New to SGI & Indigos
dravier
Unread postby dravier » Thu Jul 31, 2003 4:02 pm
this is my first Indigo / SGI / IRIX experience... i have an IRIS Indigo:
> R4400 Revision 5 @ 150 MHz
> 112 MB memory
> IRIS Audio Processor Revision 10
> GR2-ELAN Graphics
> IRIX 6.2
[2 int 450MB and 1 ext 4.5 GB drives, CD-ROM, floppy and possible int tape if i switch out the floppy].
i was given a copy of 5.3 w/ an IndyZone disc but it doesn't seem to work... would love some suggestions on where to get software and some tutorials for IRIX and what not. thanx!
oh... dare i ask how difficult the 3D glasses are to come by and what one uses them for? i saw the connector on the back... was curious.
- dravier
"a little rebellion now and then is a good thing" -Thomas Jefferson
0ctane
Unread postby 0ctane » Thu Jul 31, 2003 9:26 pm
3d glasses are typically not cheap. One of the man suppliers is stereographics. Their product is the "crystaleyes". I have used them for many years doing molecular modelling. A new package (one emitter and two glasses) will run you ~$1000. I do remember hearing about cheaper glasses that will work with the stereographics emitter. The emitter syncs the screen refresh to the glasses' lcd shutters. Consequentially they only work with CRTs.
It looks like you can get a pair of glasses for $99 on ebay right now. The seller says that an emitter will cost another $99. Although, there description "Item appears to be in very good condition" makes me think it was never tested. Caveat emptor and all. :roll:
lisp
Unread postby lisp » Fri Aug 01, 2003 12:32 am
I f you can find working ones, ELSA Relevator 3D glasses are compatible and cheap.
lisa
mistermark
Unread postby mistermark » Fri Aug 01, 2003 1:16 am
...maybe this is of any help... haven't tried it myself (since I only enjoy my SGI Challenge S through Command Line Interface... :-)). Bu there must be plenty of those Asus-glasses out there, I know several people who gave them away...
Connecting (cheap) stereo glasses
to SGI workstations
http://huizen.dds.nl/~roosmcd/
"I want an equal amount of blueberries in each muffin, understand?"
directedition
Unread postby directedition » Fri Aug 01, 2003 4:47 am
You know, someone should write a basic tutorial set for people new to SGIs somewhere on the site. Like how to use Inst, the Software Manager, hinv, stuff like that. Things that only SGI has and can confuse the new user. I would write some myself, but I don't think I have quite the technical skill to use all the features of inst....
- Jim
:Indy: <- signed by The Screensavers :) :540: :1600SW: :1600SW: <- touchscreen :PI:
0ctane
Unread postby 0ctane » Fri Aug 01, 2003 5:05 am
directedition wrote:You know, someone should write a basic tutorial set for people new to SGIs somewhere on the site. Like how to use Inst, the Software Manager, hinv, stuff like that. Things that only SGI has and can confuse the new user. I would write some myself, but I don't think I have quite the technical skill to use all the features of inst....
You could write a masters thesis on that subject.
Shtoink
Unread postby Shtoink » Fri Aug 01, 2003 9:14 am
Well, there is that "Getting Started" section, you could possibly start a thread in there... :wink:
RageX
Unread postby RageX » Fri Aug 01, 2003 10:24 am
All that is convered in the IRIX Admin: Software Installation and Licensing manual.
Most other basic questions are answered pretty well by techpubs. Then there is always Ian Mapleson's site, the SGI FAQs, google groups, this forum, and a few other sgi sites out there.
