GopherVR port to IRIX
Unread postby ClassicHasClass » Fri Mar 01, 2013 8:35 pm
For those of you unfamiliar with GopherVR, visit http://www.floodgap.com/software/gophervr/ (Gopher-compatible client strongly advised; Firefox 3 will suffice :D as will OverbiteFF for Firefox 4+/TenFourFox/SeaMonkey). Originally only available for classic Mac OS, the source code finally resurfaced whole in 2009. I ported it to OS X, and another user fixed it up for Linux, but the Irix port didn't work ... until this evening. With some hacking it now builds and appears to work normally with MIPSPro 7.4.4m on IRIX 6.5.mumble. At 1024x768 this R4400 Indy manages around 8-10fps (all in software).
http://www.floodgap.com/iv/1830
Before I release source and a MIPSIII-compatible binary, a few notes:
- libtracker doesn't seem to work. I have libaudio.so, but I'm missing /usr/include/dmedia. Was this on the IRIX CDs? Which package/CD am I looking for? Right now it just builds a dummy module with no audio, but it *should* work.
- Which is the preferred image viewer for IRIX that people like?
Re: GopherVR port to IRIX
Unread postby vishnu » Fri Mar 01, 2013 11:04 pm
So it's a 3D viewer for gopher file listings, like the one Lex used in Jurassic Park?
The IRIX default image viewer, followed by XV, then Photoshop, failing that I use my Linux box... :mrgreen:
Unread postby hamei » Sat Mar 02, 2013 2:27 am
vishnu wrote:The IRIX default image viewer, followed by XV, then Photoshop, failing that I use my Linux box... :mrgreen:
vishnu, vishnu, vishnu ... what're we gonna do with you ? Linux ? You'll go blind doing that :shock:
Go to /beta, grab the graphics magick tardist and install.
< gm display filename > will open a window displaying the file you ask for.
Or < gm display > will hop up a frog. Click on his window, you'll get a menu of choices. Lots of choices. Graphics Magick will display and manipulate just about anything. (XBM and XPM as well as all the modrun stuff, for instance.)
I agree that imgview is probably the best choice. Comes with Irix and displays just about any graphic you want. It's also fast.
duck
Unread postby duck » Sat Mar 02, 2013 5:22 am
ClassicHasClass wrote:- Which is the preferred image viewer for IRIX that people like?
Surely you should use whatever we set as our preference, system environment variable $IMGVIEWER:
Default 4DWM utilities
___(o)=
\____)
Unread postby ClassicHasClass » Sat Mar 02, 2013 8:50 am
Oh, even better. I'll just throw a getenv("IMGVIEWER") in there then.
Yep, except it's better: you move around in it like a FPS, double clicking on elements to interact with them. You can even jump up in the air to see an overhead view.
Unread postby ClassicHasClass » Sat May 11, 2013 7:33 pm
I didn't get around to fixing the preferences yet, there's still no audio, and the help system has a subtle buffer overflow bug that I can't figure out (so it's temporarily disabled), but it doesn't crash anymore, so you can try a binary of it. Firefox 3 on Irix will speak gopher, or you can use cURL, or OverbiteFF with Firefox 4+, SeaMonkey 2.1+ or TenFourFox. Built on my 6.5.10 Indy with MIPSPro. Runs fine on the Fuel with 6.5.30. The G5, however, spanks both of them in frame rate. Interestingly, the Indy will drive the G5's 1080p display over X11 over the network at nearly 24fps, implying that display speed is fill-rate-limited.
Make sure that futura.hfont and gophervr.help are in the same directory, or see INSTALL. If people like it, I'll see about making it nekoware-aware. It has no prerequisites and should run on any Irix 6.5 machine.
gopher://gopher.floodgap.com/9/gophervr ... rix.tar.gz
I'm waiting for my Arch Linux porter to sign off, and then there will be source, too.
jirka
Unread postby jirka » Sun May 12, 2013 9:09 am
Thanks! It works on my O2 (R10k/250, IRIX 6.5.27) very well! The framerate is about 15fps.
jirka
Unread postby jirka » Sun May 12, 2013 9:56 am
jirka wrote:Thanks! It works on my O2 (R10k/250, IRIX 6.5.27) very well! The framerate is about 15fps.
I added these lines to mu ~/.Xdefaults and it now looks like other SGI apps:
gophervr*sgiMode:       true
gophervr*useSchemes:    all
gophervr*Background:    gray85
The screenshot from my O2 is here: http://www.flickr.com/photos/7958754@N03/8731392645/
Unread postby ClassicHasClass » Sun May 12, 2013 5:59 pm
Yes, that looks much better. I'll look at making this default in the app as well. Thanks for testing it out.
canavan
Unread postby canavan » Sun May 19, 2013 11:18 am
It should not be necessary to set the *Background explicitly, it should just be taken automatically from the scheme.
Unread postby ClassicHasClass » Sat Feb 07, 2015 9:04 pm
I didn't get around to these Irix fixes (the biggest priority was getting it working again with XQuartz on OS X), but there are lots of general fixes in 0.5.0, and there is an Irix binary of that. Tested on the Indy and the Fuel, built with MIPSPro.
gopher://gopher.floodgap.com/1/gophervr
Notice the oozing sex
Unread postby vishnu » Sun Feb 08, 2015 11:18 am
Ha ha motif blue, yeesh! Shades of 1994.
No way to free the source yet? :?:
Unread postby ClassicHasClass » Sun Feb 08, 2015 6:28 pm
Unread postby hamei » Sun Feb 08, 2015 6:44 pm
ClassicHasClass wrote: ... there is an Irix binary of that. Tested on the Indy and the Fuel, built with MIPSPro.
You really know how to hurt a guy :(
Resolving gopher.floodgap.com... 66.166.122.165
Connecting to gopher.floodgap.com|66.166.122.165|:80... connected.
HTTP request sent, awaiting response... 403 Blacklisted
2015-02-09 10:40:58 ERROR 403: Blacklisted.
edit : the flop finally got it. 33.6 baud modem, here we come :D
Another triumph for Irix, thank you !
If you want to get rid of the blue, your standard xdefaults should do the trick. I didn't do anything to gopher, just opened it.
If you made it work with a spaceball, that would be cool, Mr Classy. Spaceballs are grrrrr-ate for 3d manipulation.
Unread postby ClassicHasClass » Sun Feb 08, 2015 10:07 pm
Port 80? Gopher's on 70!
What do you mean, a spaceball?
