Indigo 2 Solid Impact graphics problem
jessedewaard
Unread postby jessedewaard » Mon Mar 14, 2016 1:25 pm
Hi, a couple of weeks ago i bought a Indigo 2 Impact just for the fun.
After some searching on internet i managed to install "IRIX 5.3 All Impact" on the machine and tried to get to the login screen.
The login screen however does not appear as i get a black screen after IRIX starts up(the screen works just fine before IRIX starts).
After some googling i managed to start IRIX without starting x, so to console as in single user mode.
When i run /usr/gfx/gfxinit the screen goes blank but the rest of the system runs just fine(i can still telnet for example).
gfxinfo gives a ? for the revision of GE11 (GE11 rev ?).
So my question is, is the graphics card broken or am i doing something wrong in IRIX?
Thanks
Re: Indigo 2 Solid Impact graphics problem
Unread postby robespierre » Mon Mar 14, 2016 2:55 pm
What hardware is in your machine? IRIX 5.3 All Impact doesn't support the 250MHz IP22 or any R8000 or R10000 machines.
jessedewaard
Unread postby jessedewaard » Tue Mar 15, 2016 3:23 am
Aha my Indigo 2 is indeed a 250Mhz version, but the system runs just fine exept for the graphics card.
Also i have narrowed it down (i think) to ucode loading of the GE11 as gfxinit gives an error on loading its code.
Should i install a different version of IRIX and if so which version?
Unread postby dexter1 » Tue Mar 15, 2016 3:34 am
Hi jesse,
From your answers i infer that IRIX 6.2 and IRIX 6.5 up to 6.5.22 supports your machine. But is it possible to give us the result of hinv -v from telnet? Alternatively, you can interrupt the boot proces with <esc> and go the the command line monitor (option 5). There you can also enter hinv -v
Oh, and please enter you location. Your name sounds Dutch and it would be nice to see where you live.
jessedewaard
Unread postby jessedewaard » Wed Mar 16, 2016 11:12 am
Hi dexter1,
I will try to find a copy of 6.2 as i only have 96MB of ram.
I there any way to start the X server without initializing the graphics board? i tried to startx without gfxinit but could not find a way.
This is the output of hinv -v running from IRIX 5.3:
IRIS 1% hinv -v
1 250 MHZ IP22 Processor
CPU: MIPS R4400 Processor Chip Revision: 6.0
On-board serial ports: 2
Data cache size: 16 Kbytes
Main memory size: 96 Mbytes
EISA bus: adapter 0
Tape drive: unit 2 on SCSI controller 0: DAT
Graphics board: Solid Impact
b.t.w. i am indeed from The Netherlands.
Unread postby SAQ » Thu Mar 24, 2016 9:32 pm
I am off and on trying to build a IRIX 5.3+XFS for All Indigo2 IMPACT including 2MB SC, and I've gotten it to install on High IMPACT but not work right on Solid IMPACT.
I looked into some things and noticed that High and Max IMPACT were the first cards released, followed by Solid. I can't recall the exact timing, but I think that 5.3 was early enough that I suspected that it may not have had Solid support. The difference would be meaningful as Solid lacks the texture hardware that High/Maximum have. Look at the brochure on Ian's site: http://www.futuretech.blinkenlights.nl/ ... actpg.html - it lists 250MHz R4k, but only High and Max IMPACT graphics.
Anyone have a definite date for Solid IMPACT release?
Unread postby dexter1 » Fri Mar 25, 2016 3:18 pm
I don't have a release date on Solid Impact, but found a hint in this old thread
Not sure you patched your system, but patch 1099 and 1157 seem to be required, especially 1099 which is adding support for software texture mapping on the Solid Impact.
Unread postby SAQ » Mon Apr 18, 2016 6:07 am
Dexter - do you know anything about Graphicd Rollup patch 1332? I can't get it to install on any of my boxes, it has a depends failure.
Unread postby dexter1 » Mon Apr 18, 2016 12:58 pm
Let's look at the Readme:
1.  Patch_SG0001332_Release_Note
       This release note describes patch SG0001332 to IRIX 5.3 for
       All Indigo2 Impact.  This is primarily a   bug fix   patch for
       the Impact product line.    All bug fixes from patch 1223 are
       included   in this   patch. Patch SG0001332 includes   support   for
       Indigo2 IMPACT Presenter. Patch SG0001332 also includes
       support for Square Pixel   Video Formats.   IMPORTANT: In order
       to use Presenter   or Impact Video, patch SG0001271 or a
       subsequent X Server patch is required in   addition to patch
       SG0001332.  Patch SG0001332 also   includes enhanced
       diagnostics features described below.
       1.1  Supported_Hardware_Platforms
       This patch contains bug fixes for the following Indigo2
       graphics   systems: Solid Impact, High Impact and Maximum
       Impact. The software cannot be installed   on other graphics
       hardware   configurations.    In order to use the optional
       Impact Video or Presenter hardware, patch SG0001271 (X
       Server patch) is   required with patch SG0001332.   Patch
       SG0001332 replaces the following   5.3 Indigo2 Impact patches
       : patch   SG0001099, patch SG0001105, and   patch SG0001223.
       1.2  Supported_Software_Platforms
       This patch contains bug fixes for IRIX 5.3 for All Indigo2
       Impact (version 1022585737).  It   can be installed on systems
       that are   running   IRIX 5.3 for All Indigo2 Impact.  The
       software   cannot be installed on other basic software
       configurations.   Patch SG0001332   can be installed on top   of
       patch SG0001099,   patch SG0001105   or patch SG0001223
       (SG0001332 is a superset   of all previous   5.3 Indigo2 Impact
       patches). It is compatible with patch SG0001271 (X Server)
       and patch SG0001157 (hardware inventory).
So it clearly states that it is a superset of previous 5.3 Indigo2 Impact patches, but it can only be installed on IRIX 5.3 All Indigo2 Impact (1022585737) so check if you actually have that. You probably need to check eoe.sw.base for its version number.
Apart from this i can't tell you anything more, since i'm unable to test it (don't have an Indigo2 R4K Impact system)
Reason: ocd again
