Pretty - a few new desktop backgrounds for IRIX
jimmer
Unread postby jimmer » Fri Jun 27, 2014 9:14 am
Hi All,
I pulled apart my spare Fuel the other day and took the opportunity to take some piccies and make the backgrounds you can see below. The Fuel ones are 1920x1080 and the generic SGI (r16k cpu board) ones are both 1920x1080 and 1280x1024. I also got round to making an clogin icon for 'root' to match the EZsetup one I made a decade ago.
The tardist installs a little script each user needs to run to install these new backgrounds to the 'backgrounds' panel in their toolchest. After installing Pretty via the Software Manager, run
/usr/sillypages/bin/pretty
from a terminal prompt. Pretty is semi-clever about backing up your current $HOME/.backgrounds file before it adds the new background details. However, if you uninstall Pretty via the Software Manager you'll have to copy $HOME/.backgrounds.old back to $HOME/.backgrounds by hand. I guess I could automate that too but me lazy.
If you have a custom root icon the tardist does a similar backup thing and copies your current root login icon to
/.icons/login.icon.old
When you uninstall Pretty, Software Manager will restore your old root login icon.
Tardist is here:
http://www.sillypages.org/sgi/sp_pretty.tardist
Caveat: Tested only on my Fuel with a V12 and 4Gb RAM. No idea what these (large) background images may or may not do to X11 colormaps or memory on other systems.
J.
:Fuel: redbox 800Mhz 4Gb V12
Re: Pretty - a few new desktop backgrounds for IRIX
Unread postby foetz » Fri Jun 27, 2014 11:10 am
thanks that's neat. especially fuel owners should dig it :D
jirka
Unread postby jirka » Sat Jun 28, 2014 11:16 pm
jimmer wrote:Caveat: Tested only on my Fuel with a V12 and 4Gb RAM. No idea what these (large) background images may or may not do to X11 colormaps or memory on other systems.
Nice backgrounds, thanks! So far no problems on my O2 with 1600SW :-)
Unread postby vishnu » Sun Jun 29, 2014 1:21 am
Very decorative! Thanks a bunch... :mrgreen:
canavan
Unread postby canavan » Mon Jun 30, 2014 1:22 pm
Nice backgrounds, but apparently the subsystem with the exitop script is optional and the exitop for the images fails when it's not installed:
Pre-installation check completed
Installing new versions of selected sp_pretty.art subsystems
Assigning id 60000 to unknown user/group name avi
sp_pretty.art.icons: ( /usr/sillypages/bin/root_icon_install )
/bin/sh: /usr/sillypages/bin/root_icon_install:  not found
ERROR: An error occurred while:
Command "( /usr/sillypages/bin/root_icon_install )" failed (return status 127, subsystem sp_pretty.art.icons 20147)
Removing orphaned directories
jimmer
Unread postby jimmer » Thu Jul 10, 2014 7:22 am
ah - nice catch :) How do i make a subsystem mandatory?
canavan
Unread postby canavan » Sun Jul 27, 2014 3:08 pm
You need a prereq section that defines the dependencies. For example, in the neko_imagemagick package, the sw.eoe component doesn't work without the sw.lib bits:
    image sw
        id "software"
        version 17
        order 9999
        subsys eoe default
            id "execution only env"
            replaces self
            prereq (
                neko_imagemagick.sw.lib 17 maxint
            exp neko_imagemagick.sw.eoe
        endsubsys
modology
Unread postby modology » Sun Jul 27, 2014 4:48 pm
Nice stuff dude.
@PymbleSoftware: I need to visit my old friend to capture his SGI collections and put up some beauty shots for archiving purposes.
jimmer
Unread postby jimmer » Mon Jul 28, 2014 12:29 am
@canavan - thanks! will apply this with the next release of Pretty.
khalidschofield
Unread postby khalidschofield » Mon Jan 26, 2015 2:59 am
What are the command line options to use this? Mine opens shows a splash screen, creates the .backgrounds file then pretty closes.
Re-install with OpenBSD :)
jimmer
Unread postby jimmer » Sat Apr 11, 2015 5:17 am
@khalidschofield - sorry for late late response. Pretty is a bit blond I'm afraid, there's no actual binary and no command-line options. It's just a script that pops-up a splash on install, copies some background images to your machine and then modifies your backgrounds index file so you can set the copied images as a background using the stock background control panel. (Desktop->Customise->Background).
