Fan louder in dual head, normal ?
rmigfr
Unread postby rmigfr » Mon Mar 29, 2004 2:16 pm
Hello,
I have a MXE in my octane, I installed on it a second card, an SE board (in slot C, as advised in the SGI dual head manual for SI/MXI).
My fans start to be really louder. I suppose it is due to the heat generated by the dual head configuration. Is it normal ?
Or is it a sign that my Octane need a serious cleaning (in this case, is the vaccum cleaner safe ? I suppose yes).
Thanks,
Rémi
sum][one
Unread postby sum][one » Mon Mar 29, 2004 3:37 pm
I done the same 2 weeks ago.. and same louder fan.. my Octane was just cleaned so i'm almost sure it just need more airflow.. and so i just removed the SE cause it was even louder than the O200.
:: jean-claude
:: mimgfx dot com
Brombear
Unread postby Brombear » Mon Mar 29, 2004 8:24 pm
This is normal, if you populate more than 2 XIO-slots the fan will be switched into the fast mode.
Matthias
Involution
Unread postby Involution » Sun Apr 11, 2004 8:01 am
NEVER use a vaccum cleaner in a computer unless you have one that has a proper grounding strap. Octanes collect a lot of dust, very quickly. This is one of the downsides to a large amount of airflow going through the machine :) So what i would suggest is pulling out your mainboard, your PSU, and your video cards and blow some compressed air to loosen+remove the dust; then be _very_ careful plugging them back in (there are horror storys about people wrecking their backplanes by not paying attention when jamming their modules back in)
