a lightweight jpeg viewer
Unread postby hamei » Wed Dec 18, 2013 5:14 am
Imgviewer is fine for me but sometimes I want to page through a folder of photos. Imgview is a pita for that. So went looking ...
Pho is very lightweight - only uses keystrokes to control it, not even the most basic menu items. But it does a ton of simple stuff fast. And I can page through a whole folder looking for the photo I want. Can also delete ones you don't want and mark them, rotate them, bunch of other stuff. If you enter pho -v you'll get a listing of the key commands.
The lady who wrote it also did swmgr :D her address is in the zipfile, if you like it write her and say thanks. And if it's screwed up, my fault. It's not a tardist, if it doesn't work for you, here's the requirements
fool 34% ldd pho
        libgtk-x11-2.0.so.1  =>  /usr/nekoware/lib/libgtk-x11-2.0.so.1
        libatk-1.0.so.1  =>      /usr/nekoware/lib/libatk-1.0.so.1
        libgio-2.0.so.1  =>      /usr/nekoware/lib/libgio-2.0.so.1
        libgdk-x11-2.0.so.1  =>  /usr/nekoware/lib/libgdk-x11-2.0.so.1
        libgdk_pixbuf-2.0.so.1  =>       /usr/nekoware/lib/libgdk_pixbuf-2.0.so.1
        libpangocairo-1.0.so.1  =>       /usr/nekoware/lib/libpangocairo-1.0.so.1
        libpango-1.0.so.1  =>    /usr/nekoware/lib/libpango-1.0.so.1
        libcairo.so.3  =>        /usr/nekoware/lib/libcairo.so.3
        libgobject-2.0.so.1  =>  /usr/nekoware/lib/libgobject-2.0.so.1
        libgmodule-2.0.so.1  =>  /usr/nekoware/lib/libgmodule-2.0.so.1
        libgthread-2.0.so.1  =>  /usr/nekoware/lib/libgthread-2.0.so.1
        libglib-2.0.so.1  =>     /usr/nekoware/lib/libglib-2.0.so.1
        libintl.so.9  =>         /usr/nekoware/lib/libintl.so.9
        libXrender.so.1  =>      /usr/nekoware/lib/libXrender.so.1
        libz.so.1  =>    /usr/nekoware/lib/libz.so.1
        libiconv.so.3  =>        /usr/nekoware/lib/libiconv.so.3
        libXi.so  =>     /usr/lib32/libXi.so
        libfontconfig.so.2  =>   /usr/nekoware/lib/libfontconfig.so.2
        libpangoft2-1.0.so.1  =>         /usr/nekoware/lib/libpangoft2-1.0.so.1
        libfreetype.so.7  =>     /usr/nekoware/lib/libfreetype.so.7
        libfastm.so  =>  /usr/lib32/libfastm.so
        libpixman-1.so.1  =>     /usr/nekoware/lib/libpixman-1.so.1
        libpng12.so.0  =>        /usr/nekoware/lib/libpng12.so.0
        libz.so  =>      /usr/nekoware/lib/libz.so
        libexpat.so.2  =>        /usr/nekoware/lib/libexpat.so.2
        libbz2.so.1.0  =>        /usr/nekoware/lib/libbz2.so.1.0
        libpng.so.3  =>  /usr/nekoware/lib/libpng.so.3
Complaints are accepted but they better be simple, I'm not that great at fixing stuff ...
pho.zip
(81.67 KiB) Downloaded 52 times
Geoman
Re: a lightweight jpeg viewer
Unread postby Geoman » Wed Dec 18, 2013 6:47 am
Unix Software Consultant, Silicon Graphics, Mountain View, CA, 10/92 - 11/95.
o Key contributor on IRIX 5.3 installation tools, inst and Software Manager.
o Developed C++ classes implementing network protocols, tape support, and HTML web support.
o Designed and wrote the command-line query programs showfiles and showprods.
o Conceived and implemented tardist, the first widely-used Web-based software installation program.
o Designed and implemented an HTTP-based protocol for installation of large software packages over the internet.
o Developed the user interface for SGI's first graphical installation tool, Software Manager.
o Contributed enhancements and bug fixes to SGI's enhanced Motif library.
http://www.shallowsky.com/resume.html
:shock: WOW! That was a major contribution to IRIX
Unread postby foetz » Wed Dec 18, 2013 8:05 pm
and the rest of the resumee is nothing less impressive :D
sort of hurts a bit to see someone like that messing around with gtk2 :P
much thanks anyway, grabbing it right now ...
Unread postby hamei » Thu Dec 19, 2013 8:37 pm
foetz wrote:sort of hurts a bit to see someone like that messing around with gtk2 :P
Tyranny of the majority :( If you are throwing something together for a quick utility, are you going to fight City Hall ?
I've been using it the past few evenings ... Mikey likes it. Directories that I've never got around to sorting, been next -> next -> nexting through the photos and quickly d-eleting the junk ones and duplicates. Even if I just use it for that, it's handy.
jirka
Unread postby jirka » Fri Dec 20, 2013 5:28 am
hamei wrote:Pho is very lightweight - only uses keystrokes to control it, not even the most basic menu items. But it does a ton of simple stuff fast.
Thanks much! It's fast enough even on my O2!
:O2: :O2: :1600SW: :1600SW: :Indy: :Indy: :Indigo: :Indigo:
Unread postby foetz » Fri Dec 20, 2013 9:11 am
not to forget xnview which runs pretty well as well. even on 5.3.
