[WARNING]:Unused param color in light
[WARNING]:Unused param depth in light
[WARNING]:Unused param fixedradius in light
[WARNING]:Unused param from in light
[WARNING]:Unused param photons in light
[WARNING]:Unused param power in light
[WARNING]:Unused param search in light
[WARNING]:Unused param to in light
[WARNING]:Unused param use_QMC in light
[WARNING]:Unused param cast_shadows in light
[WARNING]:Unused param cache in light
[WARNING]:Unused param cache_size in light
[WARNING]:Unused param caus_depth in light
[WARNING]:Unused param grid in light
[WARNING]:Unused param ignore_bumpnormals in light
[WARNING]:Unused param samples in light
[WARNING]:Unused param shadow_threshold in light
[WARNING]:Unused param threshold in light
[Warning]: Wrong type for background constant
[Loader]: Added camera MAINCAM
Using a world resolution of 0.00142857 per unit
Rendering with 5 raydepth
2 anti-alias passes and 4 minimum samples per pass, 8 samples total.
[Warning]: Background world_background does not exist
Building bounding tree ... OK
Light setup ...
Setting up lights ...
Finished setting up lights
Render pass: [########]
Saving Targa file as /tmp/YBtest.tga
OK
... and YBtest.tga is completely black. BTW this is the same in Linux as it is in IRIX. Seems the Yafray coders have their heads firmly in mr Gates' butt...
Can anyone provide me with a small working XML file so i can do some speed testing?
skywriter
Unread postby skywriter » Thu Jun 23, 2005 1:39 pm
now this thread is starting to make sense :)
GeneratriX
Standard Output
Unread postby GeneratriX » Thu Jun 23, 2005 3:44 pm
This is a normal output from Yafray V0.06, for comparation purposes... oh, and yup, complaining about the Python environment variables, that I must fix at some point in my system :roll:
Could not find platform independent libraries <prefix>
Could not find platform dependent libraries <exec_prefix>
Consider setting $PYTHONHOME to <prefix>[:<exec_prefix>]
'import site' failed; use -v for traceback
No installed Python found.
Only built-in modules are available.  Some scripts may not run.
Continuing happily.
Starting scene conversion.
Scene conversion done.
Yafray found at : /usr/local/bin/
Starting parser ...
[Warning]: Unknown camera attr type
[Warning]: Unknown camera attr dof_distance
Parsing OK
Loading plugins ...
Registered sunlight
Registered arealight
Registered hemilight
Registered spotlight
Registered blendershaders
Registered HDRI background
Registered basicblocks
Registered globalphotonlight
Registered spherelight
Registered mix block
Registered pathlight
Registered softlight
Registered sunsky
Registered photonlight
Registered pointlight
Registered basicshaders
[Loader]: Added shader MAMaterial
[Loader]: Added object OBCube
[Loader]: Added pointlight light LAMP1
[Loader]: Added sunlight light LAMP2
[Loader]: Added pointlight light LAMP3
[Loader]: Added sunlight light LAMP4
[Loader]: Added pointlight light LAMP5
[Loader]: Added constant background world_background
Using a world resolution of 0.00285714 per unit
No anti-aliasing.
Building the bounding tree ... OK
Launching 1 threads for rendering ...
Rendering ...
