Photoshop 6.0 for IRIX?!?
orionpi
Unread postby orionpi » Sun Feb 02, 2003 7:56 am
I was doing some digging for info on Photoshop under IRIX and found this:
http://www.sgi.com/products/appsdirectory.dir/apps/app_number272615.html
Has anyone else heard of Photoshop > 3.0.1 for IRIX? I called Adobe once for support (getting the flexLM key) on my copy of Illistrator 5.5, and the support person had never heard of Adobe making products for SGI.
bobflappy
Unread postby bobflappy » Sun Feb 02, 2003 8:22 am
this is a well known mystake on sgi's website...
And for Illustrator, Adobe doesn't support it any more since a lot of years! Your cd is useless unless you have the right license code for your machine.
You should check newsgroup comp.sys.sgi.* for more informations :wink:
