Icons for Irix
dennisjunior
Icons for Irix
Unread postby dennisjunior » Sat Jun 06, 2009 7:05 am
Hello,
I created some icons for my favourite applications.
openttd.fti.gz
(1.08 KiB) Downloaded 85 times
thunderbird.fti.gz
Thunderbird simple
(3 KiB) Downloaded 104 times
firefox.fti.gz
Firefox simple
(2.76 KiB) Downloaded 75 times
thunderbird.fti.gz
(5.18 KiB) Downloaded 66 times
firefox.fti.gz
(4.89 KiB) Downloaded 66 times
canavan
More Icons for Irix
Unread postby canavan » Sat Jun 06, 2009 11:41 am
Some icons for irix that I haven't published anywhere yet.
mozilla.fti.gz
(1.46 KiB) Downloaded 60 times
konq.fti.gz
(1.3 KiB) Downloaded 57 times
ssh-fti.tgz
(4.28 KiB) Downloaded 67 times
xv-fti.tgz
(1.21 KiB) Downloaded 69 times
dennisjunior
Re: More Icons for Irix
Unread postby dennisjunior » Sat Jun 06, 2009 12:27 pm
canavan wrote:Some icons for irix that I haven't published anywhere yet.
Thank you!
indyman007
Re: Icons for Irix
Unread postby indyman007 » Sat Jun 06, 2009 12:32 pm
Someone probably has already answered this question but how do you change the icons?
:Indy: R4600PC 133 MHz
Mac Mini 2.5GHz 8GB RAM
Raspberry Pi
dennisjunior
Re: Icons for Irix
Unread postby dennisjunior » Sat Jun 06, 2009 12:44 pm
indyman007 wrote:Someone probably has already answered this question but how do you change the icons?
Copy eg. the firefox.fti file into /usr/lib/filetype/local/iconlib directory
In terminal got to /usr/lib/filetype
run make -u
Logout / Login
If your application don't have an icon, you need to create an ftr file.
http://www.nekochan.net/wiki/index.php/Install_New_Icons
tomo
Unread postby tomo » Sat Jun 06, 2009 11:13 pm
Many thanks! I'm using XV and ssh (probably as most users here) so icons are welcome! :)
I'v just add ftr file to blowfish so everyone can use it without problems. BTW very nice work with the fish.
xv icon did not work with drag and drop - so I'v fixed it.
And to "warm my own soup" I'v add my own created icon for neko_links. Icon file was posted on this forum somwhere else but this is stretched and have also corresponding ftr file.
xv_ftr.tar.gz
(358 Bytes) Downloaded 54 times
ssh_ftr.tar.gz
(374 Bytes) Downloaded 95 times
links_icons.tar.gz
(910 Bytes) Downloaded 57 times
http://www.tomosgi.co.cc
dennisjunior
Re: Icons for Irix
Unread postby dennisjunior » Sun Jun 07, 2009 7:59 am
Based on the original pidgin icon Image
pidgin.fti.gz
(2.15 KiB) Downloaded 66 times
Re: Icons for Irix
Unread postby josehill » Sun Jun 07, 2009 9:01 am
nice job on the pidgin icon...
modology
Re: Icons for Irix
Unread postby modology » Fri Jun 12, 2009 8:42 am
Any tips on how you draw these icons? (your thunderbird icon is really smooth and detail)
dennisjunior
Re: Icons for Irix
Unread postby dennisjunior » Sun Jun 14, 2009 5:37 am
modology wrote:Any tips on how you draw these icons? (your thunderbird icon is really smooth and detail)
I was trying to follow this tip from the Iconsmith Userguide http://techpubs.sgi.com/library/tpl/cgi-bin/getdoc.cgi/0650/bks/SGI_Developer/books/IIDsktp_IG/sgi_html/ch12.html
"Tip: Draw your icon design on a clear transparency, and tape the transparency to the top of the monitor housing. Using the drawing as a guide, trace it using IconSmith."
I was print a thunderbird svg logo on a transparency film with a laser printer.
canavan
Re: Icons for Irix
Unread postby canavan » Tue Jun 16, 2009 12:52 pm
I've used a transparent .XPM and sxpm (it's in freeware fw_libxpm), but not in nekoware to draw the blowfish icon. Since that covers exactly those places where you want to click, either create your parts elsewhere and drag them to the final destination, or keep using Alt-F1/Alt-F3.
Re: Icons for Irix
Unread postby hamei » Thu Jun 18, 2009 12:23 am
btw, canavan - nice icon on the xanalyser. Just noticed it, since I was starting it fom a command. You do good work :)
modology
Re: Icons for Irix
Unread postby modology » Fri Jun 19, 2009 11:29 am
I like pidgin icon and the firefox logo overall. However I think it's not very nice and clean when you put on the desktop when a dense and detail icons
I attempt to adjust pidgin icon a little bit. Hope u guy like it
pidgin.fti.gz
(1.8 KiB) Downloaded 52 times
modology
Re: Icons for Irix
Unread postby modology » Fri Jun 19, 2009 11:34 am
Refined folder icons that I created. Extract the 2 files fti and copy those 2 into /usr/lib/filetype/iconlib/ then just do "make" like usual
generic.folder.open.fti.gz
(580 Bytes) Downloaded 62 times
generic.folder.closed.fti.gz
(560 Bytes) Downloaded 60 times
modology
Re: Icons for Irix
Unread postby modology » Fri Jun 19, 2009 12:07 pm
Another batch. Copy all of these into /usr/lib/filetype/system/iconlib/ and do "make"
windows.fti.gz
(525 Bytes) Downloaded 69 times
syserrpanel.fti.gz
(514 Bytes) Downloaded 60 times
mouse.fti.gz
(1.15 KiB) Downloaded 69 times
keyboard.fti.gz
(667 Bytes) Downloaded 60 times
gfx_backend.fti.gz
(651 Bytes) Downloaded 64 times
desktop.fti.gz
(558 Bytes) Downloaded 57 times
background.fti.gz
(1.23 KiB) Downloaded 64 times
