Live rendering for demonstration purposes
kraut
Unread postby kraut » Wed Aug 12, 2015 12:52 am
Hi all,
i work in a computer museum and own a Onyx 2 with the following specs:
onyx2 5# hinv
4 400 MHZ IP27 Processors
FPU: MIPS R12010 Floating Point Chip Revision: 3.5
Main memory size: 4608 Mbytes
Integral SCSI controller 2: Version Fibre Channel AIC-1160, revision 2
  Disk drive: unit 3 on SCSI controller 0
Integral SCSI controller 4: Version QL1040B (rev. 2), differential
Integral SCSI controller 6: Version QL1040B (rev. 2), single ended
Integral SCSI controller 5: Version QL1040B (rev. 2), differential
Integral SCSI controller 7: Version QL1040B (rev. 2), differential
Integral SCSI controller 3: Version Fibre Channel AIC-1160, revision 2
Integral SCSI controller 10: Version QL1040B (rev. 2), differential
Integral SCSI controller 8: Version QL1040B (rev. 2), differential
Integral SCSI controller 11: Version QL1040B (rev. 2), differential
Integral SCSI controller 9: Version QL1040B (rev. 2), differential
IOC3/IOC4 serial port: tty3
IOC3/IOC4 serial port: tty4
Graphics board: InfiniteReality2
Gigabit Ethernet: eg1, module 1, PCI slot 1, firmware version 0.0.0
Iris Audio Processor: version RAD revision 7.0, number 1
Origin FIBRE CHANNEL board, module 1 slot 8: Revision 4
Origin PCI XIO board, module 1 slot 2: Revision 4
Origin MSCSI board, module 1 slot 5: Revision 3
Origin MSCSI board, module 1 slot 10: Revision 3
Origin FIBRE CHANNEL board, module 1 slot 7: Revision 4
I'm searching for a rendering-project i can start to show the power of the system. I tried yesterday the homebrew slow spheres and I was able to start that animation. The problem is, that i can't use it for demonstration purposes.
Do you guys can give me a hint, if there is any rendering project for a live-demonstration i can use?
nongrato
Re: Live rendering for demonstration purposes
Unread postby nongrato » Wed Aug 12, 2015 6:30 am
There is a whole bunch of demo programs written for SGIs. Why not to try them?
http://www.youtube.com/channel/UCkq5rVM ... fhA/videos
kraut
Unread postby kraut » Wed Aug 12, 2015 7:10 am
Good idea, but where can i obtain such software?
nongrato
Unread postby nongrato » Wed Aug 12, 2015 11:03 am
They appear on ebay from time to time. Or you can PM me.
