Eclipse problems
Eclipse problems
Unread postby hamei » Fri Jan 10, 2014 4:15 am
Is anyone running Eclipse successfully on VPro ? I know it used to be fine on MXI, but tried it recently on a V12. It starts but that's about it. Windows full of garbage, can't open files, freezes with just the window frame showing, big mess.
Adrenaline
Re: Eclipse problems
Unread postby Adrenaline » Fri Jan 10, 2014 5:29 am
hamei wrote:Is anyone running Eclipse successfully on VPro ? I know it used to be fine on MXI, but tried it recently on a V12. It starts but that's about it. Windows full of garbage, can't open files, freezes with just the window frame showing, big mess.
Was using it for a old Java project on my Tezro with no issues, I assume you are running the latest version available?
:Indigo: 33mhz R3k/48mb/XS24 :Indy: 150mhz R4400/256mb/XL24 :Fuel: 600mhz R14kA/2gb/V10 Image 8x1.4ghz Itanium 2/8GB :O3x08R: 32x600mhz R14kA/24GB :Tezro: 4x700mhz R16k/8GB/V12/DCD/SAS/FC/DM5 (2x) :O3x0: 4x700mhz R16k/4GB :PrismDT: 2x1.6ghz 8mb/12gb/SAS/2xFGL
Unread postby foetz » Fri Jan 10, 2014 6:54 am
which eclipse do you mean? the ide or the 2d drawing program?
Geoman
Unread postby Geoman » Fri Jan 10, 2014 8:30 am
I have got the Eclipse-Demo-Software (from form&vision), which is limited to 1600x1200 images. On my former Octane/MXE it ran fine, on Octane2/Vpro the splash-screen is blank and there are errors in the software as you describe above.
Unread postby foetz » Fri Jan 10, 2014 5:42 pm
no probs here, the following screen shot i just made with a v12
Eclipse 3.1.3
Unread postby hamei » Fri Jan 10, 2014 6:37 pm
Geoman wrote:I have got the Eclipse-Demo-Software (from form&vision), which is limited to 1600x1200 images. On my former Octane/MXE it ran fine, on Octane2/Vpro the splash-screen is blank and there are errors in the software as you describe above.
foetz wrote:no probs here, the following screen shot i just made with a v12
I am in the Geoman camp right now. How to get over to the foetz side ?
Unread postby foetz » Fri Jan 10, 2014 8:36 pm
hamei wrote:I am in the Geoman camp right now. How to get over to the foetz side ?
hehe, seems that's a tricky one. let's compare the rigs, maybe we can find a common difference. mine: onyx350, v12, 6.5.30, all patches except for the one that crashes efs (7207 iirc).
maybe important: i'm using the 8bit settings because some older stuff has issues otherwise but nothing even close to what you described.
i do recall tho that i also used it with an octane2/v6. actually i don't remember ever having the mentioned issues. i don't use it much tho but since it doesn't even start right i think i'd remember such a major problem.
Unread postby hamei » Fri Jan 10, 2014 11:50 pm
foetz wrote:[ maybe we can find a common difference. mine: onyx350, v12, 6.5.30, all patches except for the one that crashes efs (7207 iirc).
Same result on both a Fuel V10 and V12 and an Onyx350 w/V12 and V10. I remember it running on the Octane with an MXI.
Hmm. Where did you do that ? My frame buffer is 8 and accumulation buffer is software only, due to a lack of memory.
You would remember. It's unusable. It sort-of starts but that's about all.
Unread postby foetz » Sat Jan 11, 2014 8:27 am
hamei wrote:Where did you do that
ah never mind, that's not it. i tried different combinations and it always was fine.
ldd looks like:
        libXsgivc.so  =>         /usr/lib/libXsgivc.so
        libC.so  =>      /usr/lib/libC.so
        libXm.so.1  =>   /usr/lib/libXm.so.1
        libXt.so  =>     /usr/lib/libXt.so
        libXext.so  =>   /usr/lib/libXext.so
        libGL.so  =>     /usr/lib/libGL.so
        libX11.so.1  =>  /usr/lib/libX11.so.1
        libXi.so  =>     /usr/lib/libXi.so
        libGLU.so  =>    /usr/lib/libGLU.so
        libm.so  =>      /usr/lib/libm.so
        libgen.so  =>    /usr/lib/libgen.so
        libc.so.1  =>    /usr/lib/libc.so.1
        libGLcore.so  =>         /usr/lib/libGLcore.so
so mine is o32. maybe you don't have the classic LD_LIBRARY_PATH set? or maybe also set it to lib32?
yet another idea could be vswap. there's an "IncreaseVSwap" script in the bin dir. sometimes vswap is off because some programs complain while others complain about not having vswap on :P
Unread postby recondas » Sat Jan 11, 2014 1:16 pm
Works on my V12/6.5.30 Octane....
