elastic reality
elastic reality
Unread postby hamei » Thu Nov 13, 2014 1:32 am
Does Elastic Reality run on the 3000 series stuff ? Seems to me it used to work on the Fool (but that might have been in Octane years w/MXI) but when I try now (O350, V12 gfx) :
urchin 101% er
Bus error
urchin 102% er_anim
/usr/sbin/er_anim[4]: 1820 Bus error
Re: elastic reality
Unread postby foetz » Thu Nov 13, 2014 10:53 am
if it worked on the fuel it works on the o350, too. you might wanna run it from dbx and see what's the problem
Re: elastic reality
Unread postby hamei » Thu Nov 13, 2014 6:34 pm
foetz wrote:if it worked on the fuel ..
That's what I'm not sure about. Been a looong time since I tried to use it. Could have been on the Octane. I thought sure you'd be an er user :shock:
Re: elastic reality
Unread postby foetz » Thu Nov 13, 2014 9:30 pm
hamei wrote:I thought sure you'd be an er user :shock:
avid was pretty much at the end of the list of what i used. if i have some time over the weekend i'll give it a try
Re: elastic reality
Unread postby hamei » Fri Nov 14, 2014 12:11 am
foetz wrote:avid was pretty much at the end of the list of what i used.
Is there something else for morphing ? I did one or two things a long time ago with this, it was pretty easy (was doing simple stuff tho.)
I can see why you would not like Matador. That program makes DOS look good :shock: Good thing it works better than it looks !
nongrato
Re: elastic reality
Unread postby nongrato » Fri Nov 14, 2014 1:56 am
hamei wrote:Is there something else for morphing ?
Alias Composer:
http://www.youtube.com/watch?v=iOiAWmKHXVI
Apple Shake:
http://www.youtube.com/watch?v=whPGUVk4khc
:Octane2: :320:
Re: elastic reality
Unread postby foetz » Fri Nov 14, 2014 11:43 am
i actually used matador a little more because i simply had no need for ER. morphing was either a default part of the compositing programs or by plugin
Re: elastic reality
Unread postby foetz » Mon Nov 17, 2014 2:14 pm
alright, checked it out and it worked fine; the demo version tho.
anyhow it wasn't flawless. turned out to be incomplete inst prereqs:
if you install er with the required dependencies the following happens:
Can't find 'loaders' file in HIIP directory '/var/avid/hiip'.
running er_anim leads to:
er_anim[4]: 1973 Memory fault
the regular er produces a proper error telling what's missing. er_anim however doesn't and just crashes. obviously the missing hiip parts are the problem. here's what i had installed at the end (working fine then):
I  avid                 1001003000  Avid Admin, 1.3
I  avid.sw              1001003000  Avid Admin Software
I  avid.sw.lib          1001003000  Avid Support Libraries
I  er                   1003000009  Elastic Reality, 3.0
I  er.sw                1003000009  Elastic Reality Software
I  er.sw.er             1003000009  Elastic Reality Software
I  hiip                 1001006008  HIIP, 1.6.8
I  hiip.sw              1001006008  HIIP Software
I  hiip.sw.hiip         1001006008  HIIP Support Utilities
I  hiip.sw.lib          1001006008  HIIP Libraries
I  hiip.sw.loaders      1001006008  HIIP Loaders
I  hiip.sw.savers       1001006008  HIIP Savers
Re: elastic reality
Unread postby hamei » Mon Nov 17, 2014 5:45 pm
foetz wrote:alright, checked it out and it worked fine; the demo version tho. anyhow it wasn't flawless. turned out to be incomplete inst prereqs
Ooh ! Ooh ! Ooh ! Gracias muchas for checking on that Mr Foetz, I'll go look at my installation now, then report back.
nongrato
Re: elastic reality
Unread postby nongrato » Thu Dec 04, 2014 4:24 pm
Btw, HIIP from the Hotmix#18 CD seems to be fine.
:Octane2: :320:
Re: elastic reality
Unread postby hamei » Thu Dec 04, 2014 5:29 pm
nongrato wrote: HIIP from the Hotmix#18 CD ...
Eighteen, you say ? Thanks !
Yes, hiip was missing, I just haven't had enough spare time to go hunt up that CD. Now that I know which one, it should only take three days instead of three weeks :P grazie
What do you think of it, ingrate ?
nongrato
Re: elastic reality
Unread postby nongrato » Sat Dec 06, 2014 2:28 pm
well, you can do some stuff even with demo version:
http://itmages.ru/image/view/2095310/d54433da (6mb gif)
:Octane2: :320:
Re: elastic reality
Unread postby foetz » Sat Dec 06, 2014 2:40 pm
Eighteen, you say ?
it should be on the cd from avid or whatever other source you have since it's needed to run the thing
Re: elastic reality
Unread postby hamei » Sat Dec 06, 2014 8:10 pm
foetz wrote:it should be on the cd from avid or whatever other source you have since it's needed to run the thing
Ja, if I didn't have more CD's than Carter has liver pills, I could find it instantly :( I think I copied it over from the Octane, actually. It's been a while ...
nongrato wrote:well, you can do some stuff even with demo version: ...
Cute ! I hope that lady likes cats tho, or you are in big trouble :P
