Howto delete / amend toolchest entries ?
whiter
Unread postby whiter » Sun Nov 06, 2005 11:18 am
I want to get rid of some toolchest entries, alter some others, and add some in between existing ones (not to the bottom!)
How can this be achieved using the .auxchestrc file ?
unixmuseum
Re: Howto delete / amend toolchest entries ?
Unread postby unixmuseum » Sun Nov 06, 2005 12:51 pm
whiter wrote:I want to get rid of some toolchest entries, alter some others, and add some in between existing ones (not to the bottom!)
You need to create a .chestrc in your home directory for this, .auxchestrc will only add to the default toolchest...
whiter
Unread postby whiter » Sun Nov 06, 2005 1:38 pm
not true.
I just found out you can remove items by adding a line like
remove Itemname
to the .auxchestrc file. So that leaves the questions about how to add items on a specific location, and how to 'overwrite' an item. (could be done by deleting it first ofcourse, and then re-adding at the specific location. But how to do that?)
Unread postby foetz » Sun Nov 06, 2005 8:39 pm
whiter wrote:not true.
remove Itemname
to modify the toolchest systemwide edit /usr/lib/X11/system.chestrc or /usr/lib/X11/nodesktop.chestrc.
unixmuseum
Unread postby unixmuseum » Sun Nov 06, 2005 8:40 pm
whiter wrote:So that leaves the questions about how to add items on a specific location, and how to 'overwrite' an item. (could be done by deleting it first ofcourse, and then re-adding at the specific location. But how to do that?)
Tried .chestrc yet? ;-)
VenomousPinecone
Unread postby VenomousPinecone » Mon Nov 07, 2005 9:48 am
foetz wrote:to modify the toolchest systemwide edit /usr/lib/X11/system.chestrc or /usr/lib/X11/nodesktop.chestrc.
Kick ass, thanks. :D
NOTE You cannot use Virtual Disk Manager to create or to shrink physical hard drives.
Unread postby foetz » Mon Nov 07, 2005 11:25 am
u r welcome :D
edefault
Unread postby edefault » Tue Nov 08, 2005 4:19 am
that´s what I always do ;-) and also /usr/lib/X11/remote.chestrc of course
(in case I´m too lazy to walk over to that machine I want to work on).
Btw, just another question:
How do I invoke a program from the local toolchest on a remote machine?
By clicking an item in the _local_ toolchest that makes e. g. Firefox run remotely but display locally _without_ logging in on that remote machine first?
Maybe something like
f.checkexec.sh.le REMOTE-SERVER:/some-directory/some-executable
is possible?
This could possibly work around the library mismatch problems I encountered with Firefox (see another thread).
TIA
Walther
Valueing life is not weakness; disregarding it is not strength. -Mirage-
edefault
Unread postby edefault » Tue Nov 08, 2005 4:27 am
edefault wrote:This could possibly work around the library mismatch problems I encountered with Firefox
OK, to be more specific: Firefox/Thunderbird runs fine when invoked on a tcsh prompt after an rlogin user-name@REMOTE-SERVER, but locally goes
    3% 2617:/usr/freeware/mozilla-thunderbird/thunderbird-bin: rld: Fatal Error: Cannot Successfully map soname 'libgtk-1.2.so.1' under any of the filenames /usr/nekoware/lib/libgtk-1.2.so.1:/usr/freeware/mozilla-thunderbird/libgtk-1.2.so.1:/usr/freeware/mozilla-thunderbird/plugins/libgtk-1.2.so.1:/usr/local/thunderbird/lib/mre/mre-1.0.6/libgtk-1.2.so.1:/usr/lib32/libgtk-1.2.so.1:/usr/lib32/internal/libgtk-1.2.so.1:/lib32/libgtk-1.2.so.1:/opt/lib32/libgtk-1.2.so.1:/usr/nekoware/lib/libgtk-1.2.so.1.1:/usr/freeware/mozilla-thunderbird/libgtk-1.2.so.1.1:/usr/freeware/mozilla-thunderbird/plugins/libgtk-1.2.so.1.1:/usr/local/thunderbird/lib/mre/mre-1.0.6/libgtk-1.2.so.1.1:/usr/lib32/libgtk-1.2.so.1.1:/usr/lib32/internal/libgtk-1.2.so.1.1:/lib32/libgtk-1.2.so.1.1:/opt/lib32/libgtk-1.2.so.1.1:
no matter how often I install fw_gtklib_1.2(blabla).
TIA
Walther
Unread postby foetz » Tue Nov 08, 2005 4:37 am
to be more flexible you might wanna write a script and call that from the toolchest.
whiter
Unread postby whiter » Tue Nov 08, 2005 11:45 am
ofcourse I do NOT want to modigy system.chestrc or .chestrc, since I do not want to change any systemwide settings. I'm talking about user-level modifications. Specificaly user-level modifications that do not alter/overwrite/hide anything provided by the systemwide default.
I specificaly asked about .auxchestrc. So the question still remains the same.
Anybody who knows the answer ?
unixmuseum
Unread postby unixmuseum » Tue Nov 08, 2005 12:50 pm
whiter wrote:ofcourse I do NOT want to modigy system.chestrc or .chestrc, since I do not want to change any systemwide settings. I'm talking about user-level modifications. Specificaly user-level modifications that do not alter/overwrite/hide anything provided by the systemwide default.
And the answer still remains the same: create a .chestrc in your home directory, altering a copy of the system-wide chestrc... Same principle as creating a .backgrounds in your home directory that's going to overwrite the default desktop backgrounds...
http://techpubs.sgi.com/library/tpl/cgi ... 079-PARENT
whiter
Unread postby whiter » Tue Nov 08, 2005 1:05 pm
that's not an option.
I'm searching for a way to do it from .auxchestrc.
unixmuseum
Unread postby unixmuseum » Tue Nov 08, 2005 7:40 pm
I guess I fail to understand why you'd like toolchest to source the system-wide chestrc and then source your auxchestrc to remove some entries... Wouldn't it make more sense to use .chestrc to do it all in the first place? Just my two cents...
Unread postby nekonoko » Tue Nov 08, 2005 9:36 pm
whiter wrote:that's not an option.
That doesn't make any sense. Using .chestrc in your home directory doesn't change system wide settings (just the user), so why should it not be an option? It's no different than using .auxchestrc in your home directory.