.....but not my Tezro - though it used to, there's a sub-directory on the Tezro with files opened/editied in Eclipse.
Differences? The Tezro has been the test bed for the latest-greatest nekoware candidates, the Octane progressively less since I got the Tezro. As an example, the Tezro is running Firefox 3.0.19 (and all of the updated apps/libraries that go with FF3), while the Octane still runs 2.0.0.22pre.
Unread postby foetz » Sat Jan 11, 2014 2:32 pm
recondas wrote:Differences? The Tezro has been the test bed for the latest-greatest nekoware candidates, the Octane progressively less since I got the Tezro. As an example, the Tezro is running Firefox 3.0.19 (and all of the updated apps/libraries that go with FF3), while the Octane still runs 2.0.0.22pre.
ah yes, maybe something from nekoware gets in between. that'd also makes sense why it works for me because i have hardly any nekoware installed. firefox 3 does work there too tho.
on the other hand no nekoware should be part of LD_LIBRARY_PATH so it'd have to be something else except the libs.
Unread postby hamei » Sun Jan 12, 2014 12:18 am
foetz wrote:ah yes, maybe something from nekoware gets in between.
fool 10% ldd Eclipse
Hmmm :(
Good to know that it did work on tezro at one time tho ... the search continues :?
You need some ape hangers for that thing, wreck :P
Unread postby foetz » Sun Jan 12, 2014 9:02 am
ldd likely won't show the problem because:
foetz wrote:no nekoware should be part of LD_LIBRARY_PATH so it'd have to be something else except the libs.
Unread postby hamei » Sun Jan 12, 2014 8:36 pm
I'll try running it as another user without nekoware in the path, too ...
Meanwhile, a few things ...
I'm not running EcWatch. Don't know if that matters, seems like it shouldn't ?
Made a /usr/bin/X11/netscape link to fireflop, so Help works
the scratch file is at /usr/tmp per their setup
it opens okay except the initial splash screen is blank but that could be that it's looking in the wrong place (been relocated a few times)
I can't set the cache size larger than 0. It takes the number, hit "okay", it pops up a warning "won't take effect until restarted" then a restart gives me a cache of 0 again
Restarted from a terminal, everything looks okay but if you open a file (jpeg) then it sits there forever. Terminal shows
fool 22% /usr/Eclipse/bin/ecio:WARNING -p Not Option
/usr/Eclipse/bin/ecio:WARNING /usr/people/graphicsguy/beach.jpg.pxy Not Option
fool 23% ecio
Usage: ecio in_file_name  options...
       Version 3.1.3
       OPTION   PARAM                    DEFAULT
       -dev     device_name              SCREEN
       -input_type  device_name
                file formats: alias, sgi_image, wavefront
                              ct2t, handshake_ct
                              ddes_ct, chromalink_ct
                              targa, compressedtarga, targa16
                              PostScript, ColorPostScript
                              PostScriptSeps, Tiff,
                              Cmyk_Tiff, Tiled_rgb, Tiled_cmyk
                              Mask, Tiled_mask,ppm_raw,ppm_asc,pgm_raw,                              pgm_asc,Irisgraphics,Photoshop_Native
      -job      job_name                 path of source image
      -vol      volume_name              volume label for tapes
      -picture  picture_name             output image name
      -xo       x crop start             0
      -yo       y crop start             0
      -xc       x crop len               picture x max
      -yc       y crop len               picture y max
      -xloc     x start location         center_image
      -yloc     y start location         center_image
      -xlen     x len                    picture_dependant
      -ylen     y len                    picture_dependant
      -xres    dot/mm x some formats     12
      -yres    dot/mm y some formats     12
      -o       output_filename           NONE
      -gamma   gamma correction          1.0 (no change)
      -r/g/bfac r,g,or b multipliers     1.0 (no change)
      -r/g/badr r,g,or b adders            0 (no change)
      -sep     Separation param. file    NONE
      -tape_device  tape device name     /dev/9track
      -lut     Look up table             NONE
       256 rows of 5 integers:
       index (0-255)  r_or_c  g_or_m  b_or_y   k
      -command_arg   command_to_execute
      -silent
      -stat        none
hmm.
Help -> System Info shows System Type IP35 and Graphics IP35
also hmmm ?
Finally the program returns to normal, it thinks it is displaying a graphic and allows you to do some operations but like Oakland, there's no there there ...
Unread postby foetz » Sun Jan 12, 2014 9:07 pm
alright so under a different account it does at least come up. by that we can see that the problems are at least partially because of certain settings.
something trivial i didn't think of yet: resolution. do you run the irix default 1280x1024 or something else?
