Period Comparison of Onyx(1) IR and Commodity Graphics
Unread postby recondas » Thu Dec 24, 2009 8:54 am
Ran across this web page <with a date of August 2000> that does some limited comparisons of the triangles per second and fill rate performance of an IR equipped Onyx(1) and several period PCs with commodity graphics cards running linux. While the author acknowledges the tests weren't meant to be anything other than a superficial comparison <"The exact numbers given by tenmillion are almost as meaningless as a CPU's MIPS rating, but they do give some idea of the relative performance of the different systems, and are also good for seeing the effect of different options (triangle size, texturing, lighting, etc).>, I found it interesting.
http://www.evl.uic.edu/pape/CAVE/linux/speed/
A few more semi-related pages by the same author: http://www.evl.uic.edu/pape/CAVE/
I mentioned a similar comparison by the same author in this nekochan thread: viewtopic.php?f=11&t=15636&
If you haven't already, be sure to check out the links to running Quake2 in an SGI Cave system: viewtopic.php?f=11&t=15636&p=122514&#p122514
shadowless
Re: Period Comparison of Onyx(1) IR and Commodity Graphics
Unread postby shadowless » Thu Dec 24, 2009 9:27 am
Interesting articles, thanks for sharing
tomo
Unread postby tomo » Fri Dec 25, 2009 5:29 am
Nice numbers for old SGI's.
O2 was only 180MHz R5k and it catch modern graphics with mutch faster processors.
Just one think - can someone compile tenmilion test? I'd like to run it on my O2 witch is on the other side of speed spectrum to see difference. Thanks
http://www.tomosgi.co.cc
Unread postby SAQ » Fri Dec 25, 2009 9:16 pm
tomo wrote:Nice numbers for old SGI's.
Not to mention that it looks like some if not most of the IRISes were memory-starved (96MB for IRIX 6.5? 256 is better...)
Unread postby vishnu » Fri Jan 08, 2010 9:43 pm
The original source code to tenmillion.c is here:
http://www.oss.sgi.com/projects/performer/mail/info-performer/perf-96-11/0181.html
I got it to compile and run on my Linux box by changing the call to gettimeofday() to include a timezone struct and by changing the return type of main() to int. I'll try it on my SGI as soon as I get some caffeine into my system tomorrow morning... 8-)
If anyone's interested, to compile it (on Linux) I used:
gcc -Wall -L/usr/X11/lib -lGL -lGLU tenmillion.c -o tenmillion.c.exe
The -Wall switch is optional, but interesting. I always use it when I compile other people's code... :mrgreen:
canavan
Unread postby canavan » Sat Jan 09, 2010 8:10 am
Compiled with
c99 -n32 -mips4 -OPT:Olimit=0:roundoff=3 -TARG:platform=IP27:proc=r10000 -Ofast  tenmillion.c  -o tenmillion -lGL -lGLU -lfastm  -lm -lX11
tenmillion.bin
tenmillion IRIX-mips4
(43.66 KiB) Downloaded 159 times
zmttoxics
Unread postby zmttoxics » Sat Jan 09, 2010 9:02 am
vishnu wrote:The original source code to tenmillion.c is here:
".c.exe". Haha. Have you been programming in windows for too long? -o tenmillion would have been fine, and probably wouldn't have caused me to have a morning chuckle. :D
Stuff.
Unread postby vishnu » Sat Jan 09, 2010 10:08 am
Yeah, I'm a Visual C++ goit from way back. :oops: But that doesn't alter the fact that consistent filename extensions are a good idea. I've always wondered Unix uses them for it's shared objects but not executables. Just to be different from Microsoft? I find it a tremendous convenience, for example if I want a list of all the programs I've compiled in $HOME all I have to do is `find ~ -name \*exe` ...
ShadeOfBlue
Unread postby ShadeOfBlue » Sat Jan 09, 2010 11:11 am
vishnu wrote:if I want a list of all the programs I've compiled in $HOME all I have to do is `find ~ -name \*exe` ...
find ~ -exec file {} \; | fgrep executable
There is no excuse for putting .exe at the end of UNIX executable names :)
Unread postby vishnu » Sat Jan 09, 2010 12:44 pm
Oh right! I suppose next you're going to be telling me I shouldn't be renaming all my .so's to dll's... :twisted:
ShadeOfBlue
Unread postby ShadeOfBlue » Sat Jan 09, 2010 1:13 pm
:lol:
canavan
Unread postby canavan » Sun Jan 10, 2010 7:37 am
I'd prefer find ~ -perm -1
ShadeOfBlue
Unread postby ShadeOfBlue » Sun Jan 10, 2010 11:13 am
This will also return directories and other files which happen to have the executable bit set (e.g. shared libraries, scripts, ...).
Unread postby dexter1 » Mon Jan 11, 2010 1:39 am
find . -type f -perm -1
Megatron-UK
Unread postby Megatron-UK » Mon Jan 11, 2010 5:12 am
Output from my work machine (dual core Athlon X2 5600 + Nvidia Quadro 3450):
./ten light texture zbuffer area=850
running on xxxxx (Quadro FX 3450/4000 SDI/PCI/SSE2) Mon Jan 11 13:11:03 2010
visual: 0x29
850 pixel triangles, 39 triangles/strip, 1 strips
vertex data: n3s t2s v3f
flat shading, zbuffer on, light on, texture on
window size: 848 x 848
test time: 1.947 secs.
time per frame: 0.196 msecs.
geometry rate: 1594743 triangles/sec
fill rate: 1355.532 Mpixels/sec
:Indigo2IMP: [ R10k-195/MaxImpact +TRAMs/896Mb/73Gb-15krpm/G160/6.5.22 ]
:Octane2: [ Dual R12k-400/V8/2Gb/73Gb-15krpm/6.5.29 ]
