slow Octane interface speed
gijoe77
Unread postby gijoe77 » Sat Jan 21, 2017 2:03 am
I had an octane with a 1GigE card - I cloned the disk. It was *blazing* fast. easily > 10Mb/s
I put the cloned disk in another octane with a different 1GigE card - it runs painfully slow. ~ 200kb/s
ifconfig -va shows me its 1000Mb/s full-duplex. If I pop a different IRIX disk into the Octane I get really good network speeds - so the problem seems to be on the cloned disk.
I used system manager to config the interface to the proper hostname and IP/subnet. I can't seem to figure out why its running so slow - anyone have any ideas what I missed?
Geoman
Re: slow Octane interface speed
Unread postby Geoman » Sat Jan 21, 2017 2:45 am
On the Octane with the slow eth speed there might be jumbo frames activated. This brings down an IRIX machine if the frame size differs inside the network.
http://bukosek.si/articles/irix-jumboframes.html
gijoe77
Unread postby gijoe77 » Sat Jan 21, 2017 2:48 am
There is a good chance that might be the case, let me do some digging
gijoe77
Unread postby gijoe77 » Sat Jan 21, 2017 6:01 am
the original workstation had a eg0 interface, my current workstation has a tg1 interface. I checked for jumbo frames but it is not configured for either eg0 or tg1. I'm still digging but it sure is strange.
I also compared /etc/config/tgconfig.options on both disks - they are the same, and the TCP buffer sendspace is set to 256KB.
Unread postby foetz » Sat Jan 21, 2017 11:03 am
gijoe77 wrote:If I pop a different IRIX disk into the Octane I get really good network speeds
and that different disk is also a clone or has it been installed on this octane?
gijoe77
Unread postby gijoe77 » Sat Jan 21, 2017 11:09 am
I did a clean install on the octane - that's the original disk - I get good network speeds when I use the native disk.
I got my hands on a discreet octane and I cloned that disk, when I put that cloned disk into my current octane its having a really hard time with speeds. I know some discreet installs do enable the jumbo frames so I was really hoping that was the case but it appears to not be enabled.
Unread postby foetz » Sat Jan 21, 2017 11:21 am
well, you said the network card is different. in what way? original sgi card? or different kernel module? or different hex patch?
gijoe77
Unread postby gijoe77 » Sat Jan 21, 2017 12:28 pm
I think they should all be original SGI cards. From my understanding the original discreet Octane had a SGI branded card that was using the eg0 driver, my current octane has a SGI branded card using the tg1 driver. I don't have access to the original discreet octane anymore.
Unread postby foetz » Sat Jan 21, 2017 1:21 pm
then i'm surprised the clone works at all
gijoe77
Unread postby gijoe77 » Sat Jan 21, 2017 1:32 pm
i do believe the clone drive rebuilt/autoconfig'd at some point - I didn't use the network until a I swapped the original and clone a few times
Unread postby foetz » Sat Jan 21, 2017 3:30 pm
okay that's an option. still strange tho, it's nothing else than replacing a network card which should of course work anyway.
maybe discreet added some custom stuff in that regard ...
