NetPBM jpeg->XPM
whiter
NetPBM jpeg->XPM
Unread postby whiter » Sun May 18, 2003 2:44 am
I am trying to convert a bunch of .jpg files into .xpm format so I can use them as background.
It is quite a bunch so I want to do it in a batch using NetPBM.
But when I try this on a file, using something like this:
jpegtopnm filename.jpg |  ppmtoxpm  > filename.xpm
It creates an invalid file. No program can read it.
What am I doing wrong?
Unread postby dexter1 » Sun May 18, 2003 6:08 am
'convert' from the imagemagick suite is much more flexible for this task. You can use convert in batch files, crop and scale on-the-fly, whatever...
whiter
Unread postby whiter » Sun May 18, 2003 6:52 am
NetPBM conversion to XPM is just broken. It's the only program that won't do it right. ImageMagick's convert indeed works well.
But when I give the '-scale 1280x1024' option, it converts my (1024x768) images to 1280x960. I understand that it's doing a uniform scale, but that's not what I want. I want it to scale it to the exact size I give in the commandline.
Unread postby dexter1 » Mon May 19, 2003 12:00 am
try -sample instead of -scale
