Pixie for IRIX
competentcompton
Pixie for IRIX
Unread postby competentcompton » Sun Apr 11, 2010 2:52 am
Hi,
I have completed a first pass at porting the pixie renderer to irix. I only have a n32 version which I have done initial testing on with a fuel and a origin 300 both running Irix 6.5.30.
Is anyone interested in this being packaged as a nekoware package?
Firstly I have yet to get confirmation from the author that he does not object to this port being distributed to the irix community on nekochan but I would guess that he would not.
Secondly I only have a .tar of the port. Would anyone be willling to help me create a .tardist for nekoware. This is the part that I most dislike doing and so I would very much appreciate if someone would offer to take a binary install and package it up for me.
I know - this last one is a bit lame but I am busy with other things and the tardist packaging os not high on my list of todos.
Cheers
competentcompton
Re: Pixie for IRIX
Unread postby competentcompton » Sun Apr 11, 2010 2:52 pm
yes
go here
www.renderpixie.com
Why? does this exist already?
competentcompton
Re: Pixie for IRIX
Unread postby competentcompton » Sun Apr 11, 2010 4:13 pm
Like I said it is compiled and seems to be working ok.
I can tarball it but I don't have time to put a neko package together..
Maybe I will in a few weeks but if someone could offer to package it up that would be really kind of them.
Possibly I could put the tarball out on the neko ftp site?
Cheers
Sacrifist
Re: Pixie for IRIX
Unread postby Sacrifist » Sun Apr 11, 2010 5:33 pm
This I gotta see! Waiting with baited breath!
Simon
Ryan Fox
Re: Pixie for IRIX
Unread postby Ryan Fox » Mon Apr 12, 2010 6:46 am
I second that!
MAYA, nut-
cryz
Re: Pixie for IRIX
Unread postby cryz » Mon Apr 12, 2010 9:06 am
another vote! thanks in advance competentcompton!
Former: :O2: R10000 | :540: | :O2: 600Mhz | :O2: R5000
Plastic City is back!!! >>> http://www.plasticcity.de
tomo
Re: Pixie for IRIX
Unread postby tomo » Mon Apr 12, 2010 12:35 pm
another vote.
But I have question also - since I'v never used any other than genuine renderer witch is addedet with modeling sw, how I can feed this thing with datas? It will be *nice* if it can read maya v5.0 scenes but I don't think so.
So what is the options - thanks...
http://www.tomosgi.co.cc
canavan
Re: Pixie for IRIX
Unread postby canavan » Mon Apr 12, 2010 3:04 pm
If you have a tar, you've already done half the work to make a nekoware tardist.
Unpack the enclosed neko_pixie_kit.tar in an empty directory, run ./dependify.sh on the main binary, e.g. ./dependify /usr/nekoware/bin/pixie, paste the result in the appropriate seciion while editing the relnotes and the dist/neko_pixiespec file, stick your patches in patches/, the source in src/, put the list of files/directories in a file called ./files (tar -tvf pixie_irix.tar | cut -b 52-, should be the full path to the instlalled files, starting with /), run "./idbify.sh neko_pixie", put the neko_pixie.idb in dist, change to dist, run swpkg, File/Open/Both, save both, open them again, then change to the build product pane, adjust the Distribution Directory to somewhere where you can warite, Test Build, Build All, the tar the neko_pixie* in the destination directory into a neko_pixie-2.2.6.tardist.
neko_pixie_kit.tar
(20 KiB) Downloaded 86 times
PymbleSoftware
Re: Pixie for IRIX
Unread postby PymbleSoftware » Mon Apr 12, 2010 3:44 pm
eMGee wrote:Pixie as in the RenderMan implementation?
I take it that no one has the IRIX version of BMRT floating around...
http://web.archive.org/web/200202070511 ... index.html
死の神はりんごだけ食べる
開いた括弧は必ず閉じる -- あるプログラマー
Twitter @PymbleSoftware
competentcompton
Re: Pixie for IRIX
Unread postby competentcompton » Tue Apr 13, 2010 3:10 am
Hi,
ok I will try to put together a .tardist. But for impatient amongst you I am including the .tar.gz of the compiled pixie package.
I installed this into /usr/local/pixie and it will untar into pixie/
Hope this lets you all have a play until I can get the .tardist together.
Cheers
pixie.tar.gz
(6.46 MiB) Downloaded 105 times
GeneratriX
Re: Pixie for IRIX
Unread postby GeneratriX » Tue Apr 13, 2010 7:29 am
canavan wrote:If you have a tar, you've already done half the work to make a nekoware tardist.
After many weeks beeing bussy here, and reading this thread, I was about to offer myself to create the tardist... but after seeing the way you solved it... well... I have to accept you always show up with a very classy solution for all! :)
BTW: nice to see Pixie for IRIX!
Re: Pixie for IRIX
Unread postby nekonoko » Tue Apr 13, 2010 8:48 am
eMGee wrote: maybe we could mirror it on here too?
BMRT has been mirrored on my FTP for years.
Oskar45
Re: Pixie for IRIX
Unread postby Oskar45 » Tue Apr 13, 2010 11:21 am
I only run version 2.4.0.5, but with the help of the standard textbooks you still might achieve quite impressive results, anyhow ;)
Honorable member of the International Procrastinator's Society
competentcompton
Re: Pixie for IRIX
Unread postby competentcompton » Tue Apr 13, 2010 5:22 pm
I just wanted to add that it will not render to a framebuffer with a depth of less than 15.
So for example on my fuel (v10) which I have running at 1600x1200 x8 I can only get file as output.
Whereas when I login into my o300 with Xming it does render to the framebuffer as the visual depth is 24.
I thought I would mention this as pixie does not tell you this is just does nothing and like me you might think it is not working (at least you won't spend an hour trying to debug it like someone I know ... ;)
You will also need OpenEXR and FLTK along with the usual tif libraries etc. from nekochan.
It is supposedly multi-threaded maybe one of you guys witha big iron might like to throw a good number of cpus at it to see how well its multi-threaded model holds up (oh yeah and also to see how the port does also).
Cheers
deBug
Re: Pixie for IRIX
Unread postby deBug » Wed Apr 14, 2010 9:25 am
http://se.mirror.nekoware.net/SGI_Info/ ... other.html
Mein Führer, I can walk!