0%                 50%                 100%
Threads finished
Saving Targa file as /WareRoot/YBtest.tga
OK
Yafray completed successfully
Saved session recovery to /tmp/quit.blend
Blender quit
The generated XML file :
<scene>
<shader type="blendershader" name="MAMaterial" >
   <attributes>
      <color r="0.756191" g="0.756191" b="0.756191" />
      <specular_color r="1.000000" g="1.000000" b="1.000000" />
      <mirror_color r="1.000000" g="1.000000" b="1.000000" />
      <diffuse_reflect value="0.800000" />
      <specular_amount value="0.500000" />
      <hard value="50" />
      <alpha value="1.000000" />
      <emit value="0.000000" />
      <matmodes value="traceable shadow" />
   </attributes>
</shader>
<transform m00="1.000000" m01="0.000000" m02="0.000000" m03="0.000000"
           m10="0.000000" m11="1.000000" m12="0.000000" m13="0.000000"
           m20="0.000000" m21="0.000000" m22="1.000000" m23="0.000000"
           m30="0.000000" m31="0.000000" m32="0.000000" m33="1.000000">
<object name="OBCube" shadow="on"  shader_name="MAMaterial" >
   <attributes>
   </attributes>
   <mesh autosmooth="0.1" has_orco="on" >
      <points>
         <p x="1.000000" y="1.000000" z="-1.000000" />
         <p x="0.999999" y="1.000000" z="-1.000000" />
         <p x="1.000000" y="-1.000000" z="-1.000000" />
         <p x="0.999999" y="-0.999999" z="-1.000000" />
         <p x="-1.000000" y="-1.000000" z="-1.000000" />
         <p x="-1.000000" y="-0.999999" z="-1.000000" />
         <p x="-1.000000" y="1.000000" z="-1.000000" />
         <p x="-0.999999" y="1.000000" z="-1.000000" />
         <p x="1.000001" y="1.000000" z="1.000000" />
         <p x="1.000000" y="0.999999" z="1.000000" />
         <p x="-0.999999" y="1.000000" z="1.000000" />
         <p x="-1.000000" y="1.000000" z="1.000000" />
         <p x="-1.000000" y="-1.000000" z="1.000000" />
         <p x="-1.000000" y="-0.999999" z="1.000000" />
         <p x="1.000000" y="-1.000001" z="1.000000" />
         <p x="0.999999" y="-1.000000" z="1.000000" />
      </points>
      <faces>
         <f a="0" b="2" c="4" shader_name="MAMaterial" />
         <f a="4" b="6" c="0" shader_name="MAMaterial" />
         <f a="8" b="10" c="12" shader_name="MAMaterial" />
         <f a="12" b="14" c="8" shader_name="MAMaterial" />
         <f a="0" b="8" c="14" shader_name="MAMaterial" />
         <f a="14" b="2" c="0" shader_name="MAMaterial" />
         <f a="2" b="14" c="12" shader_name="MAMaterial" />
         <f a="12" b="4" c="2" shader_name="MAMaterial" />
         <f a="4" b="12" c="10" shader_name="MAMaterial" />
         <f a="10" b="6" c="4" shader_name="MAMaterial" />
         <f a="8" b="0" c="6" shader_name="MAMaterial" />
         <f a="6" b="10" c="8" shader_name="MAMaterial" />
      </faces>
   </mesh>
</object>
</transform>
<light type="pointlight" name="LAMP1" power="29.999983" cast_shadows="off" >
   <from x="0.000001" y="0.039670" z="10.092789" />
   <color r="1.000000" g="1.000000" b="1.000000" />
</light>
<light type="sunlight" name="LAMP2" power="1.000000" cast_shadows="off" >
   <from x="0.000000" y="0.000000" z="1.000000" />
</light>
<light type="pointlight" name="LAMP3" power="29.999983" cast_shadows="off" >
   <from x="0.047583" y="10.031761" z="0.005537" />
</light>
<light type="sunlight" name="LAMP4" power="1.000000" cast_shadows="off" >
</light>
<light type="pointlight" name="LAMP5" power="29.999983" cast_shadows="off" >
   <from x="0.047582" y="-10.047583" z="0.005538" />
</light>
<background type="constant" name="world_background" >
   <color r="0.056563" g="0.220815" b="0.400000" />
</background>
<camera name="MAINCAM" type="perspective" resx="320" resy="240"
   focal="1.093750" aspect_ratio="1.000000"
   dof_distance="0.000000" aperture="0.000000" use_qmc="on"
   bokeh_type="disk1" bokeh_bias="uniform" bokeh_rotation="0.000000" >
   <from x="6.282718" y="-5.000000" z="5.866797" />
   <to x="0.046017" y="-0.095082" z="-0.125717" />
   <up x="5.792415" y="-4.648865" z="6.664486" />
</camera>
<render camera_name="MAINCAM"
   raydepth="5" gamma="1.000000" exposure="0.000000"
   AA_passes="0" AA_minsamples="1"
   AA_pixelwidth="1.5" AA_threshold="0.05" bias="0.001000"
   background_name="world_background"
   <outfile value="/WareRoot/YBtest.tga" />
</render>
</scene>
These will give you a cube with the upper face hardly enlightened...
Unread postby dexter1 » Sun Jun 26, 2005 10:22 am
Oh Mr Diego, i think you might want to read this:
viewtopic.php?t=1826&start=112
GeneratriX
YafRay
Unread postby GeneratriX » Sun Jun 26, 2005 11:16 am
dexter1 wrote:Oh Mr Diego, i think you might want to read this:
Very cool Dexter!
...Now we can play again with raytraycing on Blender using the latest version of YafRay! I'll download now to give it a try. Thanks by the mention of the NekoWare thread... ;)
