file alteration monitor goes down
squeen
Unread postby squeen » Thu Sep 01, 2005 4:03 am
THe file alteration monitor (fam) on the Onyx350 keeps dying. I'm running 6.5.27. There are no network mounts, just two local hard drives. I get an error message telling me either to log out or restart the machine. The SYSLOG says lots of:
Aug 29 12:13:37 3D: fam[1268]: recvmsg: Inappropriate message buffer length
Aug 29 12:13:37 4D: inetd[201145]: /usr/etc/fam: exit status 0x1
I get similar messages on an Octane2 running 6.5.27, but the fam doesn't go down as often. When the fam is down, desktop icons dissappear and fm displays no files names. This has always happened sporadically under IRIX, but the Onyx problem has become endemic. Something in the system set-up?
Any clues y'all? Very frustrating. :(
EDIT: The network connection changed recently on the machine. In general the network has been queer ever since (thanks for the "upgrade" IT!!). Almost definately related. Can fam be made less sensitive to the network?
somecodemonkey
Re: file alteration monitor goes down
Unread postby somecodemonkey » Thu Sep 01, 2005 4:14 am
squeen wrote:Can fam be made less sensitive to the network?
I am guessing the "unplug it" answer isn't valid? :p
1995: Real Audio released, allowing users to listen to halting bursts of static in real time.
squeen
Unread postby squeen » Thu Sep 01, 2005 4:18 am
Nope. Even a quasi-stable network is better than none. :)
I found this in /etc/fam.conf
# local_only makes fam ignore requests from remote clients & remote fams.
# Note that this is ignored if fam is started by inetd.
# The -L command-line argument overrides this option.
local_only = false
However, it seems that fam is most likely started by inet.d, so it's not likely to help. Now I just need to grok inetd.
Still fumbling....
Unread postby foetz » Thu Sep 01, 2005 5:06 pm
you could just turn-off fam's start within inetd. no need to disable inetd completely.
comment out:
sgi_fam/1-2 stream  rpc/tcp wait/lc    root    ?/usr/etc/fam            fam
squeen
Unread postby squeen » Fri Sep 02, 2005 3:43 am
Hi foetz!
What I have done is add the -L option to the end of the inetd.conf line hoping that would do the trick---we'll see.
However, if I take inetd out of the loop, any suggestions on where to start fam from? rc2.d script?
Thanks for the reply.
Unread postby foetz » Sat Sep 03, 2005 4:14 pm
squeen wrote:Hi foetz!
sure, rc2.d should be fine.
why do you think after stating it outside inetd it will be better?
squeen
Unread postby squeen » Mon Sep 05, 2005 8:36 am
foetz wrote:why do you think after stating it outside inetd it will be better?
From the fam man page
-L Local-only mode. fam will only accept requests
from clients running on the local machine.
This overrides the local_only flag in the
configuration file. This option is ignored if
It isn't really clear which option is ignored, local_only, -L or both. I'm hoping by adding the -L option in inetd.conf I will circumvent this, but if it doesn't, I have another method to try. BTW, (crossing fingers) so far so good.
squeen
Unread postby squeen » Tue Sep 06, 2005 10:02 am
Just went doen again. Got this message
sgI_fam/tcp server failing (looping), service terminated. Use -R to increase maximum rate if this is...
The help says
Server Failing (looping); Service Terminated
This message indicates that the inetd (Internet super-server) daemon received too many requests for a specific service. By default inetd limits this to 1000 connections every 60 seconds.
This message may occur due to any of the following reasons:
Too many service requests occurred in a short interval.
A broken client program is requesting a service too often.
A malicious user is running a program that is flooding the server with too many requests, to deny service to other users.
The invoked service program has an error causing clients to retry their requests for services too quickly.
If only the first problem exists, you may use inetd's -R option to increase the rate limit (see man inetd for more information.)
If the problem persists, contact your System Administrator or your service provider.
For information on how to configure or disable System Alerts, click here
squeen
Unread postby squeen » Tue Sep 06, 2005 10:05 am
From the syslog
Sep  6 12:58:23 3D:eno fam[41465874]: Warning!  Started by inetd, so -L (local_only) option is being ignored!
Sep  6 12:58:23 3D:eno fam[41465874]: sendmsg: Inappropriate message buffer length
Sep  6 12:58:23 3D:eno fam[41381761]: recvmsg: Inappropriate message buffer length
Sep  6 12:58:23 4D:eno inetd[41428585]: /usr/etc/fam: exit status 0x1
Unread postby foetz » Wed Sep 07, 2005 5:38 pm
squeen wrote:From the syslog
okay, so did you start it by hand?
